Question about HP LaserJet 4200 Printer
Duplex printing how can i configure the printer to print duplex
  • Anonymous May 11, 2010
    Do you have HP LaserJet Two sided Printing Accessory for the printer?
    Genius:
  • 1,447 Answers
SOURCE:
How configure duplexer dell 3110 cn?
You don't really need to configure it as such.
The printer should recognise the duplexer if it is fitted correctly, and it's difficult NOT TO.
Printing a settings page will show the duplexer under Printer Options.
You printer driver needs to be aware of the duplexer, there is an option to 'get information from printer' within the Windows driver.
Once the driver knows the duplexer is available, you'll have an option in the printer driver to print double sided.
Apr 30, 2014 | Dell 3110cn Laser Printer
How to print double sided
DOES THE PRINTER HAVE A DUPLEX MODULE ? Print out a configuration page and see if the duplexer appears under options. Good luck.
Jan 16, 2013 | Office Equipment & Supplies
Why i need keep to press ok when i want to print in duplex mode? how i can i change it to auto?
!st Press the MENU button.
Use the down arrow to navigate to "SHOW ME HOW"
Select PRINT ON BOTH SIDES.
It will print a page that shows how to use the duplexer.
If that doesn't work...Use the arrow again to display CONFIGURE DEVICE MENU.
Go to the PRINTING SUBMENU
Drill down to DUPLEX.
Make sure that "ON" is selected.
May 23, 2011 | HP Laserjet P4015x Printer
What is it wanting me to do when it says "install duplex unit"?
A duplex unit allows you to automatically print double sided jobs. It sounds like a duplex unit is an option on your printer. If it is asking you to install a duplex unit, it is either configured for duplex printing i.e in your printer setup, duplex printing is enabled or, your driver has two sided printing enabled as its default.
Hope this helps.
Jan 22, 2011 | Office Equipment & Supplies
My HP 4700 printer suddenly can not print on both sides, yet it used to print on both sides. I can't see the option for duplex on its printing menu. Pls help
You can enable duplex printing from your computer, if it somehow got turned off. Open the printer program, and under Configuration Settings, click Duplex Mode, then click Enable Duplex Mode and then Apply.
At the printer, you can find the Duplex options by clicking Menu and scrolling down till you see Configure Device. Duplex is in that menu.
Aug 06, 2010 | HP LaserJet color laser printer
How to print back to back pages on sharp Mx-2300N
Back to back mean duplex print .If your copier has a duplex cassette you can use duplex print before configure it see your user guide and follow this function.
Dec 14, 2009 | Sharp MX-2300N Color Copier
Will not configure for two sided card printing
What printer are you using? Many printers cannot print two-sided or duplex printing. If your printer cannot handle duplex printing, you'll need to do what's called "manual" duplex. Print one page then reinsert the paper and print the second page. Test this on cheap paper first to determine if you need to insert the paper printed side up and which way (if any) you'll need to roate the page.
Sep 13, 2009 | Hallmark Card Studio 2009 Deluxe Full...
HP Laserjet 2015n printer
Sir, the Hp LaserJet 2015n printer CANNOT automatically do duplex printing since the printer does not include mechanism and paper storage areas to cycle the paper through the printer a second time and print on the reverse side. Manual duplex printing can be done as follows: Choose duplex printing and remove all sheets after the printing is complete. Turn the sheets over while preserving the orientation and insert them in the paper feed path. I have an HP 1020 laserjet printer which is similar to the 2015.
Aug 22, 2009 | HP LaserJet P2015n Printer
Duplex printer
Check the driver you have installed on your computer, that's where the duplexing would be generated from. You should be able to choose through print properties at this point. Here's the link to Sharp:
http://www.sharpusa.com/products/business/copiers/business_copiers_drivers/
Sep 10, 2008 | Sharp AR-507 Copier
HP C4200 Printing both sides
Some printers automatically print on both sides of a page (automatic duplex printing); other printers allow you to manually reinsert pages to print the second side (manual duplex printing); and some printers do not support duplex printing at all. To find out whether your printer supports duplex printing, you can check the printer manual, contact the printer manufacturer, or check the printer's properties by clicking Properties in the Print dialog box.
To find out whether your printer supports duplex printingThe options in the Print dialog box can vary depending on your printer options and configuration.
You can use the following clues to determine whether a specific printer supports duplex printing:
  • Check your printer manual or consult your printer manufacturer.
  • Click the tabs in the Print dialog box and review the options. If options such as print on both sides of the paper, duplex printing, or two-sided printing appear on any of the tabs, the printer probably supports automatic duplex printing.
Notes
  • If you are printing to a combination copy machine and printer, and the copy machine supports two-sided copying, it probably supports automatic duplex printing.
  • If you have more than one printer installed, it's possible that one printer supports duplex printing and another printer does not.
To manually set up a printer to print to both sides of a sheet of paperWith some printers, you can use the Manual duplex check box under Printer in the Print dialog box. Word will print all of the pages that appear on one side of the paper and then prompt you to turn the stack over and feed the pages into the printer again.
You can also use the following procedure to set up your printer for manual duplex printing:
  1. On the File menu, click Print.
  2. In the lower-left corner of the Print dialog box, in the Print box, click Odd pages.
  3. Click OK.
  4. After the odd pages are printed, flip the stack of pages over, and then in the Print dialog box, click Even pages.
  5. Click OK.
Note Depending on the printer model, you might have to turn and reorder the pages to print the other side of the stack.
Sep 08, 2008 | Office Equipment & Supplies
HP LaserJet 4200 Printer Logo
134 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
