Front load washer doesn't turn itself on when door closed and cycle picked
I load the washer, pick the cycle, close the door and push the 'on' switch. Nothing happens. I have to push on the bottom of the door to activate the switch to start the cycle. How can I access this switch and adjust it to activate when the door is closed?
First check the door if it is still properly aligned try to tightened first the two screw of the door sometimes it is loose align it, reset your machine, if it is still the same, now take a look on the rubber gasket attached to the shell cabinet, there is a big plastic clamp or a rounded wire with spring on the other end it is the gasket lock, pull it u can return it by reinserting it back, wire lock-just stretch it and put it back,after doing that-pull the gasket slowly,to your right the door lock is located, check if it is misaligned-difinitely no problem with your door lock it is a matter of alignment - happy washing
Posted on Apr 06, 2008
What does f26 mean
DOOR SWITCH ERROR
If the door has not been opened for 3 consecutive cycles or the door switch is open while the door is locked for more than 5 seconds.
Possible Causes/Procedure
-Door not opened during 3 consecutive cycles.
1. Open and close the door.
2. Verify CCU operation by running a Diagnostic Test or any cycle.
-Door switch open while door is locked.
1. Push the door and check if it is completely closed.
Thanks for using FixYa&^%$
Feb 27, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Bosch Nexxt 100 series washer wfmc1001uc
According to the manual, you have to:
1. Turn program selector to "off"
2. Turn selector to Drain or Spin
3. Press the start / pause
Wait until program ends.
Open door.
or
Press "start / pause" until the start / pause light flashes.
Jan 10, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washer smells like mildew after a load of wash, clothes smell.
Use a washer cleaner like AhFresh (all three tablets) with the tub clean cycle, no clothes in the washer. Now, only use 1 to a maximum of 2 tablespoons of HE laundry detergent per cycle. Due to low water consumption of these machines, you must adjust soap usage or odors will result. It may also help to leave door open for a hour or so after cycle is finished to allow inner tub to dry completely.
Jan 12, 2011 | LG WM-2277HW Front Load Washer
What is f26
DOOR SWITCH ERROR
Thanks for using FixYa$%^
Dec 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error f26
DOOR SWITCH ERROR
Thanks for using FixYa $%^&
Oct 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a Kenmore washer HE2 plus and F26 is flashing
DOOR SWITCH ERROR
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%%%%
May 14, 2010 | Kenmore HE2 Plus Front Load Washer
F-26 flashing
DOOR SWITCH ERROR
5 seconds.
Faulty door Switch or CCU board or door not closed during run cycle.
Starting Diagnostic Test and bypassing
the Service History Mode:
Execute this procedure with an empty drum. All
of the steps below must be done in sequence
in order to reach the Diagnostic Test. This
executes the automatic test but does not show
the error history.
Close the door.
Push POWER.
Select the CLEAN WASHER cycle.
Press EXTRA RINSE four times within
5 seconds.
Press EXTRA RINSE to advance to the
next step of the test procedure.
If the starting procedure fails, push
PAUSE/CANCEL, then repeat the starting
procedure.
Nov 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I'm getting an F26 code on a Kenmore Elite he5t front load washer
DOOR SWITCH ERROR
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
Oct 31, 2009 | Kenmore Elite 45986 Front Load Washer
Washer runs when timer dial turned though ON button not pushed
Problem solved by ourselves! It was NOT in the circuit board (brain) of the machine. It was NOT in the door locking assembly as others would lead us to believe. It WAS the on/off switch on the control panel--part number 22002560 - a $22.00 problem fix.
Jan 05, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune won;t rinse
Check latch mechanism for alignment. Often operation of machine loosens latch mechanism causing internal switch for "door open (or ajar)" preventing rinse or spin cycle. Opening and closing door presses latch mechanism closing internal switch allowing for continue processing to rinse or spin cycles.
Mar 24, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
128 people viewed this question
Top Washing Machines Experts
