Door lock is jammed on , take front panel and console panel off , with a screwdriver, flick door lock mechanism to open, spray with wdr0 and it should work
E09
Heating circuit fault.
As above, this is most probably going to be an issue with the heating element as the thermistors have their own fault codes below.
Recirculate/drain selenoid may have failed. Remove bottom kick panel and watch selenoid durind exhaust cycle. If it does not open to all water to empty, it must be replaced.
Hello Sir,
I think that this is due to a faulty Main box Fuse. This usually happens when the heating elements of the washer go on. Try to inspect for faults, cracks or breakages in fuse box or in switches.
Make sure you hace a 13 amp fuse fitted in plug.
Could be a faulty heater element.
Locate heater,remove connections to heater and try without the
heater.
If it still blows, then could be a faulty motor, unplug motro, and try again.
Hope this helps.
