Question about Toshiba TE2100 Notebook
PXE MOF problem
Hi, I have a toshiba 2100 and been working fine for the past months but when I turned on my laptop it showed up this message:
Intel (R) Boot Agent Version 4.0.18
Copyright (C) 1997-2001, Intel Corporation
PXE-E61: Media test failure, check cable
PXE-M0F: Exiting Intel PXE ROM>
Insert system disk in drive.
Press any key when ready....
Can you help me please?
  • 98 Answers
First, try and access your cmos setup. Look to see if your harddrive shows up.
Posted on Apr 06, 2008
5 Suggested Answers
elix0411
  • 3530 Answers
SOURCE: Broadcom UNDI PXE-2.1 v11.0.11 Copyright (C)
change your boot priority. press power button then keep on tapping F1 key until your reached to setup utility. go to boot menu and set your boot priority 1 to your HDD. if compute wasnt able to detect your HDD . then there is a problem wth your HDD, you need to call you manufacturer for HDD replacement if unit is still under warranty
Posted on Apr 04, 2010
  • 162 Answers
Hi. I think the problem on this one is its either your Harddrive has already failed or your Optical Drive has a cd inside, so double check your Optical drive if there is a disc inside it. If not this issue is also with the operating system, you can try to restore your system by pressing the One Key recovery(OKR) button found beside the power button which has a logo of an arching arrow, but remember to plugin first the ac adapter on your laptop before pressing the One Key Recovery Button and also do not press the power button to turn on your computer because when you press the OKR button it will automatically turn on your computer and proceed with the recovery process. When it gives you some option you should choose One Key Recovery and then choose System Recovery, then factory default and from there it will guide you to the whole process of recovering your machine. If this doesnt fix the issue you could also try using the Recovery disc to restore your sytem t its original settings just like the OKR. Lastly you can contact the tech support dept. of Lenovo, they are open 24/7 and this the number to contact:
US/Canada: Available 24/7 1-877-4LENOVO (1-877-453-6686)
Australia: Available 24/7 1300-557-073
New Zealand: 9am-9pm Mon-Fri 0800-446-833. Hope this helps
Posted on Jun 03, 2010
  • 11800 Answers
SOURCE: it appears INTEL(R)BOOT AGENT CE
This means that the motherboard is dead - it no longer detects its own southbridge chip, the one that controls the hard disk.
Time for a new laptop.
Posted on Oct 20, 2010
  • 18 Answers
SOURCE: Booting problem, screen message: Intel (R)
looks like it's unable to find the harddrive to boot from. It's trying to boot from a network location now.
Try entering the bios and see if you have an option to run a scan on the harddrive
Also check the boot options - make sure that it starts from the harddrive BEFORE it tries to boot from network.
Posted on May 04, 2011
How do I fix this error messageFor Athros PC/E Ethernetnet Controller v2.01.9 12/15/09 Check cable Connection! PXE-MOF:Exiting Intel PXE Rom No bootable device--insert boot disk and press any key Inte
That error comes up when the computer cannot find the hard drive or any other device to boot from so it looks for a network booting program and when it cannot find that, the error shows up. REPLACE YOUR HARD DISK,
Aug 01, 2014 | Toshiba Satellite Computers & Internet
Error Message PXE-MOF: Exiting Intel PXE ROM. what does this mean?
That means your hard disk is not being detected. PXE is a network boot, which is typically used in business environments. Check your BIOS settings and ensure your hard disk is being detected. If it is, make sure your boot order is set correctly. Network boot (PXE) should be set to the last item in the sequence. If the hard disk is properly being detected and an OS is present, you should never see PXE.
If your hard disk is not showing up, power your PC down (unplug the power) and check the cables to make sure they are seated.
Mar 17, 2013 | Acer TravelMate 5730-6204 Notebook
Wont go past first screen
First try this unplug from AC, remove battery, plug in try to boot normally. If that fails Open BIOS, Boot Order or the BOOT MENU, Boot from HDD first, and save changes and reboot, if that fails try a system restore/recovery.
Dec 09, 2012 | Toshiba Computers & Internet
I got a Toshiba Satellite A15-S1292 at a yard sale and immediately upon booting I received this message: IDE #0 ERROR Intel(R) Boot Agent FE v4.1.09 Copyright (C) 1997-2002, Intel...
Hi Jon.
Go into the BIOS confuguration by pressing the F2 key as the laptop starts up and set the BIOS to its default configuration. Save the changes by pressing the F10 key or save in the BIOS menu. The computer will restart so see if that has made any difference.
If you still get the same IDE #0 error then the hard drive is ready for failing. A replacement hard drive will not cost much at all.
Seeing as you have only spent $20 on the laptop in the first place you have got yourself a bargain there. Spend a liitle money on a new drive and OS then you could have a fully working laptop.
Regards.
Jun 07, 2011 | Computers & Internet
Booting problem, screen message: Intel (R) Boot Agent FE v4.1.18 Copyright (C) 1997-2005, Intel Corporation PXE-E61: Media test failure, check cable PXE-MOF: Exiting Intel Boot Agent. Operating...
HI there,
The "Error" texts saying:
Are completely normal. This simply states that there is no external cables plugged into the specialty inputs on your toshiba laptop.
The "operating system not found" is stating that your existing hard drive is either A) dead or B) been erased.
Try to re-install your operating system, if it finds no hard drive, you'll need a new one!
May 04, 2011 | Toshiba Satellite M105-S3041Notebook
Hi there, I have a Toshiba L510 and when I turn the on button ON: [Power key-this is the message that comes on after that TOSHIBA-leading innovation sign - Intel UNDI.PXE -2.1 (build 082) Copyright...
probably doing a network boot instead of booting from the harddrive. enter the BIOS make sure the harddrive is detected.Also check the boot configuration and verify if the harddrive is set as the primary or default boot.
Apr 01, 2011 | Toshiba Computers & Internet
My Toshiba Tecra 9100 gives me an error message of PXE-E61: Media test failer, check cable. Then it says PXE-MOF: Exiting Intel PXE.ROM. It's asking for a system disk, but this was given to me and I don't...
The error message is caused by a failed hard disk. Replace that then borrow a Windows install disk from a friend and install with it and the key on the sticker.
Mar 17, 2011 | Toshiba Tecra 9100 Laptops
My problem is I am getting this error whenever I boot my laptop "PXE-MOF:Exiting Intel PXE ROM. No bootable device -- inset boot disk and press any key -
you are getting this message because the boot sequenece is loading from PXE first, you can go into the BIOS and change the boot sequences order to hard drive first, CD Drive second and then PXE
Jan 05, 2011 | Toshiba Satellite C650DST2N02 Laptop
Toshiba TE2100 Notebook Logo
426 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
