Question about Nokia 6300 Cellular Phone
Packet data how to activate packet data on mobile phone
    President:
  • 1,017 Answers
You need to get the Settings for Internet/Wap and MMS from your Network Service Provider. These settings are usually sent as a text msg. When you receive the msg. choose save or install on your phone. Or get the settings directly from their website. The MMS service doesn’t always work between networks.
"women should be obscene, but not heard. --groucho marx."
Posted on Apr 08, 2008
6ya staff
SOURCE:
Anonymous
SOURCE: packet data
please i am using nokia 2600c and i have being trying to activate free gprs but it is not working, rather it will be writting packet data connection not available or subscribe to packet data first and link not available i want you to send me the manual configuration setting now in my inbox or through sms in my phone my phone number 00267 71731903, using mascom
Posted on Apr 18, 2009
maniando
manikandan murthy
  • 129 Answers
SOURCE: register on facebook
hi there.you need to subscribe to Gprs first,this can be done by calling your network's helpline number.They will send you the settings after they have activated the Gprs.Make sure you save the settings and activate it as default.After that try facebook am sure it will work fine.kindly rate me if i had helped.
Posted on Jul 21, 2009
Anonymous
  • 265 Answers
SOURCE: packet data unavailable
WHICH SERVICE PROVIDER U USING. NY HOW U HAVE TO GET THE SETTINGS RIGHT FOR GPRS.SUMTIMES THE SETTINGS THAT SERVICE PROVIDER GIVES R NOT APPROPRIATE SO U CALL THE CUSTOMER CARE CENTR ND ASK THEM FOR MANUAL SETTINGS. AFTER GETTING YOUR SETTINGS DONE RESTART UR PHONE AFTER REMOVING BATTERY.
Posted on Aug 05, 2009
SALMAN NASEER
  • 1011 Answers
SOURCE: packet data
yes, you have to get it by you service provider...
can it done by them
Posted on Aug 16, 2009
newtonbomb
  • 37 Answers
SOURCE: cant access my 2go through
I believe that you need to call your network provider, and ask them to send you the settings for net browsing. They should send it in a text message. If not, they should be able to help you activate it.
Posted on May 19, 2011
How can i subscribed to packet data?
Packet data (EGPRS) Enhanced general packet radio service (EGPRS), packet data, is a network service ceive data over an Internet protocol which allows mobile phones to send and re (IP)-based network. It enables wireless access to data networks such as the Internet.77 . 2005 Nokia. All rights reserved © Copyright The applications that may use packet data are MMS, browsing sessions, Push to talk, e-mail, remote SyncML, Java application downloading, and the PC dial-up. Packet > Connectivity > Settings > Menu To define how to use the service, select Packet data connection > data . to set the packet data connection to be established when an When needed Select application needs it. The connection will be closed when the application is terminated. to set the phone to automatically connect to an packet data Always online Select network when it is switched on. indicates a packet data connection. Modem settings You can connect the phone using an IR or a data cable connection to a compatible PC, and use the phone as a modem to enable packet data connectivity from the PC. > Settings > Menu To define the settings for connections from the PC, select , activate Active access point > Packet data settings > Packet data > Connectivity Alias . Select Edit active access point the access point you want to use, and select , and enter a nick name for the currently selected access point. for access point , and enter the access point name (APN) to Packet data access point Select establish a connection to an EGPRS network. You can also set the dial-up service settings (access point name) on your PC using If you have set the 121 p. PC Suite the Nokia Modem Options software. See . settings both on the PC and on your phone, the PC settings are used.
Apr 14, 2011 | Nokia 6020 Cellular Phone
When i try to browse with my pc connected to my nokia 2630 via bluetooth, i get the message 'subscribe to service packet data first' and i do not know what to do.But i am able to browse on the phone.
first you need to have sufficient amount in your mobile.if you have then go to settings>connectivity>packet data>packet data settings>>edit active access pt
and type the respective APN given by the mobile operator.switch off and on your phone and see the internet will be connected
Sep 09, 2010 | Computers & Internet
What does arow below the network bar in N72 Nokia mobile means?
hi...
I wil tell you wh at arrow denotes what, so that you can check which is on your mobile phone
62cfaad.jpg:All calls are forwarded to another number
d0a9343.jpg:A GPRS packet data connection is available.
f18d117.jpg:A GPRS packet data connection is active.
3151984.jpgA GPRS packet data connection is on hold.
thanx
Jul 19, 2010 | Nokia N72 Cellular Phone
How to activate packet data connection of my n5630 expressmusic
    1. Call your customer center
    2. Tell the to activate packet data or GPRS function in your mobile
    3. Please tell your mobile phone number and phone model number
    4. and they will activate it
    5. after that you will get packet data settings in your phone
    6. Save it And restart your phone
    7. Then it is active and you can browse internet in your mobile phone
    8. Activation of packet data is a free service
    Jun 19, 2010 | Nokia Cell Phones
    How can i use my nokia 5200 as modem to connect internet.It only sats i should subscribe fo packet data first
    to connect to internet you must activate packet data it will be provided by network provider contact customber care to know more if you are using airtel you need to activate mobile office, sms (mo) to 56123
    if u like this plz leave me comment
    Mar 15, 2010 | Nokia 5200 Cellular Phone
    When i go to web page on my mobile and connect it it says packet data connection not available how do i get packet data connection
    To receive internet service on your mobile phone (called packet data service) you will need a data plan for your phone.
    Most cellular providers require that for data service to be available, the customer must request it to be activated on their phone.
    If you have already requested data service, contact your service provider and inform them that you are not receiving packet data for your phone.
    If you haven't yet requested to have internet service on your phone, you can call your cellular carrier and request that data service be activated on your phone.
    Your service provider may have several data plans available for your phone. Take a look at each plan carefully to see what it has to offer.
    If you found this information helpful, please give me a big thumbs up when you rate my answer.
    Feb 05, 2010 | Nokia 2600 Classic Cell Phone
    Packet data connection on 3110
    Packet data connection has to be activated on your mobile number. Request the service provider's helpline for this purpose and also as for the GPRS settings from them as they happen to be service provider specific.
    Nov 15, 2009 | Nokia 6300 Cellular Phone
    How to activate Packet Data of my n6300?
    contact your mobile service provider and tell them you want to activate the gprs and they will instruct you the next step and send you the settings
    Nov 19, 2008 | Nokia 6300 Cellular Phone
    everytime mu nokia 6300 i use internet , it asks "subscribe to packet data first . pls tell me how?
    Jul 24, 2008 | Nokia 6300 Cellular Phone
    GPRS RELATIVE
    Are the services subscribed to by your providers.
    May 14, 2008 | Nokia 2600
    Nokia 6300 Cellular Phone Logo
    151 people viewed this question
    Top Nokia Cell Phones Experts
    jonathan mariano
    jonathan mariano
    Ekse
    Damen Wong
    Damen Wong
