Question about Microsoft Computers & Internet
VBA find and replace using if-else statement
I'm Anand, a beginner in vba programming. I would like to know the code/suggestions, using vba, to replace a particular word in MS Word with another (it should also ask me whether to replace the word or not). I wish to get the code written, or even suggestions, using "if-else" statement. Could you please help with this?
Best,
Anand
Jhtdcfkhgj hh jh vjhv
Posted on Aug 22, 2008
SOURCE:
Remove VBA Password
How to Remove VBA Password - VBA Password Remover Tool to quickly or reliably recover VBA password. This software recover VBA password from your sheet/workbook project password and open MS office files. Source link:- http://www.advance.vbapasswordrecovery.net/
Apr 15, 2013 | Computers & Internet
What is exel sheet extension in office 2010 ?
Excel Workbook
.xlsx
The default Excel file format. Cannot store VBA macro code or Microsoft Excel 4.0 macro sheets (.xlm files in Excel 4.0).
Excel Macro-Enabled Workbook
.xlsm
Uses the same basic XML format as the Excel Workbook, but can store VBA macro code. Users saving an Excel workbook that has VBA code or Excel 4.0 macro sheets (.xlm files in Excel 4.0) are prompted to use this file format.
Excel Template
.xltx
The default file format for an Excel template. Cannot store VBA macro code or Excel 4.0 macro sheets (.xlm files in Excel 4.0).
Excel Macro-Enabled Template
.xltm
Can contain a VBAProject part or Excel 4.0 macro sheets (.xlm files in Excel 4.0). Workbooks created from this template inherit the VBAProject part or Excel 4.0 macro sheets that exist in the template.
Excel Add-In
.xlam
A supplemental program that runs additional code. Excel add-ins use the Open XML file format to store data, and they support using VBA projects and Excel 4.0 macro sheets.
Feb 21, 2011 | Computers & Internet
VBA and macros
SLA consultants in India. The training program is intelligently designed by industry experts to provide hands on experience and in-depth knowledge to the participant regarding MA Access database and Visual Basic for application programming. The training will use real time practical sessions and live projects and assignments to offer you a better understanding of both the tools. https://www.slaconsultantsindia.com/vba-macros-programming.aspx
Jun 22, 2009 | Microsoft OFFICE 2003 BASIC OEM ENGLISH MS...
CODES for entering an I.D number using vba
Try the help built into Excel and give yourself time to absorb it; Excel has some of the best help in the business. VBA may be more complex than you need to solve a data entry problem. If you're trying to add data input masks in a database, why don't you try Access (the help for which is admittedly weaker because database programming is among the most complex of all productivity apps)? I learned VBA from 3 books I rented from a good public library over the course of a project that was about a month long, (because) at some point Microsoft abandoned the idea of teaching it via help screens. Still, you might join a MS developer site and those are loaded with detailed explanations and many other experts. I hope this helps... I feel your pain.
Mar 22, 2009 | Microsoft Office Excel 2003 for PC
Excel
Egad. Well, first off, I'd suggest splitting the document up if you can. The chances Excel will crash on all those records is pretty good.
Next, you'll need to use VBA I think. Do you know any VBA? I am guessing you probably don't. Anyway, I can't go into it all here, but I'd suggest you snag a local with some VBA skills and then point him or her to this:
http://www.automateexcel.com/index.php/2004/08/14/excel_vba_macro_to_autofill
Jun 11, 2008 | Microsoft Excel for PC
Office 2007 Standard - VBA not working
There is no indication that VBA should not work in all versions of Excel. There is a new file extension (xlsm), which is used to activate macros and allow usage. If you have, perhaps, opened and saved with incorrect extension (new is xlsx), VBA may be unavailable. Try to resave it with the changed extension. It seems likely that this is the issue (reference http://office.microsoft.com/en-us/excel/HP100141031033.aspx?pid=CH100648071033). Also, if you make sure your Save As option is set at xlsm, this should help to prevent problems. VBA should not be an issue in any version of Excel and custom functions ARE available (see http://office.microsoft.com/en-us/excel/HA102189961033.aspx?pid=CH100645021033). It should be as simple as changing the extension, and I would suggest changing the default save as option. If this helps, please rate "FixYa"! Thanks!
Apr 03, 2008 | Microsoft Office Standard for PC
VBA Password
Can you read the code at all?
If yes, try copying the code to a new VBA screen and pasting it in.
Do your changes in this screen and save it as a Macro, then delete the original.
Note: I use a blank password on all my protected documents - not real good security, but easy to remember and others don't know that it is to be left blank - so it foils a lot of people. I use the password only to protect the formulas and script from being changed accidentally by the end user - not to prevent anyone from "stealing" my code.
VBA passwords seem to be difficult to crack and the programs to do so seem to be quite expensive for a one time use.
Have you thought of just rewriting the VBA script? Remember, you did it once and went through all the problems of working out the sequence etc so much of this might come back to you and save a lot of time over the original exercise.
Good luck.
Mar 26, 2008 | Microsoft Excel for PC
Writing macros
Anirbanmj
Macros for Excel and the rest of the office suite are based on Visual Basic for Applications (VBA) which is a subset of VB programming language.
If your not familier with this language then i would suggest "Googling" VBA Introduction or similar and have a look at some introductory info. If you are ok with VB then you can record doing a task you want to do and then look at the code generated to see what it has created.
Feb 02, 2008 | Computers & Internet
Macro on excel
Macros are a timesaving feature that allow you to record a sequence of actions that you do in excel, and replay them back later.
You give each macro a name, and you can invoke them later, and Excel will "do" whatever it is you did when you recorded the macro.
To record a new macro:
1) Open Excel
2) Go to Tools->Macros->Record New Macro...
3) Type in a name for your macro and hit OK
(A new toolbar will popup with a "stop" button on it. Excel is now recording everything you do)
4) Do something, like, for example, select some cells and make them bold.
5) Click the "stop" button.
Now your macro has been recorded! You can play it back later by:
1) Open Excel
2) Go to Tools->Macros->Macros...
3) Select your macro from the list
4) Click "Run"
The actions you performed earlier will now be executed.
Macros are written in Visual Basic for Applications, or "VBA". It is a programming language which uses the Excel Object Model to perform various actions. You can edit and create custom macros by writing the code manually in VBA. To do this:
1) Open Excel
2) Go to tools->macros->macros...
3) Select an already existing macro
4) Click "Edit"
(The visual basic editor will open, showing you the code for your macro)
At this point you are writing a program in Visual Basic. To learn how to edit macros, you need to learn visual basic, as well as the specific quirks related to excel macros in visual basic.
Recording a macro, and then using it as a template while you edit it is a common trick for making macros manually more quickly.
If you are not familiar with VB, I would not suggest attempting to edit your macros in any but the most simplest of ways. If you're brave, you can try to learn about editing macros in VBA here:
http://www.anthony-vba.kefra.com/
Jan 28, 2008 | Computers & Internet
Excel vba password recovery
You can but you will need software. Search for google for VBA password recovery tools. Search for the appropriate crack you have it all . .
Dec 30, 2007 | Microsoft Excel for PC
Computers & Internet Logo
477 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
