Question about JVC AV-48WP74 48" Rear Projection HDTV-Ready Television
Won't power up and power button light flashes
My jvc av-48wp74 won't power up and the power light flashes. The speakers also make a thumping noise. I have already replaced and upgraded the stk's could this be a new problem? Maybe the power supply?
  • jvsee Apr 18, 2008
    I replaced the 110's with 150's and the tv worked great for about 2 years and now this. This time the tv has different symtoms than before.I guess I will check them again. Thanks
  • adolan2 Apr 21, 2008
    I was watching the TV and it went gray, I heard a repetitive clicking as if it was trying to power up then a thumping from the speakers. I replaced the convergence board a year ago, but the symptoms were completely different. At that time the TV would power on no problem but the convergence was off and could not be adjusted. Even though the symptoms are much different, you still think it is the convergence board?
    Problem Solver:
  • 8 Answers
When you replaced the convergence amps did you check and replace the resistors? it seems like they always take out two or more resistors. the problem is on the convergence board, i have the same tv that did the same thing. if the speakers are still thumping, you may have got a dud amp. i recommend using the factory stk392-110 amps. make sure all of your solder connections are good and none of them are touching. also, when you get the set back on you will need to manually adjust the convergence from the menu. you will need the factory remote. if you find bad resistors, the values are on them, but if you need the values and wattage, then use this page:
http://home.comcast.net/~dande76530/ConvergenceOutSchematiics.pdf
hope this helps you.
Posted on Apr 17, 2008
  • Rush Williamson
    Rush Williamson Apr 18, 2008
    this board is common too go bad as soon as once a year that iv seen. but i am positive with the symptoms you are describing that it is the convergence board. i own and operate a tv repair shop, and my personal tv is the same as yours, and done the same thing.
    best of luck to you
Power light blinks , no picture or sound , just the speakers pulsating.making a heartbeat sound.
Sounds like the TV needs some type of serivice. But just to cover your bases try unplunging it from the power from the wall and let it rest for about 5 minutes. Then plug it back in to the power and try to turn it on using the power button on TV rather then the remote. See if that works. If it doesnt call JVC.
Sep 13, 2010 | JVC AV-48WP74 48" Rear Projection...
JVC AV-48WP74 convergence
The ICs are most likely defective if the old ones allow the set to power up.
Nov 20, 2009 | JVC AV-48WP74 48" Rear Projection...
Ic location
they are located in the front of the TV behind the speaker grille. Remove the screws from behind that secure the speaker grille and the two inside the small door below the control buttons, Then you will see a small access panel remove that and the ICs are on the skinny board up front. Do not remove the rear panel on your model with the cord plugged in or it will destroy the HD circuits
May 29, 2009 | JVC AV-48WP74 48" Rear Projection...
Thumping
when I turn on my tv there is a black screen and a loud thumping noise.What do I do?
Jul 29, 2008 | JVC AV-48WP74 48" Rear Projection...
JVC AV-48WP74
it's worth about as much as you paid for it.
Mar 06, 2008 | JVC AV-48WP74 48" Rear Projection...
Blue light flashes
it is most likely the convergence panel. do your speakers make a thumping sound? if not, disregard this solution. change the stk392-110 convergence amps located behind the front cover on the convergence board. also check the resistors, it seems like they always take out two or more resistors. make sure all of your solder connections are good and none of them are touching. also, when you get the set back on you will need to manually adjust the convergence from the menu. you will need the factory remote. if you find bad resistors, the values are on them, but if you need the values and wattage, then use this page:
Feb 11, 2008 | JVC AV-48WP74 48" Rear Projection...
Flashing power light on JVC 48W TV
Tri to remove the concergence pcb assy and start the Tv.If the TV is working just replace the convergance IC.
No responce except thumping noise
PLEASE TRY TO CHANGE AGAIN THE CONVERGANCE IC'S
Oct 02, 2007 | JVC AV-48WP30 48" Rear Projection...
No Picture / No Sound
What was happening before can put you close to what when out. If you had color problems or sound, or even picture going small. these are symptoms that causes the set to go out. If color look in the convergence area and look for blown fuses and bad resistors. If just went out the look at horizontal output transistor.
Aug 24, 2007 | JVC AV-48WP74 48" Rear Projection...
JVC AV-48WP74 48" Rear Projection HDTV-Ready Television Logo
128 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
easy alberta
easy alberta
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
