posted by RebeccaDiane on Apr 06, 2008
THE GASKET INSIDE THE DOOR (FRONT LOADING) HAS 3 HOLES FOR DRAINAGE. THERE IS A LOW SPOT IN FRONT OF THE HOLES AND WATER COLLECTS CAUSING MILDEW. I HAVE BEGUN WIPING THE WATER AWAY WITH PAPER TOWELS BUT WONDERED IF ANYONE ELSE HAS THE SAME PROBLEM AND WHAT THEY HAVE DONE TO RESOLE IT. THANKS
1 Other User Has The Same Problem
Comment by MarianneCS, posted on May 12, 2008
I have the same problem and wipe the gasket after every load. I also clean the holes occasionally with q tips to get rid of the gunk that builds up in the holes themselves and behind in the gasket.
Solution #1
posted on May 15, 2008
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
This is a poor design. Mine became so stained that I replaced it. Unfortunatly the replacement part is for a newer model and the retrofit is a little different than the original. The seal didn't let the door close all the way and I have to push against it to get it to lock. I am hoping the gasket will loosen up over time. Even with that the drain is a water collector. I spray mine with a mildew product after washes, or leave the door open so it will dry out, and I occasionally wipe it with a rag. I hope Bosch changes their design.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Bosch Nexxt Premium WFMC6400UC Front
Email this problem
Email this problem
Can you Help with these Washing Machines problems?
Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch WFMC3200UC
Bosch WFMC3200UC
My Bosch clothes washer does... Answer This...
Bosch washing machine
My Bosch front load washer... Answer This...
Bosch Washer Nexxt 3200
The washer is not spinning or... Answer This...
bosch front loader washing...
bosch front loader washing... Answer This...
Washer help
Washer help
I have the Bosch 2060, Same... Answer This...
Repair Service
Find Washing Machine Repairman Near You:
Find Parts
