Question about GE Energy Star WCVH6260F Front Load Washer
Sparking! I forgot to mention with my GE Front Load Wash Machine problem of banging, violent shaking and movement, we also have sparking I can see while the machine is running. I don't believe consumers should have to adjust to the machine to make it work and try to find solutions on blogs-its a GE problem and needs to be resolved with a permanent solution.
When we first got our washer home, we had a very scary problem with it "walking" across the floor on the spin cycle. We discovered that we didn't remove the " shipping bolts" They are located on the underneith of the washer. No one told us we had to do that when we purchased the washer.
Posted on Apr 27, 2008
How do I fix a front load washer that shakes violently on the last spin cycle?
CLOTHES UNBALANCED? OR COUNTER BALANCE SUPPORTS BROKEN, AND NEED REPLACMENT? WASHERS have many different weight balancers but sounds like u need to take body off and have look at the counter weights set up while running machine, just jumper the door switch to keep a closed line. and then agin sometimes its as simple as making sure ur washer is leveled on ur floor, check ur leg adjusters as they do get funny at times..
Sep 13, 2014 | Washing Machines
Was installed on a solid, level floor, adjustable legs flat at their lowest level and cannot wash a load of clothes due to the shaking vibration and banging around of the unit.
GE thats rare///Is the unit solid frount to back corner to corner can;t be any movement there at all///more inportant to be solid then level grab corner of machine and see if there is any movement from rear corner left to front corner right and then the other side also are the shipping bolts and spacers 4 removed from the rear of unit..hope this helped.....good luck if I helped you please vote
Feb 06, 2011 | General Electric WCVH6800J Front Load...
Heavy loads like rugs do not spin and the machine jumps around and bangs into the wall. I have to turn it off and take my wash downtown to complete. The repairman says evrything looks fine. This is a GE...
Check for any movement from corner to corner (across corner to corner) if there is any AT ALL adjust legs to take up the movement / no movment is more inportant then being level a lot of techs miss this... anymore questions or problems just ask .....good luck
Feb 01, 2011 | General Electric WCVH6800J Front Load...
The drum shakes violently and is very loud during spin cycle
There are 2 shock absorbers/springs attached to the drum. If one of them breaks it will cause a loud banging noise when you wash heavy loads. This is an easy fix. The part is about $22.00 and it is accessed throught the front bottom panel.
Dec 01, 2009 | Frigidaire GLTF1670A Front Load Washer
Samsung P801 Front Loader shakes violently during spin cycle.
When the washer goes into spin cycle it is suppost to start at a slow speed and continue to increase speed (to a maximum of 800 RPM) as the water leaves the clothes. Your washer is going directly to 800 RPM which causes the washer to shake and stop giving you the E4 code. The control board that controls this speed increase must be replaced.
Feb 23, 2009 | Hotpoint Ultima WD72 Front Load...
Shakes Violently
run it with the top access panel open and watch,
while you are there try out the suspension ,
you do it like an old car push it down , push to sides etc .
it should resist and return well. no bounce. tight.
May 15, 2008 | GE WBVH6240F Front Load Washer
GE WBVH6240
Disconnect power to machine,
Drain all the water you can.
Remove the bottom access panel ( 3 screws on bottom plate)
open the large plastic filter in center
have a tray and towels to catch the water,
remove all clogging material,
look in with a light and turn the pump , it should turn freely.
Jan 27, 2008 | GE WSXH208A Front Load Washer
Frigidaire front-load stackable washer has violent shaking cycle
The Shipping bolts need to be removed from the back of the unit?? they go thru a plastic sleeve once the bolts are out you can twist the plastic peice to remove them completely I think there are 3 of them
Jan 24, 2008 | Frigidaire GLTF1670A Front Load Washer
Shaking like crazy
ALERT. transit brackets still on machine ..REMOVE THEM;;
Nov 25, 2007 | GE WBVH6240F Front Load Washer
GE Energy Star WCVH6260F Front Load Washer Logo
198 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
