Question about Philips HTS3450 System
Philips HTS3450 System Problem buzzing/clicking sound on startup. Now nothing.
I have the Philips HTS3450 DVD home theater system. I have had it for over a year now, and love it, except.... In the past couple of moths we recently moved. After hooking up the system exactly like it was premove, I get a clicking sound that starts out spaced apart, and progressivly gets closer, and closer, until it becomes one high pitched sound from all my speakers. It reminds me of some kinda of warming up sequance. It started out rather quickly, and over the past few months has gotten longer and slower. There is no sound until it goes through this routine. once its done, all is well, until.... Today, no clicking, no progression to a high pitch union. Nothing. So now I have no sound what so ever. I have double, and tripled checked all connections. Recycled the power several times. Double and tripled checked all settings too. I do not know what could be wrong....
  • 7 more comments
  • wmhechler Apr 06, 2008
    Since posting this message, I have Googled and looked elsewhere for an answer. I have found many a post of the same issue, but have yet to read a solution.
  • LAMPRO Aug 03, 2008
    Yeah I have the same problem.. Ive been turning the unit on after being off all night, and then i hear this static and noise coming from the speakers sort of like how the apr 6 post does. It happened a bunch of times, and i wea sable to click thorugh sources till it went to TV and finally some sound came out. But last night, it sorta took longer than usual (the static noise to go away) and then like apr 6 post, NO sound at all.. switching wires, cycling power, speaker swaps, nothing workd. Im going to radio shack to swap out those capacitors and hopefully it will work. any chance of getting some pics of this replacement.. maybe a DIY? Takinng apart the subwoofer? need some guidance through that..
    Thatd help alot.
  • johnvalley Nov 02, 2008
    Well, I Had the same problem. But with a few solders and a trip to Radio Shack (Both very easy) complete success!! Thanks a bunch!!
  • Anonymous Nov 12, 2008
    Same exact problem has anyone fixed this yet, if so how?
  • tmvitelli Mar 05, 2009
    Can someone provide step by step instructions for this correction...?
  • D Stella Aug 15, 2012
    +1 for the fix! <$20 (soldering tool, solder, and capacitors) and the system is back to where it was when I bought it. No more squealing, popping, or cracking! Thanks WheatService!
  • Richard Allen McDaniel
    Richard Allen McDaniel Feb 03, 2018
    Can anyone elaborate on this repair? My unit is doing exactly this, I opened the back of the sub woofer and there are quite a few capacitors among other things. This is not my specialty in work but I am pretty handy and can handle the repair as long as know what I am repairing. Thank you
  • Larry Feb 04, 2018
    This unit is made by Funai in China and is full of grade 4 and 5 capacitors that break down in time (capacitors are graded from 1 (best)to 5(worst) and this is what is causing your issues, Ive repaired several of these and Ive replaced all the electrolytic capacitors in the power supply section and the output section...think there were about a dozen of them, you can order capacitors from the link at the bottom (capacitor world), just match your size and voltage and order what you need, as you will see most are around a quarter each, for under 10 bucks with shipping can have things working like they should...you will need some basic soldering skills and equipment however
    Forgot the link http://www.capacitorworld.net/product/el...
  • 20 Answers
As I found somewhere on the internet; there are two 470uF/25V capacitors on the power supply board in the sub-woofer that are the cause of buzzing, crackling and then eventually no sound. Go to Radio Shack and buy two Catalog #: 272-1030 470uF/35V capacitors and change them out. They are in the middle of the Power Supply PCB and are close to the long flat aluminum heatsink. Make sure you match the polarity properly when replacing. Your unit will be as good as new and will proibably last forever now.
Posted on Jul 18, 2008
  • webpagecons
    webpagecons Jun 04, 2014
    WheatService, thank you so much for your help, it was very useful and worked like a charm! Even the catalog number for the capacitors at Radio Shack were the same so it made the repair even easier. Thanks!
  • Anonymous Apr 25, 2017
    Thanks WheatService saved me from having to buy a new stereo! That fix worked perfectly! Ordered new caps from ebay. Took about 30 minutes to replace the caps and another 10 to put it back together and test to make sure all was safe (always have fire extinguisher near buy when testing DIY fixes ;) ). Works like brand new again and sounds better than it had been when it was slowly dying before.
    Cheers!
I had the same problem except my volume would just decrease after a few minutes of being on like someone was pressing the volume down buttton. If I walked over to the subwoofer and gave it a knock on the top the volume would instantly come back on where I had it set before. I took WheatService's advice and replaced the 470uF/25Vcapacitors and everything is working great now. I am very pleased. BTW, the parts at radio shack were like $3.00. I needed a desoldering tool, which I would recommend for this job...the one with the suction ball. I also needed some more soldering wire for a total repair cost of about $17. If you have all the tools the capacitors will cost you $3.00. Philips wanted to send me a replacement unit for $100.00 and I'm sure the local repair shop would have been the same if not more. Thanks again, WheatService!
Posted on Aug 12, 2008
  • andersen_tra
    andersen_tra Feb 17, 2013
    Worked perfect...thanks for the good info :)
  • andersen_tra
    This worked perfect... Thanks for the heads up ;)
I confirmed that replacing the two 470uf 35v capacitors works. I had the same problem and took the advice above. I have no skills in soldering but pulled it off without a hitch.
James Brown's "I Feel Good" was playing on the radio when I turned the system back on !
Posted on Feb 06, 2009
Replacing the two capacitors works!!! Thanks everyone!
Posted on Jan 04, 2011
I've got a new problem. It would help if I could read. I replaced the main power capacitors (didn't catch the sub woofer part for some reason). So now I need to replace the transformers. Any idea what ratings I'm looking for when I buy new ones? About to remove them and start prowling thru other electronics in the house to see if I can find a match.
Posted on Dec 24, 2011
Ok i added the capacitors, but now my power light on the subwoofer is just flashing and still now sound. any ideas?
Posted on Aug 05, 2010
    Problem Solver:
This works great, anyone with this model and buzzing problem should try this!!!!!!!! Mine stoped powering up as well.. the little red light on the sub would not turn green anymore. bought 272-1030 470uF/35V capacitors at the shack and changed them out..... powered right up... Im still kinda in shock. If anyone needs any help with which ones... email me ivtecboy@yahoo.com.
Posted on Jan 24, 2010
  • Brad Roth
    Brad Roth Jan 27, 2010
    This is off the subject of the above problem, but since my unit powers up now, does anyone elses not hold the station presets anymore? mine doesnt... is there a battery int he dvd section that holds these that went out?
  • jsg1k2 Jun 17, 2013
    Had the same symptoms. Replaced the 2 caps on psu. The problem still persists. Any ideas what else could be an issue.
Thanks, WheatService! I followed instructions and fixed the problem for only $11!
Posted on Nov 10, 2008
I had the save the same problem
Posted on Jul 17, 2008
    Genius:
  • Philips Master
  • 1,550 Answers
Maybe the ICs sound amplifiers are damaged.
Posted on Apr 06, 2008
Hi I have a Philips HTS3450 system but lost the Subwoofer, Is there a way that I can connect the Subwoofer connection to my Panasonic Home theator system to get the sound? Thanks in advance
I'm not sure what you mean by "connecting the Subwoofer connection to my Panasonic Home Theater System"
If you want to watch something on the Philips and send the audio to your Panasonic Home Theater you can buy a VGA to AV Adapter Cable. Just connect it to the back of the Philips HTS3450, get an AV cable (red,white,yellow) and run it to the Panasonic.
I recommend buying it here: http://www.buy.com/retail/product.asp?sku=212966742
Aug 11, 2010 | Philips HTS3450 System
Hi my philips hometheater HTS3450 subwoofer power supply is blown off and the philips guys are giving estimate of 100$. my question is if i dont want to use the subwoofer and the speakers but only connect...
yes.modern TVs have good speakers,and the bravia has a good set,with adjustable sound fields,plus a decent amp in them.just use good cables,and use component video cables,or HDMI if yr DVD has it.most have 1080 video resolution nowadays
Jul 01, 2010 | Philips HTS3450 System
I have a philips surround system model # HTS3450/37 and my subwoofer is out and i cant hear anything through my system. How do i check what is out on my subwoofer?
Hi
Thanks
in advance
Jan 01, 2010 | Philips HTS3450 System
Speakers
Did you read the manual or just started to try and connect everything?
what do you mean by HT slots? I hope not the slots on teh back of the device itself....
Just check here,1 cable from the device to the subwoofer, the speakers should be connected to teh subwoofer: http://www.p4c.philips.com/cgi-bin/dcbint/faqview?scy=US&subrequest=1&mid=Link_FAQs&view=aa12_view_full.html&desc=Philips+DVD+Home+Theater+System+HTS3450+DivX+Ultra&session=20090417124015_94.209.249.65&list=aa12_list_partial.html&slg=AEN&refnr=0006801&refdisplay=AVS_HTS_031&dct=QAC&ctn=HTS3450/37
Apr 17, 2009 | Philips HTS3450 System
I own an hts3450 system, dvd player part is destroyed.
You can check on ebay if maybe somebody else has damaged set. they seem to be sold a lot there. Otherwise contact philips vendor
Feb 10, 2009 | Philips HTS3450 System
Installing help
check on www.philips.com and search for HTS3450, all setup details are available there.
Jan 02, 2009 | Philips HTS3450 System
Philips HTS3450 sound problem
Jun 09, 2008 | Philips HTS3450 System
Buzzing noise
If the sound goes out completely, try hitting the mute button (to mute it) and then hit it again (to un-mute). I've found that this work-around typically gets it working, at least.
Jan 03, 2008 | Philips HTS3450 System
Region free
Sorry - every Philips model has a region it was marketed for, and dvd's from other regions will not work without an illegal hack (if one exists).
Dec 07, 2007 | Philips HTS3450 System
Philips HTS3450 System Logo
2,871 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
