Question about RIM BlackBerry Pearl 8100
When I'd switched on my Palm Z22, I'd realised that it needed charging, but I'd ignored it and tried to get more life out of it. Now when Itry to use it none of the buttons are responding, and when I try to use the stylus, there isn't any response either. The devise is switched on , but the picture is frozen
I have thproblem with My Dell Axim.
I swear it has something to do with the lock button on the side of the Dell Axim. When I play with that it seems to unlock itself and I'm back to using it. Maybe it just needs a good cleaning????
Posted on Jul 29, 2008
I have a Palm z22 that won't keep a charge. My
The Palm Z22 is, I have found out, a bullet-proof design in regards to reliably keeping your valuable "DATA" safe over time. The Engineers at PALM really did a good job of Data integrity compared to many other devices. HOWEVER -- there are 3 common problems with the growing AGE of the Z22, 2 are with the dying batteries, and 1 with the years of wear and tear on the touch screen. The battery is a typical square, thin, modern Lithium battery, wired in with two wires ( + positive, red, and - negative, black ) that can be
taken out and replaced if you take the unit apart. In a brand new, in-the-box package, the battery is dying simply from old age. If the Z22 was used heavily, the constant cycling from dead to fully charged wears out the battery even more. The Touchscreen is a thin layer of plastic stretched over a sheet of glass, with a tiny air gap in between. Over time, the top plastic layer deforms - with hot and cold, air pressure changes, and being pressed by wearing the unit in a pocket, purse, briefcase, or even in a drawer with pencils, pens, and staplers etc. It is very important to have a hard cover over the screen! Other than just having the battery loose its weak charge continually, there is a problem with the unit getting into a state of BLACK SCREEN - it does not charge and remains "apparently" dead, since the logic circuits are in an invalid state, and it can only be reset if the battery dies COMPLETELY to remove the power on the logic circuits.
I have covered the topics of the battery problems, the data problems, the screen problems, and the disassembly, maintenance, and security, and how to get data off the unit, particularly to the new Windows Operating Systems that were developed AFTER the Z22 was no longer made. This is at
kidbots.com/WEBADD/Z22_PALM_PILOT/Z22_PALM_PILOT.html
I have ripped apart the Z22 repeatedly, and posted pictures of the various steps to service these units. There are links to aftermarket software to transfer data, and examples of how to USE the Z22, for valid purposes. This should be a one-stop source for any information or troublehooting the Z22, for those who have the Z22 and want to keep it operating!
good luck
robin dusty graves
Z22 PALM PILOT
palm-z22-keep-charge#solution-section-jquljdhkw5zrsfvn5uli2qb2-3-0.jpg palm-z22-keep-charge#solution-section-jquljdhkw5zrsfvn5uli2qb2-3-1.jpg palm-z22-keep-charge#solution-section-jquljdhkw5zrsfvn5uli2qb2-3-3.jpg palm-z22-keep-charge#solution-section-jquljdhkw5zrsfvn5uli2qb2-3-6.jpg palm-z22-keep-charge#solution-section-jquljdhkw5zrsfvn5uli2qb2-3-10.jpg
Mar 09, 2010 | Palm Z22 Handheld
Can we charge Z22 handheld through PC??
Sometimes if you plug them in to the hot sync cable they will charge. This works for my TX however I am not sure about the Z22. I am including a link to the palm free chat service. Normal 0 Scroll to the bottom of the page and you will see a Palm Chat. From there click on the link that says Chat Now and follow the online prompts. Best wishes...I hope this will help you.
They can answer that questions for you there. I have used the free chat service and it worked great for me. Best wishes.
http://kb.palm.com/wps/portal/kb/na/zire/z22/unlocked/supportservices/page_en.html
Nov 13, 2009 | Palm Z22 Handheld
My z22 Palm will not keep a charge and after a day
The battery needs to be replaced. They are sold on Ebay but if you need to do any kind of soldering then the best bet is to take it in and have it done by an authorized repair. It is worth the little extra you will pay.
Best wishes.
Oct 12, 2009 | Palm Z22 Handheld
Can I get my z22 repaired?
actually palm does not want u to change the batt they want u to buy a new device from them but u can do it
first check the charger voltage thru volt meter or confirm from other ways that ur charger is working fine , i am pretty sure that ur battery is Dead and it is difficult to replace but can be done if u have little expertise becoz Palm does not want u to replace the batt they want u to buy a new one when the batt is dead but u can do it thru following procedure
First check the specs on batt by taking it iut like this
How to Replace the Battery on a Palm Z22
The Palm Z22 is powered by a rechargeable lithium-ion battery which, in theory, can be recharged an infinite number of times. In practice, however, the lifespan of a rechargeable battery is finite. Replacing the battery yourself is possible if you have some skill with tools and a bit of patience.
