How to fix excessive vibration during spine cycle?
If your machine is new, and you self installed it, you forgot to remove the shipping bolt, for front load-check the back there are four long screw sometime three depending on the brand , for top load tilt ur unit take a look on the bottom- in the middle again depending on the brand they use a single bolt to hold the tub during transporting- remove it, slide out the spacer it will be ok. now if your unit is some years back already you have your problem with its transmission or gearcase for top loader-quite difficult to fix it sir, or suspension mechanism and bearing on front loader sir- u have to replace it or call a qualified service tech - happy washing soon sir
Posted on Apr 06, 2008
SOURCE:
I have a Maytag LA 211 washer and during the spin cycle it vibrates excessively. I tested the spin cycle without clothes and water and it still vibrates excessively. how can this problem be fixed? Ron
To fix this problem you will need to replace the damper pads, this will require several hours of your time, you can read several articles on how to complete this repair yourself at the link below, let me know,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | Washing Machines
Excessive vibration during spin cycle
Plz check for the ground level is equal.weather its normal means u have to check the shock obsorber
Jun 06, 2010 | Maytag PAV2300 Top Load Washer
LG WM0642H washer "excessive" vibration
sounds like damper rods are getting worn. they support bowl underneath.i think if u change them it should fix problem. is it noisy during spin?if u need more help please reply. please turn power off b4 working on it do not want any accidents.
Apr 08, 2010 | LG WM0642H Front Load
On spine cycle washer thrashes around, hard thumps
Your load is probably unbalanced. Open and redistribute the garments or take some items out.
Mar 08, 2010 | Bosch WFMC 3200 Front Load Washer
Spining makes noise and machine vibrates a lot
its a simple solution just remove the brown colour clamp at the bottom of the machine with a screw driver
Jun 03, 2009 | Whirlpool Washing Machines
Chck to see that all (6) suspension springs are still attached. Check the plastic snubber ring below the mechanism and above the base plate for cracks or contamination.
Mar 07, 2009 | Maytag Performa PAV2200
The spin cycle for my
Dear shelldon39, Fri 2-20-2009 9:24pm EST (USA)
Some machines will shut down during the spin cycle as a precaution to prevent damage!
They will do this if you overload the washer with clothes and/or use too much detergent!
If this doesn't help please get back to me with more details!
jack
Feb 21, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Vibration during spin cycle
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
Dec 13, 2008 | LG WM2688HWM TROMM SteamWasher
sure..start by re leveling the unit, with a standard carpenters level.
Mar 02, 2008 | Maytag Atlantis MAV5000
Machine vibrates excessively during spin cycle
Open washer's cover and look for a released or a malfunction shock absorber. Good luck!
Nov 08, 2006 | Maytag MAV4755A Top Load Washer
Washing Machines Logo
870 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
