posted by ubcman on Apr 06, 2008
I instaled a WDA-2320 desktop adapter and it is not working. I also instaled the D-Link DIR-615 Wireless N Router and that is working fine. But the card that in instaled in my hp 750n is working at all.
Solution #1
posted on Apr 06, 2008
To make sure it's not a driver problem: Click Start>right click my computer>click Properties>click Hardware>click thr + next network adadtor. Right click on your wireless adapyor and click on uninstall. When it's done, move tou're pointer to the top where it says My Computer or the name if you gave it one. Right click on it, then click on scan for hardware changes. Your system should find the card and install it and tell you it's ready for use. If you need a driver here is a link: http://support.dlink.com/products/view.asp?productid=WDA%2D2320#drivers
Also, with d-link there should be a little d on your task bar. Right click on that, click on show available networks and make sure it's connecter to youre. If this fixed your problem please rate it fixed. If not just add a comment and I'll be glad to help. Thanks.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
When the card was installed the for the first time , did HP detect if something new was put into the computer . If not then there could be an isuse with the card.
To check that , click on start>right click on my computer>left click properties>click harware tab >click device manager
In the list click the +sign next to network adapter
If the D-link card shows up with a yellow excalamation mark there is a driver conflict
If the D-link card shows up with a yellow question mark there is no driver
Suggest a new solution for this problem
Post a New problem for D-Link RangeBooster G WDA-2320
Email this problem
Email this problem
Can you Help with these Wireless Adapters problems?
Wireless Adapters
Have a Kensington Power adapter...
End is broken off and need to... Answer This...
Wireless Adapters
Disconnects from Internet when...
I have the exact same problem.... Answer This...
Repair Service
Find Wireless Adapter Repairman Near You:
