Question about Refrigerators
I need new parts for a Samsung cooltech Fridge door shelfs, top-crisper door, bottom container
    Scholar:
  • 178 Answers
Www.partstoday.com they will need the model number to be able tro search for the parts, enjoy.
Posted on Apr 06, 2008
SOURCE:
Can you remove doors on samsung sr-l626ev?
it may not be necessary to remove the doors
open the doors fully and slide the fridge sideways through any door , one open door first , fridge then second door
Jun 23, 2016 | Samsung CoolTech Plus / Basic Bottom Mount...
Crisper glass cover for Avanti fridge
have the local glass shop cut a new one for you
Dec 06, 2015 | Avanti FF8SSR Top Freezer Refrigerator
Amana fridge model number Arb1914cw is not cooling. Freezer is working fine
Bottom freezer fridges are especially susceptible to
  1. Dust build up on the condenser coil that impedes heat transfer to the outside from inside the box
    • Remove the (bottom) footplate by grasping outside edges and pulling/levering out and popping it free.
    • Use vac crevice attachment and coil brush to clean away all dust from the coil and foot plate.
    • Replace plate and allow 24 hours for inside temp to stabilize.
    • Adjust top temp setting if needed to maintain safe temp level.
    • Repeat semianually or annually as scheduled maintenance--depending on the dustiness is fridge's location.
  2. Airflow blockage through the crispers and meat keepers.
    • Remove crispers and meat keeper as well as glass cover shelf.
    • Find cooling passages between crispers and at midline of meat keeper.
    • Remove any buildup of air blocking debris.
    • Wipe up fridge box floor beneath meat keeper.
    • Reinstall glass shelf, meat keeper, and crispers.
    • Check perodically for poor temperature/moisture keeping in crispers and for water pooling on fridge box floor as signs of blocked air flow through criispers and meat keepers.
Mar 16, 2015 | Amana Refrigerators
Hi, i'm looking for a new 'veggie crisper box top shelf' about 13x17, and a 'bottom shelf' for the fridge door, Avanto Fridge Model# FF8SSR/FF8WR Cheers, Christian Lawson 6467846628
IF you go to Appliance Parts Depot and just put your brand along with your model number in the spaces provided then you should be able to order the parts you need your self. That away you can have them shipped to your house and not have to pay all the services fees that companies try to charge you for when they are going to do the same thing. Hope what info that i have gave to you is useful. If not you can email me at [email protected]
Jan 19, 2011 | Avanti FF8SSR Top Freezer Refrigerator
I have an LFRD25850SW Fridge. The bottom shelf above the crisper drawers has cracked at the left front and is causing the drawer to stick. I need to replace the shelf frame (glass is OK). Can you give a...
The shelf frame is cracked . It can be purchased if the part is still available from LG . I wouldn't hold out hope though because LG is notorious for discontinuing parts after 3 years. Find a parts supplier who has contact with LG parts to see if it's still available . I was able to order one for my customer back in the spring.
Oct 22, 2017 | LG LRFD22850 Bottom Freezer Refrigerator...
CONDENSATION ON BOTTOM SALAD CRISPER SHELF OF A WHIRLPOOL INTERGRATED FRIDGE
cold,damp air,condensates on warm shiny surfaces(bathroom mirror),try putting kitchen towel under the crisper...(why they put crispers on bottom of fridge instead of on top of the cooling coils at the top of the fridge ???)
Mar 29, 2010 | Refrigerators
Door to fridge is not clamping shut
if this is a top mount freezer, what can often happen to the fridge door is it gets bent from people leaning on it, and the bottom of the door rubs against the inside bottom of the fridge compartment, preventing the bottom of the door from sealing against the frame. you will have to remove both doors, and replace the lower hinge and any shims, washers pins that are there, tell your appliance parts store your model # and that you want all above. this will normally fix any problems.
if this is a side by side, or even a top mount as well, check also all crisper drawers, sometimes they arent firmly in correct position, and they obstruct the door. this is likely the culprit since you say it was not gradual. ive even seen some fridges that had food fallen behind a shelf, pushing it forward, and customers thought it was in place cuz they couldnt push it back any farther.
Feb 27, 2010 | KitchenAid Superba Architect KBCA06XPBS...
Broken shelf? help!
if it is the very bottom shelf then here is your part number 240354602.
if it one of the glass spill proof shelves here is your part number.240355211
Feb 09, 2010 | Frigidaire FRS3R5EMB Side by Side...
I am looking for the replacement parts for a Samsung Cooltech 330 litre fridge. It is the door shelves
Google search for parts for Samsung Cooltech 330.
You will probably find it there
Jul 03, 2008 | Samsung Refrigerators
Assistance required
A thermostat would have nothing to do with this problem. Condensation occurs when warm air moves into a cold place. Check door gaskets or any possible way that warm air is getting into the cabinet.
Nov 07, 2007 | Samsung CoolTech Plus / Basic Bottom Mount...
Refrigerators Logo
186 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
