Question about Philips LX3500D System
DVD player does not read disc or finish loading, I can not play movies or cd's.
  • MyPet Apr 07, 2008
    I have tryed to clean it several times with a cd cleaner over the last day, and still no changes..HELP!! thanks
    Genius:
  • Philips Master
  • 1,550 Answers
Try to clean it with a cd cleaner maybe is only dirty.
Posted on Apr 06, 2008
I cleaned my dvd player tested it working fine. Watched a movie. Put it back together now just reads loading.
Someting in the player intake can be not timed a microswitch or switch contact s inside the tray that will see if a cd is loaded is not timed or not finishing that it not let see the signal to get focussing the table of contents of the cd , a slipping belt or what ever . a dirty mode select switch in some kind of players with more cd or dvd .
if the cd rotating if loaded then it goes focussing for the reading mode .
cleaning or replace belts contactspray inside microswitch or contacts inside the disc tray.
Mar 24, 2016 | Televison & Video
I have element dvd #e1023pd ,i have a screen ,but cd will not work, will not except any cd. what am i doing. dennis
Ur DVD disc movie work,only CD music have problems?Laser eye,might be dirty,not reading the laser disc.Tries websites like Amazon.com,Ebay.com to buy a Laser eye cleaning kit.Just put in the disc,play it,will clean the laser eye,it'll tell u when it finish and to take the disc out.
Oct 25, 2010 | Element Electronics E1020PD Player
DVD player wont read disc.....
how long have you been using this player? The problem should be from the lens (laser).
The lens is weak and that's why it cannot read/load all Cd's/movies.The weak lens is what is making the player select discs, that is, not playing all discs.
Get a lens cleaner and use it to clean the lens, but if the lens still does the same thing even after using the lens cleaner, then it means you would have to change the whole lens completely to a brand new one.
By so doing your player would play all Cd's/movies with no problem at all.
Good luck.
Apr 23, 2010 | Samsung HT-Q70T System
Sony Portable Cd/DVD Player DVP-FX810, "loading", "check disc"
Hey Teddybearman, I have exactly the same problem as you have. Did you manage to find out how to fix it?
Regards,
Seqdarsca
19 July 2010
Jun 07, 2009 | Sony DVP-FX810 Portable DVD Player
Plays CD but not DVD, says no disc
HI.This will occur when the optical assembly becomes unstable. this ((Whole One Piece)), assembly incorporates the spin/load motor, optics housing /arm, tracking device and tracking rail. This is connected to the loading dock assembly. This 'NO Disc' or CD NOT PLAYABLE, code is the result of a failed or burned out lens. It is possible that you have a dirty lens cap. you can try using a cleaning disk in this case to confirm actual lens failure. if the cleaning doesn't restore normal reading capabilities, this will confirm my diagnosis.
You will need to have the optical assembly replaced in this case. once replaced, your unit will be able to read and track once more.
Nov 29, 2008 | Insignia PD10135 Portable DVD Player
Disney dvd player wont play movies (dvd) but plays music (cd) fine
Might be the type of movie - some of them are only able to play "G" ratings. Try this: click <play> 1234 <play> It will likely unlock the dvd that is in and will begin to play. You will have to do the 'code' each time, or there's an unlock program you can purchase.
Aug 07, 2008 | Disney Princess DVD Player
Denon 2910 CD player malfunctions
you could try this http://www.fixya.com/support/t244156-denon_2910_cd_player_malfunctions or clean the lens
Nov 06, 2007 | Denon DVD-2900 DVD Player
DVD PLAYER NOT READING DISC
Well I have been repairing dvd players a while now and the main problem spots are laser ,spindle motor, laser tracking motor and the biggest culprit and un suspecting one the lens cable .....most of them range from the lens cable to the spindle motor though... the constant movement of the lens in watching a whole movie causes the cable to unknowingly and slowly break and if the spindle motor is defective ,on inserting a dvd the disc spins slowly and you may hear the lens chirping ... so you can check those....
Oct 06, 2007 | Onkyo DV-S535 DVD Player
Disc cannot be played
TRY TO RELACE YOUR CD OR OPEN YOUR CD DRIVE THEN CLEAN THE LENS WITH A COTTON OR ADJUST THE TRIMMER
Apr 19, 2007 | Samsung L70 7" Portable DVD Player...
Philips LX3500D System Logo
97 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
