Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Whirlpool model GS6NBEXRL00 side by side Inside lights
The inside lights on the Refrigerator won't come on. I've check the bubbs all work fine. Unpluged the door swiatch and conected the wired directly and stll nothing. The Freezer side works fine. Anyone got a clue?
    Genius:
  • 1,073 Answers
Bad wiring inside the case
Posted on Apr 13, 2008
No Display, no light on refrigerator side
If the refrigerator compartment light does not come on but the refrigerator is cooling, make sure the light switch inside the refrigerator compartment or freezer compartment is not stuck in the closed position.
The light switches (on some models) are located on the ceiling inside the freezer compartment or on the outer wall inside the refrigerator compartment. I usually try flicking the switch or unjamming it with a small pin.
Hope this helps
Ryan
May 22, 2011 | Whirlpool Refrigerators
The lights (3) does not work on the frig side of my Whirlpool side by side. The door switch checks out fine.
i hate to tell you this,but you will need the new motherboard to fix this problem,they are notorious for doing this,the board is located in the rear area inside the unit inside a plastic box with a cover and has 2 to 3 harnesses yoy unplug and replug in,some clues to this are:lights that burned out and you replaced and now either dimly strobe or do nothing and the refrigerator compartment does not cool and the digital temp read-out if equipped is dark now also,the board is about $90
Apr 16, 2010 | Whirlpool GS6NBEXR Side by Side...
Refrigerator is too cold and freezes food.
Good day,
If the machine is under one year old, all working components are under factory warranty. Call for warranty service from selling dealer, or if you moved out of the area, an authorized Whirlpool warranty dealer.
Nov 25, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Icemaker not producing ice at all. Tried all the
hi
it is the compressor problem ..check it
thank u,,//please rate it
Jul 04, 2009 | Whirlpool GS6NBEXR Side by Side...
Freezer not freezing on whirlpool side by side fridge. Its a 2001 model... ED0GTQXKQ00
Inside the fresh food compartment near lights is the defrost timer. Turn it clockwise slowly until you hear refrigerator compressor start. If this works, replace the defrost timer. Let me know, Thanks, Sea Breeze
Mar 18, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Inside LED and light on fridge do not work.
First check your light bulb to see if it's good, if it is replace the door sw( it's the switch the door hits when closing ), It can be a pain to remove but that's the only parts that make up the light circut hope this helps
Jan 08, 2009 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Mod #GD5RHAXNQOO
Possible that the door switch is the reason.Check for powerat the door switch
May 19, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool side by side water dispencer
Sounds like some switch wires at the water valve.
Should be color coded.
May 01, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice Dispenser Doesn't work...
sounds like the water coming into the icemaker is spilling over or leaking into the ice despenser bucket.... check for ice build up or plugging of water chut into ice maker
Aug 08, 2007 | Whirlpool GS6NBEXR Side by Side...
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
192 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
