Question about Refrigerators
My fridge causes the main board to trip. I have tried plugging into different sockets around the house but the same thing keeps happening.
  • 1,550 Answers
Quizas la compresora esta en corto y esa es la causa de tu problema.
Posted on Apr 06, 2008
Fridge keeps tripping the house surge protector switch what would cause this temp curcuit board has been replaced but it still trips the switch
there is a problem in the wiring insulation of the fridge or moisture in an electrical control of the fridge
get an electrician in to check it out
Feb 17, 2016 | Refrigerators
Fridge/freezer keeps tripping
Try to plug into different circuit, if it trips that breaker on the board then the appliance is probably at fault.
I must assume that you have not acquired something plugged into the same circuit as the fridge.
Sep 26, 2017 | Beko Refrigerators
Dryer keeps shorting electrics
In a situation like yours, either the terminal block has burnt and the hot lines have arced over blowing the breaker or a wire has burnt in have causing a short. In either situation this a very serious issue and a proffesional should be contacted.
Apr 25, 2012 | Hotpoint Dryers
The fridge shut off and tripped the breaker, tried to reset breaker and it tripped again. I unplugged fridge, breaker was able to reset, voltage good at outlet, ohmed out fridge plug, appears to have a...
Could be anything, bad cord or plug, possible bad appliance bulb causing short (had that happen on another appliance) or the main problem, bad compressor.
Sep 05, 2010 | Refrigerators
My superba refrigerator recently keeps tripping off the power. I tried swithing to a different outlet but it didn't work (same problem). What is causing this?
well usually several plugs are on the same breaker and just because u use a different plug dont mean u r using another breaker try replacing the breaker and see if this cures the problem breakers sometimes get weak and trip when they need replacing but make sure u put in the same size if it still does it then u have something overamping because of being dirty or clogged up around the fridge or behind it or under it make sure its clean all around and try unplugging a couple of things on the outlets and see if it stops tripping
Mar 01, 2010 | KitchenAid Superba Architect KSCS25IN Side...
Washing machine trips electric when fills with water
From the symptons described, I would suspect that the heating element is faulty, disconnect the heater, and try it again, if it does not trip, then replace heater.
Please rate my solution.
Aug 15, 2009 | Washing Machines
Fridge keeps tripping the circuit breaker
Unless there is a dedicated circuit of 20 amps to the refrigerator this will continue to happen When your refrigerator goes into defrost and other things like lights fans air conditioners are on the same circuit it will have no choice to not trip the breaker. Try this turn the breaker off and how may thing in your house stop working? You need a 20 AMP circuit or this will possibly damage the compressor or weaken the breaker because it has tripped so many time. Thanks, Please rate my solution, I have done this work for 30 years. Thanks, Sea Breeze
If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
Jul 10, 2009 | Whirlpool ES5FHAXS Side by Side...
When I plug in my refrigerator, it throws my circuit breaker?
You may have a seized compressor, evaporator or condenser fan - have you tried turning it off first, plugging it in and seeing if that will hold? If you open the doors with the fridge off, will the lights still work? Can you hear the compressor start up when you turn the fridge on, or does it trip right then?
Mar 13, 2009 | Frigidaire FRS26R4A Side by Side...
Washing machine keeps tripping electric switch
there is a few things that will do this to your electics 1st & formost if your trip switch is tripping off remember this is a safty device to prevent fire so ignoring the problem & switching the power back on to try again could run the risk of fire!!
when the power trips you will need to know at what point in the wash this happens if its when the machine is emptying then it would be a pump issue if the machine is emptying no problem then the issue is more likely to be the motor either of which would need to be replaced if you are having these problems.
on rare ocasions you can spring a leak & if water gets on the electrics this will also trip the power but this is 1 of the least likely posabilatys.. rest assured if the power is tripping off then your home electrics are working fine & to confirm all sockets run from 1 main fuse all lights run from a second main fuse then there is a few other bits that run on there on fuses too i.e. cooker, power shower etc.. remember always get a qualified electrician to work on your electrics to ensure the job is carried out correctly
Hope this helps
Jan 16, 2008 | Washing Machines
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
