Question about LG enV VX9900 Cellular Phone
Lg was dropped in coke.. any way fix?
My lg env slipped out of my pocket into class of soda... it stayed on until I turned it off. I took out the battery to try to dry it a little bit more, but when I try to power it up it shows the verizon symbol and then will say Battery Charging, is there any to solve this problem?
  • Twilight09 Apr 06, 2008
    I dropped my phone in a cup of liquor..dont ask...but it was mixed with a juice. I know the battery or something is owrking because it vibrates when i try to turn it on. I have set it in the heater to dry it. i am currently leaving beside to blow dryer to dry it out some more. If anyone knows what else I can do it would sure help me.
    Problem Solver:
  • 10 Answers
MOST LIKELY YOU WILL GET MORE PROBLEMS WITH THIS PHONE IN THE FUTURE WHAT CAN HELP SOME IS IF YOU OPEN UP THE PHONE AND USE A TOOTHBRUSH TO CLEAN OFF THE CHARGING AREA FROM THE OUTSIDE FIRST THEN GO TO THE INSIDE, I WOULD RUB DOWN EVERY PART I COULD, IT MOST LIKELY WILL HELP FOR NOW BUT I WOULDNT TRUST THE PHONE, WATER DAMAGE CAUSES THE PHONE TO CORRODE SLOWLY.
Posted on Apr 06, 2008
6ya staff
SOURCE:
Need to replace the belt
Spray heavily with coke(soda) and let sit for 24hrs. It should loosen. Used on naval ships for rusted things and somethng in the coke eats away at the metal.
Jun 03, 2009 | Maytag SAV5710 Top Load Washer
Stays on verizon symbol wont turn on
it doesn't go out after a couple secs? or are you looking to change the pic after it boots? if the latter you can go to verizonwireless.com and use there manual on line for directions
May 03, 2009 | LG enV VX9900 Cellular Phone
My LG NV from Verizon turns itself off at random, even sitting on a counter (vs in pocket, which would make sense) Any clues??
Totally I have the same issues. I have had the ENV 1 ENV 2 (three of them) and VW says they have no idea what the issues if so they have been giving me new phones.....at least they gave me two new ones. I have also heard the the ENV 3 does the same thing
Apr 11, 2009 | LG enV VX9900 Cellular Phone
I dropped my LG enV into a puddle of water.
Sounds like you will need a new battery. My env2 would only work if plugged into the wall charger after I dropped it in the toilet. I got a new battery and it works fine now!
Mar 12, 2009 | LG enV VX9900 Cellular Phone
Battery is required
I already fixed my problem. I'm not sure how...? I just took the battery out a few times and wiped it off with a clean, dry cloth and eventually it started working. Thanks though.
Apr 06, 2008 | LG enV VX9900 Cellular Phone
Wont turn on
Pull the battery out for 60 seconds and replace. It should work. I had the same problem and a service rep helped me fix it.
Nov 08, 2007 | LG enV VX9900 Cellular Phone
How do I pair my Jabra Bluetooth -48D
well what you have to do is to go to the bluetooth menu turn  it on and select add new device now on you jabra headset it has an answer button wich you can press untill the blue light stays on that when the env can find and paire the device
Oct 22, 2007 | LG enV VX9900 Cellular Phone
LG enV VX9900 Cellular Phone Logo
91 people viewed this question
Top LG Cell Phones Experts
William Norris
William Norris
George Etukudo
George Etukudo
Sheldon Dedek
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
