Question about Whirlpool Washing Machines
Clyapso display ce - Whirlpool Washing Machines
Hoe do I fix this CE and hoe will I know what curcuit board to fix please email me at [email protected] ASAP please and thank you
Posted on Jun 09, 2008
SOURCE:
Ce 7000
This is a common fault when the 7000 series gets older. The display drive circuit will normally need repairing.
if anyone needs a Casio CE-7000 or TK-7000 manual, one of the users has it here:
http://the-checkout-tech.com/manuals/cashregisters/Casio_TK-6000_TK-6500_TK-7000_TK-7500_TK-T500_CE-6000_etc_dealer_manual.html
Jul 02, 2013 | Casio Parts Cash Register PC Desktop
Flashing CE CODE
try to clear error code
Aug 20, 2017 | Hayward Pool & Spa
How to change tax rate on spl-290 calculator
* Press *N/C/CE *****n* Enter 200* Press the TAX+ *****n* The display will sh*w the t*tal price TAX+ 210* Press the TAX+ *****n again* The display will sh*w the tax am*unt TAX 10* *r the price after tax is $58.5, what is the pre-tax price and tax am*unt:* Press *N/C/CE *****n* Enter 58.5* Press the TAX- *****n* The display will sh*w the pre-tax price TAX- 55.72* Press the TAX- *****n again* The display will sh*w the tax am*unt TAX 2.78
Apr 24, 2012 | Office Equipment & Supplies
Our pump bearings noisy, had small engine shop repair hook back up , now ce reports on heater ????
Pump bearings, hook up, CE error...not following your sequence of events here. CE error on a Hayward heater means a problem with the control board communicating with the display board. Generally it means you need a new display/bezel assembly. None of this should have anything to do with a motor repair unless at some point during all this someone grounded out line power and sent a surge thru the system in the process.
John
Sep 07, 2011 | Hayward 250kbtu Ng Pool Heater - Inground
CE error displays
hello there and thank you for choosing fixya
CE Communications Error If there is any breakdown in communication between the machine controller and the motor controller, CE flashes and the unit beeps once.
Some common causes of CE errors include:
· Conformal coating on serial communications pins between the machine controller and motor controller. After disconnecting power to the unit, try scraping this coating off the pins.
· Check the resistance values between the serial communications pins with the connectors in place. Make sure the harness does not have a bad connection.
· Check the quick disconnect at the motor terminal. The drive motor must be hooked up properly or a CE error will occur.
· Drive motor thermal protector has opened.
·Motor controller is not powered or fuse has opened. Replace motor controller.
Press STOP/CANCEL to clear the display.
Jul 31, 2011 | Washing Machines
The code CE is showing on my Hayward pool Heater what does that mean and can I fix it
I have just repaired my H400 series pool heater from the 3rd CE error in only 3 years since the pool and heater were installed. In each case the circuit board (F0059-456600) was in some way to blame .... I will explain.
Case 1 : Only months after installation the CE error came up. Rain water had got in around the display module and water-damaged the circuit board. It was replaced under warranty. Since then I keep a big plastic lid covering the display unit when the heater is not in use.
Case 2 : 1 year from new the CE error came back. On investigation it was found that a rat had managed to get inside the heater (there are big gaps around the pipe entries) - it had then partly chewed through the ribbon cable joining the two circuit boards together. Display circuit board was replaced at my cost - and all was well again. I also rat-proofed the heater - eliminating all the big openings with chicken wire.
Case 3 : Fired up the pool heater for the first time this year and CE came up. I pulled the display module and this time found obvious signs of blackening / burning on the display circuit board under the big green resistor (R1). Luckily I had kept the old circuit board from the previous time and was able to make 1 good board from the two I had - back in action now.
So in my experience it has been the display circuit board each time - and it only takes a phillips-head screwdriver and about 10 minutes to get it out.
Jul 27, 2011 | Hayward 250kbtu Ng Pool Heater - Inground
CE error code on hayward pool heater
CE= Communication Error between Control Module
and Display Interface Assembly
1. Disconnect and then reconnect power to heater.
2. Check for faulty wiring or connection.
Inspect Display Interface Wiring. Ensure Display Interface Plug is securely attached to Control Module. .
3. Control Module and/or Display Interface Assembly
are defective.Replace Control Module and/or Display Interface Assembly.
Here is a linkt oH aywardmanuals:
http://www.haywardnet.com/inground/products/manuals.cfm
Jul 04, 2010 | Hayward 250kbtu Ng Pool Heater - Inground
The washing machine displays error code CE for communication error
Hi, Well if there is any breakdown in communication between the machine controller and the motor controller, "CE" flashes and the unit beeps once.
Some common causes of "CE" errors include:
1.Conformal coating on serial communications pins between the machine controller and motor controller. After disconnecting power to the unit, try scraping this coating off the pins.
2.Check the resistance values between the serial communications pins with the connectors in place. Make sure the harness does not have a bad connection.
3.Check the quick disconnect at the motor terminal. The drive motor must be hooked up properly or a "CE" error will occur.
4· Drive motor thermal protector has opened.
5·Motor controller is not powered or fuse has opened. Replace motor controller.
I hope it helps. Thanks! mannu_rakesh
Sep 02, 2009 | Kenmore Washing Machines
AEG LAVAMAT 74620 - Washing Machine CE error code
Replace Water distributor (Dispenser Drawer) then will be Ok
Rafiq
Aug 27, 2007 | Washing Machines
Washing Machines Logo
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
