DVD Players
Problem for DVD Players
Generic problem for all DVD Players
Sound but no picture
By frankgbsn on Apr 06, 2008
sound but no picture
Same Problem
Mar 03, 2009
-   Update:
Seems that HDCP is the cupret. If I disconnect the HDMI cable from the cable box to the TV, the problem is cured.
What should I do? Scrap that expensive HDMI cable and use component cables instead to my TV?
Is there much difference in picture quality between component and HDMI cables?
Thanks!-   poconojoe57
Mar 03, 2009
-   Sound but no picture...
Changed cable box from a digital one to an HD one. No picture from HD cable box to DVD recorder. Have DVD recorder RCA DRC8030N. DVD's play fine. Recorded shows on HDD play fine. If I hook up the cable to DVD before the cable box it works fine (but of course I only get basic cable that way). I've tried a few ways to connect from cable box to DVD player. Just coax, just yellow/white/red rca jacks, both of the above together, S-video/white rca/red rca. DVD recorder does not have component input, only output. Sometimes when I first turn it on I get a picture for maybe 10 seconds, then it disappears, only sound.-   poconojoe57
Dec 26, 2008
-   I have sound but the picture isn't showing but if i go to the setup and go to LCD Setup i can fix it a little but it doesn't help very much. -   PLEASEHELP5
Nov 22, 2008
-   Player will not display disk video on own screen. LCD menu displays fine, as do adjustment menus. Setup menu will not display. Everything displays fine on external TV when connected. Just no video feed to internal screen. Line select is on OUT. -   flydutch
Nov 20, 2008
-   sound but no picture
-   Guest
Best Solution
posted on Apr 06, 2008
Helpful)
The witch
Rank: Wiz
Rating: 83%, 716 votes
No pusiste la funcion progresive scan por error.
Was this helpful?
Yes
No
Solution #2
posted on Jun 22, 2008
Helpful)
underdog1
Rank: Apprentice
Rating: 85%, 1 votes
i had same problem . I took it apart and it started to work. while I was putting it back together it stop working again....found that when one screw was removed from bottom of player the screen worked, but when screw was out in it stopped. left screw out and seems to be working fine. Screw from back under battery near screen
Was this helpful?
Yes
No
Solution #3
posted on Sep 14, 2008
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
replace it buy a new
Popular Solutions for DVD Players
Questions and Unsolved Problems for DVD Players
Answer
what sort of scart lead for product dvp3360
Answer
Which is the Best and Lower Price DVD player
Answer
Hi, Anyone knows how to make my pioneer DV-420v-k region free?
Answer
Answer
cant find new version to download
12 Other Users Have The Same Problem - Continued
Comment by sryan001, posted on Nov 03, 2008
Has there been any solution to this problem yet?
Comment by Guest, posted on Oct 28, 2008
set it to progressive and the set went blank. its possible that its not equipped 4 progressive but how do i return 2 set up 2 change it back 2 interface?
Comment by sugarmanesq, posted on Sep 19, 2008
sometimes I get a picture; sometimes I don't - lately its been more of the latter. Plenty of sound tho
Comment by Guest, posted on Sep 19, 2008
Sometimes the picture comes on, sometimes it doesn't. Doesn't matter if its on battery power or is plugged in. How do you reset or reboot it?
Comment by chortle, posted on Aug 07, 2008
I have sound, but cannot get picture. The screen is filled with lines and there is static at times. I don't have the manual. Does the tv have to be set on a certain channel. It worked fine last time I used it, about 1 month ago. Thanks
Chortle....
Comment by hockeyman1, posted on Jun 27, 2008
have sound no picture
Comment by Guest, posted on Jun 05, 2008
I have tried everythin, nothing works, help
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top DVD Players Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
