Question about Cameras
Have a nikon D80, sometimes when turning on and taking a photo the battery drains to no charge. have to turn off and back on again and camera works ok. have tried on existing battery and on a brand new battery, same problem, so its not the battey.
    Genius:
  • 3,422 Answers
HI,
You can try updating the firmware if it is possible first.If this doesn't help then try removing the batteries off the camera and allow the camera to reset for an hour and then put them back.
If this doesn't help then You need to use 2500 or higher rechargeable batteries - as soon as you switch to this type of battery, it will work fine!
Your camera requires four AA size batteries.There are several factors that contribute to battery life:
NiMH: This is the best solution for enjoyment and cost savings. NiMH batteries typically last longer per charge than the average alkaline batteries. NiMH batteries are rechargeable batteries, so they can be used several times and thereby reduce the expense of continually purchasing new batteries. NiMH batteries are typically sold with a power adapter for charging. The life of these batteries can often be determined by the mAh rating, the higher the mAh rating on the battery, the longer that they will last. NiMH batteries do not have the memory effect associated with NiCd batteries, which means that these batteries can be recharged at any time and at your convenience (you do not have to wait for the batteries to completely drain between charges).
Lithium: Energizer has introduced a new series of Lithium batteries that provide optimum performance and long life for disposable AA size batteries. Laboratory studies shows that Lithium batteries last more than three times as long as standard Alkaline batteries. This means many more hours of fun and satisfaction with your digital camera. These lithium batteries are not rechargeable, they are long lasting.
Alkaline: Using the LCD display, downloading images, playback, zoom and flash all require some battery power to operate and may decrease the number of shots per set of batteries. Performance may also vary based on the Alkaline batteries selected. To significantly increase battery life, be sure to turn off the LCD when it is not in use. The LCD consumes the most amount of battery power. The benefit of being able to use alkaline batteries is that you can find then almost anywhere if needed.
Manganese: If you are using manganese batteries, the typical battery life will be about 2 - 5 shots. Then the camera will indicate that battery power is low and may shut-down. To avoid this experience, use either Alkaline or NiMH batteries.
Optimum Solution: Use a set of NiMH batteries for longer use and to reduce the expense of continually buying new batteries. It may also be a good idea to keep a spare set of NiMH batteries for other devices that require AA size batteries on a regular basis. Use AA Alkaline batteries when the NiMH batteries need to be recharged and you want to continue enjoying the use of your camera.
Goodluck,
Please don't forget to rate the solution as fixya..
Posted on Apr 08, 2008
  • 4,889 Answers
You have to re-flash the firmware of your camera... That will fix the problem..
  • 3,037 Answers
Try cleaning the battery connections and then let me know if this does or doesn't work
Thank you
I have a brand new Nikon D3100. The battery was fully charged and placed in the camera. I took about 4 photos, and then turned the camera off. When I turned it back on the battery wasn't working to...
The solution to your problem is simple, Kathrynbax.
The battery never comes in fully charged. It's always charged only so you may be able to check if your camera is working. I suggest, you take out your battery and put it to charge for exactly 90 minutes as the manual says. Then I'm sure you won't face any such problems.
Hope this solves your problem.
Good day!
Rebel
Sep 17, 2011 | Nikon D3100 Digital Camera
Nikon d80 dslr camera working fine and then one day turned it on to take pictures only to find an err message flashing and when the shutter button depressed it says r04. The shutter sounds but no pictures...
HiI am sorry to hear, but you will have to some professional. Regarding your d80 has common problem of sequence unit defective. I believe that is the problem and your local repair shop would charge around $75 to 235 depend on what they really want to charge. Thanks and best regard!
May 27, 2011 | Nikon D80 Digital Camera
I receive a Err on the display shutter snaps but no picture takes place. I have found out that if I try to take a pitcher let the shutter snap and then push the the apature botton i think it is on the...
Hi Jeff - The manual describes "Err" as a general error, a "Camera malfunction" and says "If error persists, consult with Nikon-authorized service representative." (Bottom of page 132 in the english version of the manual.)
Some folks have had mixed results with removing / mounting the lens once or twice, charging the battery and cleaning the contacts of both the lens and camera body's lens opening. More odten than not though - the camera has to go back to Nikon for repair. it appears that the shutter is replaced and things go back to working just fine again.
I would contact Nikon directly to learn if there are things they would like you to attempt before arranging for service of your D80.
I hope this helps and good luck. Please rate my reply. Thanks.
May 18, 2011 | Nikon D80 Digital Camera with 18-135mm...
When I zoom my nikon D80 to take picture, the apperture display will read F---- as a result, the image will be dark.
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success. Thanks & Before you leave, if you have found my information helpful and if you haven't already done so then please press the ACCEPT button, this is how I am paid for helping you today. POSITIVE feedback & bonus is appreciated
Feb 10, 2011 | Nikon D80 Digital Camera with 18-135mm...
D80 "battery drained' and "F"sign when pressing release button
Pls make sure of the following:
- You are using original Nikon batteries (generic batteries gave a similar problem to me)
- The aperture ring of your camera is correctly placed
Nov 16, 2009 | Nikon D80 Digital Camera with 18-135mm...
Err message appears on the display of my D80.
This may be due to the aperture ring in your lens. Try the following:
1. Turn off your camera
2. Move the aperture ring clockwise then lock
3. Turn on your camera and try again.
If this does not work, do the same thing again but turn the aperture ring counter-clockwise.
Nov 08, 2009 | Nikon D80 Digital Camera with 18-135mm...
I have nikon D80 purchased about 1.5 yrs. ago. After taking less than 10 pictures, I see a flashing battery sign saying low in battery even when I had charged the battery full. If I turn the camera off and...
Nice camera! I have one too, and really enjoy it. I suspect you are running the original firmware. There is a new firmware version 1.11 that specifically addresses this problem. The download and instruction page is below:
Windows OS:
http://support.nikontech.com/app/answers/detail/a_id/16091
MAC OS:
http://support.nikontech.com/app/answers/detail/a_id/16092
Sep 21, 2009 | Nikon D80 Digital Camera with 18-135mm...
NIKON D80 Can't turn it back on
oops. This is what I'm facing right now! Looking for a solution.
Sep 21, 2008 | Nikon D80 Digital Camera with 18-135mm...
Cameras Logo
63 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
