I have attached cable connection to my Sanyo AVM 2020P and changed the settings to cable. Unlike my other tv sets, the Sanyo does not produce any visible channel. All channels are static. What seems to be the problem? I have tried auto programming but still the same. I'd appreciate any solution to this. Thanks
SOURCE: Sanyo avm 2506 tv no sound
As It only makes noise when there is no signal (without an antenna).clearly indicates that there is a problem in sound IF SECTION or loose contact in that section. your audio section section is ok as you get noise signal when there is no signal. also check remote control setting.
SOURCE: schematic for a sanyo avm 2506 tv
schematic for a sanyo avm 2506 tv. please check www.serviceinfo.com for schematic diagram.
SOURCE: Sanyo Model DP42848 42 inch
I just bought the Sanyo you inquire about and am afraid of this problem. Did you fix it? How do you like your tv? Wish I could help with your issue and appreciate your time, Pogo.
SOURCE: sanyo tv kit 360 ch fit in my old tv & lock channel kindly solve problem to unlock tv channel
i am imran
and i have also buy sanyo tv kit 360 ch fit in my old bpl 20"tv and i know for unlock tv channel.
try this this code definetly is solve your problem.
1st go to the locked channel.
and then press menu>system>child lock
and then press and hold down tv/av key and press swap key.
and see locked channel is unlock.
i have coming soon post for service code menu in short coming days.
please reply me to [email protected]
SOURCE: new dp 19648 sanyo hdtv no signal detected
You gotta have a way to get signal to the tv . If you don't want a outside antenna use rabbit ears .After you hook them up hide them behind the tv then do a channel scan. If you don't pick up all the stations set them on top and scan again or get satillite or cable hd boxes.