Instructions
Difficulty: Moderate
Things You’ll Need:
* Star-bit screwdriver
* New z22 battery
* Palm z22
What to Do
Step1
Pull down on the back cover of your Palm Z22, and remove the cover from the device.there is a trick to it. The little translucent bezel surrounding the USB connector can be snapped out, revealing two T-5 (Torx) screws. Remove the bezel and the two screws and the other three sides will separate with some gentle prying as you have already discovered.
The best way to remove the bezel seems to be to slip a knife (or a thin fingernail) into the joint closest to the display. It's a tight fit but you don't have to separate it very far to get it to pop out.
The battery is not "user replaceable" - i.e. it is soldered in place, but you can buy one online if you're prepared to do the solder work.
Step2
Loosen and remove the screws from the Z22's casing using a star-bit screwdriver.
Step3
If there are tabs present on the circuit board, you will need to stop immediately. Consult with a technician about removing the tabs.
Step4
Find the battery. Move it out of the case so you can have better access to the power supply lead.
Step5
Pull the power supply lead from the battery. Grasp the base of the plug firmly and disconnect in one smooth motion.
Step6
Remove the old battery from the case and insert the new battery into the same position and with the same orientation.
Step7
Replace the rear cover on the Z22 and charge the new battery for at least four hours before use.
Tips & Warnings
* Use firm steady pressure to open the case. Sharp blows and delicate electronics do not mix.
* A star-bit screwdriver is not the same as a Phillips screwdriver. The star-bit has a six-flanged head which looks a little like an asterisk when viewed head-on.
* If your battery has a blue casing on it, do not attempt to change the battery.
How to Buy a Replacement Battery for a Palm Z22
The Palm Z22 is powered by a rechargeable lithium-ion battery. This means that you can use it forever, right? Well, no, because even rechargeable batteries wear out eventually. Since Palm currently does not offer replacement batteries, you will have to track one down yourself. Here is how to buy a replacement battery for a Palm Z22.
Instructions
Difficulty: Moderately Easy
Things You’ll Need:
* Palm Z22
Step1
Write down the technical specifications of the Palm Z22 battery. The battery is 3.7 volts and delivers 950 mAH.
Step2
Shop at your favorite local retailer, electronics store or battery specialty store. Take advantage of the sales staff’s knowledge in your hunt for a battery that is compatible with the Z22. Bring your Palm Z22 to the store to be sure that the battery fits.
Step3
Search for an online retailer who carries the Z22 replacement battery. Once you have found a couple of vendors that have the goods, shop for the best deal. Remember to include shipping costs into your decision.
Step4
Get information about return policies or money-back guarantees before shelling out any money. Returns may not be an option for the Z22 replacement battery due to the specific complications involved with lithium-ion rechargeable batteries.
Tips & Warnings
* You will need a tool kit to change your battery. The screws on a Palm Z22 require a star-bit screwdriver to loosen the shell.
* Correct use of your battery charger will prolong the life of your batteries, whether the original issue or replacement.
* Be sure that your batter is compatible. You don’t want to fry the Z22 with a high-powered, incompatible battery.
Mar 16, 2009 | Palm Z22 Handheld
Time change killed palm
If thatn doesn't work, put your palm aside for a week allowing battery to completely drain. Repeat procedure after a full charge. If this is helpful please post as such.
Mar 08, 2009 | Palm Z22 Handheld
I just bought a palm Z22 PDA. I used the AC charger to charge the Z22 but when I attempted to attach the USB synch cable I noticed that the plug is different from the plug on the AC charger. The USB...
I have concluded that the USB synch cable is not the correct one for my Palm Z22 PDA. There is only one point of attachment on the PDA and it is different from the plug on the USB synch chord. This was the last Palm Z22 PDA in the store so I think that the store clerk rounded up leftover parts and components of previous PDA kits and tried to make a complete set out of it. I am going to return the PDA to the store (Staples) in the next day or two.
Thanks for your offer of help. I will contact you again in the future if I need help.
Oct 15, 2008 | Palm Z22 Handheld
Won't turn on
The battery must be toast. Look on eBay to get a replacement.
Mar 08, 2008 | Palm Z22 Handheld
Palm Z22 will not turn on
I had this problem in the very beginning and a few times after. What worked is the following.
Put it to charge for at least half an hour. You won't see it is charging or anything.
Then, while connected to the charger, press the reset button.
Have you guys tried it like this already?
Feb 02, 2008 | Palm Z22 Handheld
My palm Z22 froze
I have the same problem. I fixed it the first time by rebooting from the back of the palm and plugging it in to charge. Not sure if it needed charged or not but it worked. I am having the same problem today though and know it doesn't need charged so not sure if this is a true fix but got me back up and running the first time.
Sep 14, 2007 | Palm Z22 Handheld
RIM BlackBerry  Pearl  8100 Logo
29 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
ismael castillo
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
