Question about Technics SL-1200MK2 Turntable
Not a good sound
I cant get very much sound, I think it might be on phono, how do I change it to line?
  • 515 Answers
You will need a phono pre-amp to connect it to the LINE level input on your receiver/amplifier.
The turntable requires a pre-amp, which is built in to all PHONO input jacks. However, newer receivers do not include a PHONO input, so when you try to connect to the regular LINE or AUX input, there is no pre-amp built-in to boos the signal for the turntable. Thus, causing a very low volume coming from your turntable. A phono pre-amp will correct this problem.
You can purchase one HERE.
TWEAK A/V LAB
www.DJPROLAB.com
Posted on Apr 10, 2008
You can't...the technics need to be pluged into phono..because the signal has to be amplified for it to play...phono channels on amps and dj mixers have an amp built in....
Posted on Apr 07, 2008
Kenwood turntable no sound?
Are you using a magnetic "PHONO" input on your amp/receiver, or just a line/aux input? The 'good' turntables from the 70's - 80's used magnetic catridges with a very low level output - you will need a phono preamp in order to hear the turntable. Only phonos (Crosly) that use ceramic catridges generate enough voltage without a preamp. Good luck and let me know if that answered your question.
Aug 10, 2014 | Technics SL-1210 Turntable
HELLO,RECENTLY BOUGHT A ROTEL 1500 TURNTABLE BUT WHEN PLUGGED IN TO MY AMP I NEED TO TURN VOLUME TO FULL TO GET ANY SOUND.Only thing i can think of is that the wiring is fualty is it easy enough to rewire?...
"PHONO" is the only designated connection on an audio device that is literal and exclusive. Nothing but PHONO will work right on it and old-school turntables would require it to preamplify the tiny current produced by a Phono cartridge.
If your unidentified amp doesn't have a PHONO connection AND your TT doesn't have a self-contained preamp you will have to get a Phono Preamp to connect between the TT and any Line Level input, like Aux.
eBay always has some...
http://shop.ebay.com/?_from=R40&_trksid=p3984.m570.l1311&_nkw=phono+preamp&_sacat=See-All-Categories
http://shop.ebay.com/i.html?_from=R40&_trksid=p3984.m570.l1313&_nkw=phono+preamp&_sacat=See-All-Categories
Jul 14, 2011 | Audio Players & Recorders
I have a LG 47 inch flatscreen.i cant find any audio output plugs to hook it up to surround sound.how are you supposed to hook it up.
this is from the LG website about that TV.
- Rear,
2 x Composite video/audio input (RCA phono x 3) - Side,
2 x S-Video input (4 pin mini-DIN),
1 x USB (4 pin USB Type A),
1 x Audio line-out (RCA phono x 2),
2 x Component video input (RCA phono x 3),
2 x Audio line-in (RCA phono x 2),
1 x Digital audio output (optical) (TOSLINK),
1 x Digital audio output (coaxial) (RCA phono),
3 x HDMI input (19 pin HDMI Type A),
1 x RGB input (15 pin HD D-Sub (HD-15)),
1 x Audio line-in (Mini-phone stereo 3.5 mm),
1 x Serial (9 pin D-Sub),
1 x Remote control (Mini-phone 3.5 mm)
Mar 20, 2011 | LG 47LC7DF 47 in. LCD HDTV
When setting up a sound card to my m4 numark 3 channel mixer do i have the switch to phono or line
"PHONO" is ONLY for an old school turntable that would require a PHONO preamp, so that leaves, uh, LINE.
It's more than a matter of gain as Phono cartridges require special equalization to restore flatness to the sound recorded in a vinyl groove.
Mar 17, 2011 | Nu Mark Numark Dm3050 3-Channel DJ Mixer...
When I turn on the record player on my Crosley, the digital display reads "line". No sound comes from the speakers unless they are turned all the way up. And then it sounds tinny and fuzzy. HELP!
Seems like the wrong input source has been selected. The gain on the LINE input is much, much lower than the PHONO input. Try changing the source knob to PHONO. Dont forget to lower the volume before you do this.
Jun 27, 2010 | Crosley CR248 Turntable
I can't get much sound from my tuner/receiver. I have tried all possible connections.
"Much" sound? What's that mean? Very low, almost silent, tinny?
"There is a switch on the bottom panel, next to the RCA cables, that selects between PHONO/LINE. Use PHONO level for
plugging into a turntable (PHONO) input on a home stereo. Use the LINE level for plugging into CD/AUX/TAPE inputs. WARNING: You
may damage your receiver if you plug in a LINE level into a PHONO input."
Apr 03, 2010 | ION Audio TTUSB10 Turntable
Hooked it up but sound is very low. Has a ground
Didi you try to change the middle. that was what was wrong with mine
Jan 13, 2010 | Audio Players & Recorders
I have a vestax qfo le and I'm only getting sound from one channel on the master out I have cleaned the headshell changed leads and I'm stuck. Does any one know of someone who could fix turntables in the...
Sam, I have a silver QFO and just recently I had problems with Phono/Line 1 where I lost sound but Phono/Line 2 (I use for IPod) was fine.
I took the fader out and cleaned it, checked wiring connections inside and tested and it was ok and I could use again..
Then during a skratch session, the Phono/Line 1 just lost sound again. If I turned my speakers and the QFO volume right up, I could hear very distorted sound.
I turned off by the power switch on the back of the QFO and turned on and I got a long hissing sound which died out. I still had no sound.
I turned off and back on and this time there was no hissing sound and Phono/Line 1 was ok.
Every time I get this problem now, I just turn off and back on a couple of times and the sound comes back.
I think it may be something to do with the sound control unit inside.
I know that this is not really a solution but your not alone with your problem.
I even had one of the feet fall off which I had to supa glu back together.
I have tried contacting Vestax but they wont reply.
I dont know about you but I was disappointed with the build quality of the QFO. Feels cheap and not your usual high quality Japan build.
I bet Q'Bert does not get any of these problems!!!!!!
Peace
Paul
Jul 01, 2009 | Audio Players & Recorders
Instruction manual for ministry of sound mixing decks
What are Ministry of Sound mixing decks? I am familiar with MOS, but was not aware they manufactured mixing decks?
Are you connecting these to a DJ mixer, or a Home Receiver?
If it's going through a home receiver, make sure you have them connected to the PHONO input on your receiver. If your receiver does not have a phono input, and you are connecting to the LINE IN or AUX IN section on the rear, you will not hear much. Most turntables require a pre-amplified signal, and only the PHONO input has this option. So, you will need to purchase a PHONO PRE-AMP, and connect your turntable to it, then connect the PHONO pre-amp to the LINE IN.
If you are connecting to a DJ mixer... same thing. Make sure you have them connected to the PHONO INPUT on the mixer. If you still don't get anything, then there might be something wrong with your mixer.
If you could clarify you exact set up, and the EXACT models, we can help you better.
- OPTiC
The Technics Expert
Technics Repair
DJ Equipment
Dec 27, 2008 | Technics SL-1210 Turntable
Rane Mixer ttm 54
in sound system you have different sound level start with phono level up to line level up to speaker level.-you will switch to phono when you connect phonograph and you will switch to line when you connect another audio source like dvd and video sound.
Sep 01, 2007 | Rane PE 17 Home Equalizer
Technics SL-1200MK2 Turntable Logo
275 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
