Question about Sharp R-520LK Microwave Oven
Noisy magnatron Whenever the magnatron is operating, a very noticeable buzzing, vibration appears to emanate from the magnatron housing. It has become noticeably louder over the last few months. The unit still appears to cook properly but very noisily. Any ideas what could be cause the buzzing, vibration?
  • mikek9 Apr 26, 2008
    this unit is still under warrenty . it has been very noisy since we got it 5/14/07.
    now thier is no power at all. when you push the start button the light and timer come on but no power.
  • Sharp Master
  • 9,174 Answers
First of all, if you press against the right side of the outer cover of the oven, does that lessen the noise? If so, it may be that a rubber cushion on the side of the HV transformer has fallen off.
If it had that hum but was not heating, I would first check the HV rectifier diode.
But since it's cooking, I would say your magnetron is on the way out.
Unless the warranty is about to expire, I'd continue to use it and watch and wait.
Posted on Apr 08, 2008
SOURCE:
Speed queen noise when on spin
follow this test and fix it. God bless you
  1. MagnetronIf your microwave is emanating high pitched or growling noises during operation, the magnetron could be going bad. Normally a nearly silent part, the magnetron uses high voltage and induces the frequency required to cook food. Although normally not a safety hazard to operate, this is a sign that the magnetron is failing and will need to be replaced as soon as possible.
  2. Exhaust fan motorIf your microwave is making a very loud humming noise during operation, it could possibly be the exhaust fan motor. If defective the part will need to be replaced to silence the appliance once more.
  3. Stirrer motorAnother leading cause of a noisy microwave is an expired stirrer motor. With use this part becomes worn and makes a loud grinding noise, which is usually a leading indicator that the part needs to be replaced. The stirrer is a metal blade that is slowly turned by the motor. This action disperses the microwave energy in a random pattern, which heats the food evenly. If the stirrer motor is determined to be nearing expiration, it should be replaced to halt the grinding noise.
  4. Turntable motorA very common cause for a noisy microwave is a worn out turntable motor. This is a relatively easy repair and will put an end to the noise once replaced.
Nov 19, 2013 | Microwave Ovens
Microwave occasional loud buzz
make this test and fix it. God bless you
Nov 14, 2013 | Jenn-Air JMV8208AAS Microwave Oven
GE microwave occasionally buzzes loudly.
Nov 14, 2013 | Microwave Ovens
Buzzing noise
follow this steps and fix it. God bless you
Oct 23, 2013 | Panasonic Microwave Ovens
Sharp sound bar buzzing
test this steps and fix it. God bless you
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#13#ixzz2hVe8AHvJ
Oct 12, 2013 | Microwave Ovens
Buzzing noise
follow this instruction and fix it. God bless you
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#13#ixzz2ZYUSVYSH
Jul 19, 2013 | Morphy Richards AM925EF Microwave Oven
Gh5184xps3 microwave
this cause noise ; God bless you
  • MagnetronIf your microwave is emanating high pitched or growling noises during operation, the magnetron could be going bad. Normally a nearly silent part, the magnetron uses high voltage and induces the frequency required to cook food. Although normally not a safety hazard to operate, this is a sign that the magnetron is failing and will need to be replaced as soon as possible.
  • Exhaust fan motorIf your microwave is making a very loud humming noise during operation, it could possibly be the exhaust fan motor. If defective the part will need to be replaced to silence the appliance once more.
  • Stirrer motorAnother leading cause of a noisy microwave is an expired stirrer motor. With use this part becomes worn and makes a loud grinding noise, which is usually a leading indicator that the part needs to be replaced. The stirrer is a metal blade that is slowly turned by the motor. This action disperses the microwave energy in a random pattern, which heats the food evenly. If the stirrer motor is determined to be nearing expiration, it should be replaced to halt the grinding noise.
  • Turntable motorA very common cause for a noisy microwave is a worn out turntable motor. This is a relatively easy repair and will put an end to the noise once replace
  • Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#13#ixzz2ZPm395lp
    Jul 18, 2013 | Whirlpool Microwave Ovens
    Electrolux microwave buzzes and food doesn't heat up
    If the unit operates correctly except heating the food, then the unit needs a new magnetron.
    Aug 29, 2012 | Electrolux EI30BM55H Microwave Oven
    My microwave magnets keep cracking
    Have you checked out your waveguide and stirrer? Also ensure you have good connections & earths.
    Feb 04, 2010 | Kenmore 62622 Microwave Oven
    Kenmore microwave making loud buzzing sound.
    Mar 05, 2009 | Kenmore 62622 Microwave Oven
    Sharp R-520LK Microwave Oven Logo
    299 people viewed this question
    Top Sharp Microwave Ovens Experts
    William Miller
    William Miller
    Steve Allison
    Steve Allison
    Ekse
    Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
