Question about Sony Handycam CCD-TRV37 Camcorder
Icon The screen on my camera has a yellow flashing arrow pointing upward with a line underneath and there is a steady beeping sound. What is the problem and how can I fix it? My video 8 Sony Handycam CCD-F380E is displaying a triangle with a line directly underneath it and it flashes near the center of the eye view finder. While flashing it will not allow any playback functions. This product is not recognised as a valid product?!!? Hence being under a different product name to obtain access.
    Sergeant:
    Champion:
  • 319 Answers
The icon you see is "EJECT" tape. It shows there is a problem with unit but cannot be defined without having unit checked by a pro tech
Posted on Aug 01, 2008
  • Chris k Nov 18, 2015
    Hi, did you ever resolve this issue?
6ya staff
SOURCE:
When i turn my camera on there is a small yellow camera icon with an exclamation point beside it. Can you tell me what this is a code for?
That is a camera shake warning. Use a steady base to support the camera when taking the picture or use the flash.
Jul 06, 2010 | Fuji Finepix Z20fd Digital Camera
When I try to set the time on my intex 8110 I can set the time & when I leave it for 10 minutes it always goes to flashing 94. Is there something wrong with the pump or maybe it's possible I'm missing...
that sounds really weird. There is no code 94
Try locking it manualy
hold down arrow till beep
now hold up arroe till beep
now with quick pushes set desired hours of run with up arrow
now hold till beep on down arrow then hold down on up arrow till beep
the unit is now locked and should start it could take upwards of 10 minutes
If all else fails you can call intex with a valid receipt up to 2 years of purchase and they will replace it
Hope this helps
Jun 21, 2010 | Intex Automatic Salt Water System for ...
When turning on to vcr or camera, camera beeps repeatly
Sounds like the camera ATE THE TAPE will not eject,fastforward, or rewind.. This will need to be repaired , worse case a belt slipped or something got misalligned inside, I would recommend a camera shop so you can save the tape otherwise digging into this yourself could stirr up more issues in the long run. Please do be considerate of facts here that we cannot see your unit and this error is because the tape got ATE or something got jammed.
Thanks please do leave some feedback and ratings for your free answer today.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 29, 2010 | Sony Handycam DCR-HC14E Mini DV Digital...
I have a zr100 camcorder and I have a red flashing icon underneath the battery icon. It looks like a boat with a diagonal line through it with an arrow to the right of the line.
On page 24 of the manuel it shows the symbol that you mentioned below the battery symbol. It's labeled item 4. Which states "flashes in red when the lithium button battery is not installed, or when it needs replacing". I guess you need to check the lithium battery with a voltmeter to see if it's any good.
Dec 04, 2009 | Canon Video Cameras
What does the yello camera with the yello
I have an S1000fd and to get rid of the yellow camera icon with the exclamation mark next to it I pushed the button on the side of the flash to pop the flash up. Its a low light level indicator basically.
Aug 10, 2009 | Fuji FinePix S1000FD Digital Camera
Nikon D50 Flashes Err and clicks
hi..
This screen shows areas of the photo that are overexposed slightly.
It flashes them to help you.
You get to this screen by pressing the up or down arrows when displaying the pictures you have taken.
To change it just press the up arrow when the camera is showing the screen until you get a display without flashing.
Once you have done this the display will be steady.
If you get any other screen in future you may have accidently pressed the arrow again.
Just cycle thru the displays to get back to steady.
thank u
rate me!!
Jul 27, 2009 | Nikon D50 Digital Camera
MY NIKON D50 SCREEN HAS THE WHITE AREAS OF PICTURES FLASH BLACK AND WHITE
Jul 21, 2009 | Nikon D50 Digital Camera
Cannot record
it is a reel sensor problem...try to adjust the contact of the sensor at the main board sometimes it is a poor connection or poor solder...
Aug 26, 2007 | Sony Handycam DCR-PC105 Mini DV Digital...
Sony Handycam CCD-TRV37 Camcorder Logo
611 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Al Rush
Ekse
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
