Question about Nintendo Wii Console
Multiple cds inserted into Wii at same time
My 3 year old has inserted 3 music cd's into the Wii it now won't eject them and is making a clicking noise when asking it to eject.
Can I get the cover off to get the cds out? or any other solution
  • 655 Answers
In CD's there is an emergency lock which you can open to come out the tray.
On the CD shutter you can see a very small hole in which you can only insert niddle or thin wire. Try to find out this.
  1. Make Power Off
  2. Take a hard thin wire or long niddle.
  3. Insert the niddle in the hole.
  4. Push it gently, press a lillbit harder when it stricks any thing inside.
If you notice that the door is opening then push more hard till you can pull the shutter out with your finger.
And dad don't be angry............:)) lol
If you don't find the emergency lock opener then you have only way to remove cover...
Thanks
Iqbal
Posted on Apr 06, 2008
Model p1 personal music center displays "Cd err 3" when playing CD, also cd won't eject.
Not sure of error code but usually to eject cd knock power off hold eject button at same time you turn power button on, workks for my on cds, computer drives ,etc
Dec 16, 2016 | Cars & Trucks
How do you import CDs into iTunes?
Copy music from a CD to iTunes by following these steps:
  1. Insert a music CD into your computer. Notice that iTunes opens automatically.
  2. In the list that appears, use the checkboxes to select or deselect the songs you want to import. Songs that are selected will be imported.
  3. After you've selected the songs you want to import, click the Import button. iTunes will begin copying the music from your CD to your iTunes music library.
  4. After the songs are imported, click the Eject Disk button.
  5. Select Library in the Source list to view all the music in your iTunes library, including the songs you just imported.
Of course, if you want to import CD to iPhone, you can also read this guide. How to Import CD to iPhone
Oct 08, 2015 | Audio Players & Recorders
Boss assembly three disk "stacker" won't eject CDs
Someone is going to have to open it up and LOOK to see if jammed, out of alignment or has damaged mechanism. Any of these can prevent the unit from working.
Dec 15, 2012 | Bose Wave music system Multi-CD Changer...
I have a 2001 Honda Crv, the cd player keeps ejecting CDs before it has the chance to load them. The radio works fine, and I gave tried burnt and original disc CDs. Can anyone suggest a solution?
Are these CDs that you burned yourself? Older CD players won't recognize the audio file format of this kind of recording, only the established file format that typical retail CDs have used for years. In recent years, CD players have been developed to recognize more file types than just the old format; but with an older player like you have in your car, it wouldn't recognize what you were trying to play, as if you put a DVD in. It balks, and spits it out. You can burn CDs with the correct file format, you just need the appropriate software or file translator.
Apr 14, 2012 | Car Audio & Video
My front loader reads disc error or unplayable no matter what disc I insert. It worked just fine for about 2 years. It doesn ot get heavy cd use, but everyday radio/alarm use.
To resolve this issue, try one or all of the following:
  • The Wave® music system is designed to play commercial CDs, CD-Rs, MP3-encoded CDS and CD-RWs. If your system has trouble playing MP3 CDs, make sure the discs were recorded with compatible formats. See Cannot play MP3 CDs
  • The system may not be able to play certain CD-RW discs. Playability is dependant on how the disc was recorded, including the format it was recorded in and the actual disc used for recording.
    Note: iTunes defaults to AAC as the encoding format. In order to use iTunes to make CDs that will play on the Wave® music system, you’ll need to change the format to MP3 How to Choose Import Options
  • Different brands of CD-Rs and CD-RWs use different materials which may affect the ability of a player to read them. If you are burning your own CD-Rs or CD-RWs, experiment with different brands of discs
  • If a commercial disc won’t play, check for scratches, fingerprints or other physical damage. Try the CD in another player. If it still won’t play, there may be a problem with the disc
  • Reset the system by disconnecting the power cord from the wall for one minute, then plug the system back in
Dec 05, 2009 | Bose Wave Radio
Inspiron 1525 DVD/CD drive problems
you have to use a cd/dvd lens cleaner. and then itll read all ur cds perfectly.
Aug 05, 2009 | Dell Inspiron 1525 Notebook
CDs get stuck in the slot of my mac mini---3 years old.
Ok, let's go through the options in case you have missed one. Command E, Open Finder and click eject button next too it's name, dragging the item to trash, press F12, or hitting eject on the keyboard. If none of those work make sure the drive is not just busy. Sometimes you have to wait a few seconds even after stopping the application. You can use Disk Utility in Applications/Utilities to eject a CD. Open Terminal and type drutil tray eject If that fails, in Terminal type drutil list and then look at the list and find the drive. Tyoe drutil tray eject 1 The 1 should be replace with whatever drive # you found in the list.
Aug 05, 2009 | Apple Mac mini G4 Desktop
Alpine CDE0-7826P Cd Player doesn't always work
If It dosent play burned cds its not an mp3 compatiable cd player as far as the other problem kinda seems like its time for a new cd player
Jun 14, 2009 | Alpine CDE-7826P
Error code 6 & error code 4
hi try first to insert a clean up CD, and test your Cd player with an original CD, if the problem persist , your laser sense is defficient you have to go to fix it to a specialist.
hope this helps you
sserpentio
May 21, 2008 | Clarion DXZ438R CD Player
Bose Wave Music Sys & 3 CD Changer
I have had a few of these come to my shop. The gears jump out of timing causing the cd lift to jam or become unalligned. The unit will probably have to be disassembled to get the CD out or have it serviced.
Dec 23, 2007 | Bose Wave music system Multi-CD Changer...
Nintendo Wii Console Logo
155 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
