My brand new Toshiba Satellite Pro..'s CD/DVD can't read any disk inserted in it. I can't send it back because I'm abroad now. can you help please ? Lot's of thanks
There is a registry tweek to remove an upper and lower bound reg keys ok the drive which will allow it to work. my drive did not work out of the box but after removing two registry keys it works fine! search google to find the satellite registry hack to fix the cd rom drive. again it involves deleting an upper and lower bound key in the registry. good luck!
Posted on Apr 11, 2008
6ya staff
SOURCE:
Toshiba satellite l505-s6946 not reading disks
Clean the cd/dvd with a laser lens cleaning kit. If that doesn't fix it then the cd/dvd drive will need to be replaced.
Jun 30, 2012 | Toshiba Computers & Internet
Have tried to completely restore laptop by running dvd recovery disks. Inserted disk 1 ,after a while got message "bootmgr missing" Any ideas?
There are corrupted files from the recovery disc which the computer cannot read. Use another recovery disc.
Hope this helps.
Jun 12, 2011 | Toshiba Satellite Pro L300 Notebook
CD DVD ROM doesnt read dvds when i insert the disk the light turns on i can hear the dvd turning but later on it stops. turn and stop again. then it doesnt read the dvd anymore
how long have you been using this CD ROM? I suspect the laser (lens) of the CD ROM. I think the laser (lens) is weak that's why it cannot read data/files on DVD.
To confirm if actually its a laser problem, insert an Audio CD into the CD ROM and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the CD ROM cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new CD ROM.
Good luck...........
Mar 18, 2011 | Toshiba 100GB Laptop for Satellite 2400,...
My Toshiba Satellite Pro, when I turn my laptop the screen comes on with Password= I forgot my password, how do I reset it?
The first question is - did you create a password recovery disk? If not you will have to re-install the operating system.
Your BIOS default will be set to start up from teh DVD drvie - insert the recovery disk and it will re-install the operating system.
Dec 18, 2010 | Toshiba Satellite Pro 6000 and 6100 14.1...
Trying to use Toshiba "recovery Disk creator"
u need a blank dvd, or tell the program your using regular cd, it will be like four dvd's or like 11 regular disks. in some cases it wont work with either, i have seen it where the program just doesnt know any disk is inserted or blank. if thats the case, update the program or contact toshiba
Sep 01, 2009 | Toshiba Satellite L305-S5907 Laptop
Toshiba sd-r2002 - won't recognize blank CD when trying to write files to a CD
right click on the drive.... go to properties... under tab recording, remove tick "enable CD recording on this drive" and press apply... after that tick "enable CD recording on this drive" and press OK.
It should work.
Jun 01, 2009 | Toshiba SD R2002 CD-RW/DVD-ROM Burner
Toshiba sd-r2002
I'm very late to your question, but the problem is that this drive doesn't burn DVDs (i.e., it was not designed to do that). It's a CD-RW, DVD-ROM (read only).
Apr 03, 2009 | Toshiba SD R2002 CD-RW/DVD-ROM Burner
Atapi dh20a4p problem
OK... see if this:
Toshiba Satellite Pro C50 Laptop Optical DVD Drive Bezel Assembly K000888950 will work for you?
See eBay: 272402441049
$20 NEW ~ Including shipping from Denver.
The ONE thing that does bother me about this Auction is the word "BEZEL"... is it just the BEZEL without the actual drive? Please MESSAGE the seller and ask!
Final note: Be VERY careful about DVD Drives that are listed as "NEW" (other) ... MOST times that decodes to USED!
Anthony
Toshiba Satellite Pro C50 Laptop Optical DVD Drive Bezel Assembly...
Nov 01, 2017 | Toshiba (K000816870) for Satellite 1100,...
Toshiba Satellite pro hl-dt-st dvdram gma-4082n
goto program defaults/media player/disc insertion= and choose the options you require. Or goto computer-cd/dvd drive and choose the program you wish to run the disc
Dec 10, 2007 | Toshiba Satellite A135 Notebook
Open Questions:
Computers & Internet Logo
51 people viewed this question
Ekse
Marvin
Marvin
