Question about Vizio P2 42 in. HD-Ready Plasma Television
Vizio P42HDTV Power on Diagnosis
I have a Vizio P42HDTV that won't turn on.  I believe the main and sub power boards are ok, as all the voltages check out.
How can I tell whether the turn on issue is from the power supply versus the main (DTV) board?
The unit's power light comes on when I plug it in, but pressing the power button does not cause the led to cycle to green, nor do the main power relays click.
  • 2 more comments
  • DrAnonymous Apr 07, 2008
    Hi Bill, thanks for the info.  I did some more diagnosing and came up with the following:
    - When first plugged in, the relays do click.
    - After I press the power button, no clicking.
    - There is a switch on the main power board, that is labeled Auto/Normal.  If I switch it to Auto, the relays click and I can see the screen illuminate.  Its still black, but you can tell it came on.  No menu or video signal displayed.
    - If its unplugged for awhile and I plug it in, I can sometimes press the power button and the screen will come on with regular video for about 30 seconds. It will then click back off and pressing the power button won't do anything else.
    I almost wonder if its thermally related.
    Here's a link to a photo I took.
    http://www.forumsigs.com/img.cfm?img=387...
    I labeled the parts. Do you think this is the DTV board? I think the Y/Z sustain boards are ok, since the image looks fine when it does come on.
  • DrAnonymous Apr 11, 2008
    I can't find a cap that's bad, but using this manual -
    nationalservicealliance.com/visio/VIZIO-P42HDTV10A.pdf
    I discovered most of the input voltages to the voltage regulators are not correct.  The 7809 should have at least 10V on pin 1 to regulate down to 9V on pin3.  My input was 1.26V, way too low.
    Here are the readings for my board -
    J1 All 5V lines good
    J1 All 12V lines good
    U4 3.3V output good
    U5 1.8V output good
    U6 0V output and 1.26V input. This is the 7809.
    U7 0V output
    U13 0.31V
    U14 0.31V
    J2 5V on all lines
    J7 Should read 3V or higher on the buttons (Power, volume, etc)
    I noticed that when my TV turned on I had the correct voltages on the buttons.  When it wasn't working, the button voltages were under a volt.  I never could catch the voltage at one of the regulators at the same time the button voltages worked.
    Vancebaldwin sells the board for $145'ish including shipping.  They have a core charge of $60'ish.  Unless I can get ahold of a schematic, it may be easier to just buy another board.
    I'd be happy to swap info with someone directly or via phone if they'd like.
  • Anonymous Apr 13, 2008
    Please check the U29 8 pin little surface mount mosfet it has this
    letters
    > FDS4935
    > In this part inputs 13.2 volts which is ok for the near 12 vdc but
    it
    > outputs 1.250 vdc i am 100% sure that this is all the problem
    > check it out, and tell me if you´re agree with me
    > On this output pin it feeds the audio Ic, the 7809 and the tuner side
    board
    > which needs de 12vdc too and its getting only the 5vdc part
    > what do ya think??
    > Richard
  • importc Feb 05, 2009
    where is that board with pin 8 u29
    wont turn on p42 vizio
Please check the U29 8 pin little surface mount mosfet it has this letters > FDS4935 > > In this part inputs 13.2 volts which is ok for the near 12 vdc but it > outputs 1.250 vdc i am 100% sure that this is all the problem > > check it out, and tell me if you´re agree with me > > On this output pin it feeds the audio Ic, the 7809 and the tuner side board > which needs de 12vdc too and its getting only the 5vdc part > > what do ya think?? > > Richard
Posted on Apr 13, 2008
Hi same problem, but which component is the problem?? i cant buy a new dtv board ill try ti fix it, but which caps are the faultys?? pls help
Posted on Apr 11, 2008
  • ricardito Apr 13, 2008
    I think i got it!!!
    letters
    > FDS4935
    it
    board
    > what do ya think??
    > Richard
  • 934 Answers
Relays are the first big clue, triggered by the 5 & 12v supply you should be able to trace back using a dmm and see if you have both of those voltages present... The lead coming from the smps to the y-sus board is a good start. On a Vizio I believe the voltages are listed per pin right on the board...
If you had any kind of relay sound then you could suspect the y-sustain or z-sustain board or something else. With the relays being silent I'd strongly suspect the power supply.
Bill
Posted on Apr 06, 2008
  • William Rayburn
    William Rayburn Apr 07, 2008
    Could very well be thermal affected - and somewhere in the cause and symptom it's likely to include being some caps will need to be replaced. Don't rule out the sustain boards - they could very well be loading down the supply and cause these very symptoms. You might try unplugging first the x-sus from the supply and try to power the unit. If it comes up normally (picture messed up of course) powers okay has audio then try testing the components on the x-sus. Then try the same thing with the y-sus. At this point you'll need to take out the schematics and mesaure some test points to isolate the problem. While you're at it, might as well get out the esr meter and some mist and check on a few caps - might help narrow down the area too..
