Question about RIM BlackBerry Pearl 8100
My personal organizer palm z22, I thought it might have needed charging, but I'd tried to get more out of it, then I'd tried to press the buttons and use the stylus to tap and get some reaction.the with no hope but picture was frozen.
  • pensyface Apr 06, 2008
    Thank you for trying, but there is no battery or memory card on the Palm Z22, please find another solution, cos the picture is still frozen.
    Thank you for your solution but my Palm Z22 haven't got a removable battery or a memory card, your solution haven't worked
    Genius:
  • 1,447 Answers
Sounds like having a bad battery... remove the battery and the memory card. then reinstall then hook palm to power surge then let it charge for awhile and turn it back on.. hope this helps...
Posted on Apr 06, 2008
Can not get the device to turn on
There should be a pin hole on the back of the PDA. Press the hole using a thin paper click. This will RESET your PDA. Press the power button and it will work OK. All PDA's have a RESET option.
Jun 01, 2015 | Palm z22 32mb handheld pda organizer z22-b
I bought a used Palm z22, the previous owner didn't clear out their password. How can I clear it so I can use
Press and hold the power button through out.
While holding the power button use the stylus or similar item to press the reset button on the back of the Z22.
Keep the power button pressed until you see the Palm logo appear.
Let go and hopefully this will reset everything, although it is not guaranteed to reset the password.
If it all works and resets everything, you should be able to set the Z22 as you want from now.
Jan 26, 2015 | Palm Computers & Internet
I have just bought a replacment Z22 tried to hot sync fom PC and it closed the Z22 down and will not come back to life why?
HI,
I had the same problem with my Palm TX. What I did was to first make sure I had the most up to date desktop software. I got this from Palm.com. I found that I did have the most recent software version so my next step was to do a hard reset on my palm. Make sure you have all your information backed up on your computer before doing the hard reset! To do the hard reset here are the steps:
  1. Press and hold the Power (on/off) button on the front panel of your device.
  2. While holding Power, use an unfolded paper clip, or the reset tool at the tip of your stylus. Gently press and release the RESET button inside the hole on the back panel of your device (where's the reset hole?).
  3. If you see a progress bar (see below), keep holding the Power button.
  4. Next, the Palm Powered screen will appear. Release the Power button when you see it.
  5. You'll see a screen that asks: Erase all data? YES = "up" button NO = any other button. Press UP on your 5-way navigator to complete the hard reset.
After you do this try the HotSync. Your z22 should sync with all the info from your computer. Best wishes.
Aug 24, 2009 | Palm Z22 Handheld
Palm z22-Touchscreen wont work
The Palm Z22 is a very solidly designed device to reliably store your personal data, however, it is subject to 3 failure mechanisms, all related to its AGE of over a decade of use. The batteries are all dying - even in an UNOPENED, sealed, "AS-NEW" package, the battery is almost dead. The TOUCH SCREEN is a delicate stretched layer of plastic on top of a layer of glass. The top layer bends down a touches the glass layer, and invisible layers of "wiring", electro-deposited on the layers, touch each other. Over time, with air-pressure changes, heat and cold, and mostly objects pressing on the screen (such as carrying it in a pocket, purse, briefcase, or even leaving it in a drawer with pencils, paper, pens, staplers, etc.) , the top plastic layer deforms and touches the bottom layer, which renders the touch screen dead.
My page on the Z22 is at :
kidbots.com/WEBADD/Z22_PALM_PILOT/Z22_PALM_PILOT.html
and has tips and tricks on temporarily getting your screen working, as well as how to replace it yourself - $9 U.S. free shipping from China.
I hope that this helps you get your Z22 up and running again, and helps you to keep it functioning.
good luck
robin dusty graves
Z22 PALM PILOT palm-z22-touchscreen-wont-work-ngl0e1lc0ft3j10pmz4xzklk-1-0.jpg palm-z22-touchscreen-wont-work-ngl0e1lc0ft3j10pmz4xzklk-1-1.jpg palm-z22-touchscreen-wont-work-ngl0e1lc0ft3j10pmz4xzklk-1-3.jpg palm-z22-touchscreen-wont-work-ngl0e1lc0ft3j10pmz4xzklk-1-6.jpg
Aug 06, 2009 | Palm Z22 Handheld
Palm Z22 will not turn on and I don't know where to reset.
the reset button should be located on the back to the bottom right of the label.
have a look at this link.
http://www.palm.com/us/images/support/kb/articles/30113_z22.gif
May 26, 2009 | Palm Z22 Handheld
Palm zire z22 went dead
while pressing the up button on the front, press the reset button on the back. if the Palm screen comes up allow it to reset, then plug it in to charge. I found this instruction for a "soft reset" online.
Mar 12, 2009 | Palm Z22 Handheld
I want to delete all information from my Palm Z22
do a hard reset...press and hold on/of button while simultaneously pushing reset button on back. Keep on/off button held in until Palm Powered screen appears.
Mar 04, 2009 | Palm Z22 Handheld
Won't turn on
The battery must be toast. Look on eBay to get a replacement.
Mar 08, 2008 | Palm Z22 Handheld
I had this problem in the very beginning and a few times after. What worked is the following.
Put it to charge for at least half an hour. You won't see it is charging or anything.
Then, while connected to the charger, press the reset button.
Have you guys tried it like this already?
Feb 02, 2008 | Palm Z22 Handheld
Palm Z22
Just had to do a hard reset myself and it's not straight forward! While holding down the power button, BRIEFLY press the reset button on the back of the palm. DO NOT RELEASE the POWER button until you see the GRAY screen with the Palm logo (not the first screen with the palm logo). That should start the hard reset for you.
Aug 19, 2007 | Palm Z22 Handheld
RIM BlackBerry  Pearl  8100 Logo
21 people viewed this question
Top RIM Computers & Internet Experts
Andrew Wright
Trisha
Trisha
Nataly Roberts
Nataly Roberts
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
