Question about HP Pavilion dv4000 Notebook
HP Laptop Low Memory
How can I fix my laptop where the not only is the memory is low, but the laptop itself is becoming very slow, and it skips time hours.
  • 520 Answers
For slow pc defrag or compress drive for memory update more ram or larger ram for time loss rtc battery needs to be replaced.
it looks like a large watch battery located on motherboard.
by removing battery it will also reset bios to factory set and wipe any passwords set
Posted on Apr 06, 2008
  • 77 Answers
Try changing your CMOS battery
    An expert who has answered 500 questions.
  • 674 Answers
Run System In Safe Mode: To identify the root cause of theproblem, first of all restart your system, press and hold F8 key. Do thefollowing once you are on the desktop. 1. Right click on Computer.
2. Select Manage.
3. Click on Event Viewer in computer management.
4. Double click on Application.
5. Check for the errors.
6. Similarly double click on System and check for the errors.
7. Search for the solution to this problem. Now you are able to easily diagnosewhy Windows laptop starts up very slow. b> Limit your Startup list: A long list of programs in startupcan adversely affect the performance of your PC. There are some programsrunning in the background without knowledge of user that causes Windows laptopto start slower. To solve the problem, follow the steps given below. 1. Click on Start button.
2. Type "msconfig" in search option.
3. Double click on the file.
4. Click on Startup.
5. Uncheck all unwanted programs.
6. Close system configuration utility.
7. You are done. b> Uninstall unwanted program: Sometimes Windows laptop starts upvery slow due to unwanted programs hogging your memory. To fix this problem,below are some steps. 1. Click on Start button on thetaskbar.
2. Go to Control Panel.
3. Double click on Add or Remove Programs.
4. In the list of programs, select the program that you no longer needed.
5. Click on Remove button.
6. Repeat step 4 for all unwanted programs.
7. You are done. b> Scan System for Viruses: Windows laptop may start slower due to any virus onyour computer. To solve this problem you should scan your system with somepowerful antivirus program. b> Run Disk Clean Up: Running disk clean up utility isalso helpful to resolve slow Windows start up. To run disk clean up utility,here are the steps given: 1. Click on Start button.
2. Go to All Programs.
3. Click on Accessories.
4. Now click on System tools.
5. Click on Disk clean up. b> Defrag hard disk: 1. Click on Start button.
2. Go to Command Prompt.
3. Type "chkdsk" and press Enter. b> Defrag Registry: You mayuse some safe program such as McAfee secured RegInOut to fix registry relatedissues.
Posted on Jul 11, 2011
How to resolve the memory low system
Hi Anon, this is Microsoft's answer to low memory messages, and I would only add the suggestion that you check for viruses and other unwanted programs hogging your computer's memory. How to prevent low memory problems Running fewer programs at one time can help prevent low memory problems and information loss. It's a good idea to observe which programs show signs of low memory conditions and try not to run them at the same time.
However, it's not always convenient or practical to run a limited number of programs. Signs of low memory can indicate that the computer needs more RAM to support the programs you use. Here are the recommended ways to solve or prevent low memory problems:
  • Increase the paging file (virtual memory) sizeWindows automatically attempts to increase the paging file size the first time your computer becomes low on memory, but you can also manually increase it up to a maximum size that is determined by the amount of RAM installed. Although increasing the paging file size can help prevent low memory problems, it can also make your programs run more slowly. Because your computer reads information from RAM much faster than from a hard disk (where the paging file is), making too much virtual memory available to programs will slow them down.
    For more information, see Change the size of virtual memory.
  • Install more RAM
    If you see signs of low memory, or if Windows warns you about a low memory problem, check the information that came with your computer or contact the computer manufacturer to determine which type of RAM is compatible with your computer, and then install more RAM. To install RAM, check the information provided by the manufacturer.
    For more information, see Find out how much RAM your computer has.
  • Determine if a program overuses memory
    If the computer becomes low on memory whenever you run certain programs, one or more of those programs might have a memory leak. To stop a memory leak, you need to close the program. To repair a memory leak, you need to check for updates for the program or contact the publisher of the software.
