Back to:
Tags:
Home Theater Systems
Generic problem for all Home Theater Systems
Unable to power-up a Pioneer VSX-D714 unit (by 2 users)
posted by Soggycrumpet on Apr 06, 2008
The unit will not respond to remote or manual operation of power on/off button.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Jun 29, 2008
This is the third time mine has turned off and wont turn back on. The last two times were covered under warranty and the uni was reset at the service centre, but this time it is out of warranty and I want to know how to reset the unit myself.
The "factory reset" (Press TONE and STANDBY button for 3 seconds) does nothing..
Best Solution
posted on Apr 06, 2008
Thanks for Trying (70)
marsrover
Rank:Wiz Wiz
Rating: 80%, 218 votes
change power cord first- apply a new battery to remote- apply a contact cleaner spray in on-off switch.if all above failed ask for help from service center near to you.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Unable to power-up a Pioneer VSX-D714 unit:
I don't want to Accept this solution
Solution #2
posted on Sep 10, 2008
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Have a vsx-d714 with the same problem, looks like a main board containing cpu has gone corrupt, causing non boot up of the unit. on board mem battery can be disconnected then board shorted to drain caps then reconnected, This should reset the unit.
Thank You!
Can you Help with these Home Theater Systems problems?
Sony DAV-S888 System
Ive got my pc connected up to my surround sound. When I...
Panasonic SC-HT730 System
When I try to use the functions the secreen comes up with...
Samsung HT-Z310T Theater System
Hello, I just purchased this home theater system 2 months...
Bose Lifestyle 38 DVD Home Entertainment...
I'm having a problem with my Bose Lifestyle DVD Home...
My HT-TQ72 home theater system shuts down itself in a...
Loading problems.
Repair Service
Find Home Theater Sys. Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