    Good Luck!
    Bill
Vizio e470i-ao won' turn on, power supply board replaced still no picture or sound, led power on indicator light comes on momentarily then goes out?
Power ON signal voltage should come from the main board to power regulator board. It does not come now. Check for the reason. Probably, the main board will have the fault. Contact any service technician. http://electronicshelponline.blogspot.com/
Jul 23, 2015 | Vizio Televison & Video
Vo47lfhdtv power no sound or picture
First start with checking or have someone check the power supply voltages. I believe that particular model has 5vdc, 12vdc, and 24vdc circuits. If the power supply checks out fine, you most likely have a faulty main board.
Feb 06, 2013 | Vizio Televison & Video
How do I test a High Voltage Transformer on my Vizio VU42L-FHDTV10A?
It could be the main board. The main board controls the standby light on the front of the set. Check and verify that your 5vdc standby voltage is working. Next, I would check the "on" or "ps on" input on the power supply board. When you turn the set on (either my side buttons or remote) the main board should send a 3.3vdc signal into the "on" terminal on the power supply. This "on" signal from the main board turns on the other half of the power supply thus turning on your set. If you are not getting this signal from the main board, I would suspect the main board. To test your power supply, you can simply put a jumper from 5vdc to the "on" terminal on the power supply. Your 12vdc, and 24vdc power supplies should then become active.
Oct 31, 2012 | Vizio Televison & Video
VIZIO MODEL VW42LFHDTV10A WILL NOT TURN ON. FUSES &VOLTAGES OK
Did you check for the "ON" or "PS ON" signal on the power supply board? It should be around 3.3vdc.This signal comes from the main board, it commands the other sections of the power supply to come on and turn on the TV set. This signal should be present when you press the power button from either the TV or remote. If you are not getting this signal from the main board, you're most likely dealing with a main board failure. If you are dealing with a main board failure, take heed, some Vizio main boards can be expensive.
Sep 04, 2012 | Televison & Video
Vizio VW37L no power
Check for bad capacitors in power supply, check voltages coming out of the power supply, if voltages are good, bad main board.. Vizio's are notorious for bad main boards.
Nov 23, 2011 | Vizio VW37L 37 in. LCD HDTV
I have a Panasonic model TH-42PZ80U Plasma Tv the red light keeps blinking 10 times and it won't turn on?help
hi,
In your tv there some problem with power supply. you have to check the followin voltages. Sub 5v SOS ,Main 3.3v SOS A-Board,DTV 9v SOS , Tuner Power SOS. If any one of the voltage fails it will shows 10 blinks.
ok
Jul 18, 2011 | Panasonic Viera TH-42PX80U Plasma TV
Tv won't turn no the vizio logo only blinks
That problem is 2 causes,its either power supply or system board.
This are some D.I.Y procedure for troubleshooting.
  1. Open the back cover by removing all screws at the back.
  2. Try to look at the power supply board and find the leak/bulge on top capacitors.If you found,replace it with the same type and ratings.
  3. If the power supply doesn't have any leak capacitors.Try to power it ON to perform voltage checking.
  4. Check the output voltage of power supply such as 5vdc,12vdc and 24vdc by using voltmeter.If this 3 supplies having a voltage drop or flickering voltage while on power ON.Check the following parts on the power supply,change value/open resistor,shorted transistor and diode or repeat step # 2.
  5. When the output voltage is stable and all parts looks OK.The problem could be on system board.Unfortunately the system board or main board is not for D.I.Y because the parts inside is very logic and very sensitive.That is replaceable.
Thank you and good luck.
Jun 06, 2011 | Vizio L32 32 in. LCD HDTV
My vizio tv won"t come
May 09, 2011 | Vizio Televison & Video
My VP504fhdtv10a vizio plasma TV when connect power cord the Vizio in front light up yellow/amber but will not turn on. I have replace Logic Control D Board still have same problem. I do research online...
Logic Control D Board got nothing to do with this problem. This is your main power supply gone bad(usually not the sub power supply). I just repaired my VIZIO by replacing main power supply. Just remove back cover and your board will be right in the middle of the screen. Just get board part/serial # and google it. My best price was through eBay(around $100). Everything is fine now.
Nov 07, 2010 | Vizio VP504F 50 in. Plasma HDTV
37 inch vizio has black screen. the vizio display
L37HDTV10A THE TV ON NO VIDEO NO MENU SAON OKEY
Jan 16, 2010 | Vizio L37 Television
Vizio P2 42 in. HD-Ready Plasma Television Logo
1,405 people viewed this question
Top Vizio Televison & Video Experts
Dave Naylor
Dave Naylor
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
