Question about Panasonic CQ-VD7500U 7 Wide LCD/DVD/SD/TV Receiver MP3 CD Receivers Car Video Player
Unit shuts off
Shuts off after 10 minutes - checked all of the wiring - can't find anything. Any suggestions or solutions would be apprecated.
  • rymac802 Apr 23, 2008
    I have a panasonic head unit that does this same thing. has anyone found the reason?
Hi, if your unit doesn´t work and dead(no possible repair) and you want to sale the brain(YEP0FX5533) or all. Please mail yeliwill@cantv.net.
Posted on May 19, 2008
COMPRO EL MODULO TV TUNER DE INTERFASE DE UN PANASONIC CQ-VD7500U SI LO TIENES EN VENTA AVISAME ESTOY INTERESADO MI CORREO ES COMPRA24@hotmail.com SALU2
I BUY THE MODULE TV TUNER OF INTERFACE OF A PANASONIC CQ-VD7500U IF YOU HAVE IT IN SALE WARN ME I AM INTERESTED MY MAIL IT(HE,SHE) IS COMPRA24@hotmail.com SALU2
Posted on May 08, 2008
Rinnai RL94i - Produces hot water for 3 minutes, then stops
I just had this exact problem. It kept getting worse until we had no water. Our Rinnai tankless hot water heater started the same way though, with hot water for a few minutes and then would shut off with an error code 10. We just had to shut the hot water off and then back on, wait a minute or so and we had hot water back for a few minutes. Our unit would come on with a loud vibrating noise and remain until it shut off with an error code 10 (air flow fault). The solution was to remove the blower fan and blow out the squirrel cage. Ours had moths in it. We also vacuumed out the fan housing. Be careful to mark any wires you disconnect and take pictures before removal. Our unit is now almost silent when it comes on and supplies endless hot water.
Jun 10, 2014 | Rinnai RL94i Tankless Water Heater
Hi i have a 2010 Hyosung Aquila,I have replaced CDI unit and wireing loom and fuel pump relay, but bike will keep stopping after running for about 15 minutes,I allow it to cool for 20 minutes and it will...
Use a multimeter and monitor the kill switch or whatever switch shuts the unit off normally. It may be failing when warm. Sounds like you covered the basics already.
Nov 02, 2013 | Hyosung Motorcycles
Lound vibration when running
Check gas control valve.
Good luck,
Marty
Feb 18, 2013 | Rinnai Water Heaters
Furnace kicks on but the gas stays on for about 6 seconds and then shuts off and repeats this two more times and then stays off for 20 minutes and then starts all over again
This tells me that its either an ignitor or flame sensor. You will need to check to see if the ignitor is working by watching it when the unit comes on and if its not then replace the control board for the ignitor or the ignitor itself. If it is coming on then its the flame sensor. Sounds like the ignitor though. I would check that. These go back on a reg. basis.
Feedback is apprec. Thanks.
Jan 28, 2011 | Dehumidifiers
Stalls at about 3400 RPM - Everytime!
u could have just replace the main relay and save a lot of money.
Jul 01, 2009 | 1996 Honda Accord
Dometic RM2862 will not come on at all, no blown fuses or tripped breaker. no lights come on either. Any thoughts?
I have the same problem Have replaced the power Modular still Refrig light or anything styill doesn't work. Anyone have any suggestions?
Jun 27, 2009 | Dometic RM2852 Refrigerator
My r85 rinnai water heater vibrates significantly and makes
Sounds like there is something loose in the line.Like cut off valve,check valve.
Mar 09, 2009 | Rinnai Digital Remote Water Heater Control...
Unit shuts itself off after 10 -15 minutes
Protect mode will kick in whenever a fault is detected.
You get the unit not powering up, and sometimes you hear a clicking noise, that is the protection switch that keeps shutting down the unit.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Jan 08, 2009 | Samsung HT-WX70 Theater System
Harmon Kardon AVR-220 Shuts off unexpectantly
The fact that it is putting off that much EXTREME heat tells me that their is a power regulation problem.  I would recommend not using this device at all and disposing of it properly.
Jan 04, 2009 | Audio Players & Recorders
My Harmon Kardon AVR 220 Shuts off after less than ten minutes
It sounds to me like solder overflow (from getting too hot) is shorting out the circut board! Chech the board for short circuts
Jan 03, 2009 | Audio Players & Recorders
Car Audio & Video Logo
160 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