    To determine which program is using the most memory, follow these steps:
    1. Open Task Manager by right-clicking the taskbar, and then clicking Start Task Manager.
    2. Click the Processes tab.
    3. To sort programs by memory usage, click Memory (Private Working Set).
    You can also check for program errors and troubleshooting information using Event Viewer.
    1. Open Event Viewer by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg, clicking Control Panel, clicking System and Security, clickingAdministrative Tools, and then double-clicking Event Viewer. 18abb370-ac1e-4b6b-b663-e028a75bf05b_48.jpg If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
    2. In the left pane, click Applications and Services Logs to view error events. To see a description of the problem, double-click the event. To see if troubleshooting information is available, look for a link to online Help.
    For more information, see What information appears in event logs (Event Viewer)?
Top of page
Aug 10, 2014 | Acer Aspire E1-472G-6648 Misty Silver 14"...
I have a Dell D600 Latitude Laptop. After installing Microsoft Office 2007 and using One Note the system become too slow and displaying. 1) The command cannot be performed 2) "your system is...
Any error message displaying low virtual memory has to do with ram. try upgrading the sticks of ram. i upgraded to 1GB on my D400 and it worked like a charm. You probably don't have a virus but it would be a good idea to run a full scan on any virus software you have installed. Also do not format the Hardrive a lot because this could put it at risk of failing.
May 02, 2011 | Dell Latitude D600 Notebook
My acer laptop 4736Z's memeory dumping problem
HELLO..if you convert the memory and it is you experienced these problems may be the memory you bought is not compatible with laptop, can the FSB memory is high and the laptop is low and they do not match the FSB, or try to install a new OS / windows...GOOD DAY
Jul 28, 2009 | Acer Aspire 3690-2196 Notebook
Laptop overheating
ya overheating of a laptop is but normal as made by the maufacturer due to absence of power fans to cool down the heat from the power supply so for that reason just take it normal or else it could be due to other factors like memory being too low.for the idea of being too slow you will have to meet a technician to increase the capacity of your memory
Jun 22, 2009 | Computers & Internet
Sound is not working proprely and laptop has become very slow
my wife has the same laptop and this fixed hers the problem began after we restored it to factory default.the problem is in the ide controller.go to device manager unistall the primary ide controller restart reinstall it restart again and all should be well also try uninstalling and reinstalling memory controllers,
Apr 21, 2009 | Acer Aspire One Netbook 8.9" Notebook
Memory for HP Pavilion N5495 laptop computer
Your machine will support 2 of these for a total of 1gb of ram.
Note: Not my auction, just passing along info...
Apr 02, 2009 | HP Pavilion N5495 Notebook
My laptop has 256K memory installed. I purchased 512 RAM (max I can add is 1024) and installed it in my hp Pavilion zt1230 laptop. Per instructions, I cleaned gold leads with eraser and popped...
Is it a High Density memory? There are two different types of memory, High and Low. Low density is the universal but High density, may be cheaper but the motherboard needs to be compatible with High density memory. Although your memory fits in the slot, I think you have High density memory hence why it won't boot up and does when you remove the memory.
Dec 06, 2008 | Computers & Internet
Laptop is running slow
possible virus or trojan infection, too low on memory, not a lot of hard drive space left, low virtual memory.
Aug 31, 2008 | Gateway 7322GZ Notebook
My laptop keeps coming up with low memory!
Low memory usually refers to the RAM. Low space refers to the Hard Drive. You might have too many applications/programs running at the same time on your laptop. Or have an application or program that is using up too much memory. Viruses/Spyware sometimes do this to put your computer in a state that is not usable.
So what you can do is add more RAM. And check your "Task Manager" for applications and/or programs that is using too much RAM. Look under the column "Mem Usage"
Aug 17, 2008 | Toshiba Satellite A70-S249 Notebook
Virtual memory low
naz2172, Buying memory is always a good idea.
Buy as much as your laptop can handle, to eliminate your problem.
Feb 19, 2008 | Computers & Internet
HP Pavilion dv4000 Notebook Logo
215 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
