Front Loader Wont Purge Water and enter Spin Cycle
I have a Hoover Zodiac 12 Front Loading Washing Machine. The machine works on washing Cycles but will not purge the water or enter the spin cylce and accordingly does not allow the door to be opened.
It is the drain pump, it is nt working due to lack of power entering its supply line or there is something stuck in the impeller,or its winding failed, u can check it by observing or wait till machine reach the drain cycle when you hear a humming sound during the drain cycle, you isolated already the supply to the drain pump it means the drain pump is working but there is something blocking the hose,impeller and or the pump motor is weak already. if so, call an authorized servicer or service fr the company to do the job, or if u want to fix it by yourslf, first lay down the hose of the machine at floor level, water will comes out, drain it,with that it means no problem with the water line from the tub of the machine to the drain hose, remove the back cover from there u can see the pump get a mechanical plier to remove the clamp,slide the pump or unscrew it if is installed that way then u can check now the pump physically, sometimes small pins is blocking the impeller if there is nothing and when you touch pump is so hot-it is electrically defective-the winding is weak or just what i have said earlier it is blocked or mechanically defective -replace the pump assy- u can order it -try www. repair clinic .com
Posted on Apr 06, 2008
6ya staff
SOURCE:
My Hoover 700 LA Top loading washer does not spin dry clothes after the was cycle ? The drum does not spin fast enough for the clothes to dry out as before.
Just got Hoover 700 la manual top loader 2. hand...it is taking maximum amount of water on low arrange, and takes an hour on delicates. it also spin dries very strongly, just ruined my clothes..what you would suggest folks..
cheers aysh
Jul 06, 2012 | Washing Machines
Hoover 750L top loader washing machine
The load might be unbalanced, and will not spin at full speed as it could damage the machine. Try reloading the machine
Goodluck,
Dont forget to rate me as Fixya..
Jan 30, 2008 | Hoover Nextra HNF 3167 Top Load Washer
Hi, My Hoover 600MB top loading washing machine is approx 8 years old. Recently it has occassionally not fully spun out - clothes still wet at end of cycle. Now it also often doesn't agitate - just...
Have a look for coins etc stuck in the drain pump or the tub outlet hoses especially where they fit onto the tub. If a coin or other foreign material blocks the water flow when draining , these machines wont spin properly.
Jul 26, 2011 | Hoover Washing Machines
I have a Hoover washing machine, its a front loader, I don't have the exact model in front me at the moment. I recently moved house, and yesterday after re-plumbing my washing machine, I put the washing...
If water remains in the drum after the drain cycle, the unit will not go into the spin cycle. There may be a couple of reasons for your problem.
Make sure the drain hose is raised above the machine hose outlet to create a siphon effect. The drain hose needs to have a loop in it to work correctly. You can tie a string around the hose and hook it on the water valve creating a loop in the hose. Raise the loop of the drain hose so the top of the loop height is at the center of the washer drum.
Apr 06, 2010 | Hoover AI130 Front Load Washer
Hoover Zodiac 12 that won't spin.
possible filter blockage, or the pump has failed/seized, machine CANNOT spin while it CONTAINS WATER, the door interlock will not open for the same reason,WATER in drum.
manually drain excess water into a bowl now
1 clean filter, 2 check pump for objects that prevent impeller working may still need pump if seized
Jun 12, 2009 | Washing Machines
Ca230 w. machine not spinning leaving clothe wet, no water in drm
It is possible that the belt at the back of the machine is slipping. try running the spin cycle without any load in the machine. I assume this is a front loading machine and you are in UK. the Belt is available on line for about 15 pounds.
If it is running the washing cycles normally, it can't be the motor.
Dec 06, 2017 | GE S8000E
Maytag top loader washing machine
i believe i can help you,,but washers dont agitate in the spin cycle,,i believe you ment it wont wring or spin in the spin cycle..your lid switch is defective,,replace,,if need be i can talk you though,,onthejob
Dec 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
136 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
