Question about Video Game Consoles & Games
Wats a ip address - Video Game Consoles & Games
  • 32 Answers
Your internet's address.
Posted on Apr 06, 2008
  • 81 Answers
An IP address (Internet Protocol address) is a unique address that certain electronic devices use in order to identify and communicate with each other on a computer network utilizing the Internet Protocol standard (IP)—in simpler terms, a computer address.
2 Suggested Answers
SOURCE:
ib_yang
  • 1098 Answers
SOURCE: wat does 5200 error code
HI there.
Our experience has shown that this error message is solved by performing a manual setup on the Nintendo DS. Please follow these steps: The first thing you'll need to do is find out what IP address range you should be using. To do this: Click the "Start" button in the lower left-hand corner of your computer. Next, you will need to access the command prompt. To do this: Windows XP users click "Run." Windows Vista users click inside the search bar. Type "cmd" into the box and press Enter. Type "IPCONFIG/ALL" and press Enter. The IP address, Subnet Mask, Default Gateway, and DNS servers of the PC will be displayed. The IP address you are going to assign to the Nintendo DS must be 10 digits higher than the PC's. (e.g., 192.168.1.100 becomes 192.168.1.110). The DS and PC must have different IP addresses. Enter in the exact same values for your Subnet Mask, Default Gateway, Primary DNS and Secondary DNS. They must be the same for your Nintendo DS and for your PC. Click here to go to our Wireless Router Configuration page. Use the drop-down box on the left to select, if available, your router manufacturer. Click on your router's model number, if available. Read any "special notes" at the top of the router's page. Many issues can be solved by changing the settings found in the Special Notes. Follow the instructions and test the connection. You will now need to manually assign this new IP address to your Nintendo DS. For step-by-step instructions on how to do this on your Nintendo DS or Nintendo DS Lite, please click here. Check Nintendo's router info for special notes, if available, for your router. If you try these steps and you get a different Error Code, please review the values that you entered carefully, since an incorrect manual setup will cause another Error Code to appear. If the 52000 Error Code persists, than the problem may be caused by a basic setting in your router such as transmission rate. Please carefully read the instructions below: If you are still unable to connect, please call 1-800-255-3700 in the USA or Canada for more information.
Thank yo for using Fixya!
Posted on Jul 07, 2011
Need to know wat ip number is and port is
IP stands for Internet protocol.
It's represented by numerical code, which is assigned to each device like computer, printer, phone.
IP's are two types. There are Internal IP, External IP
Internal IP means that your system ip address.
If you want to know your system ip address follow these steps:
Start--->run-->Type cmd
Then command prompt will display.
type ipconfig
then it will display your system ip address
External IP address means that your network IP address. If you want to know your Network IP address then visit IP-Details.com here it display IP address, ISP,location, Longitude, latitude and so on.
To find your port number follow these commands:
Go to start--->cmd---->type netstat -a
Feb 02, 2014 | Televison & Video
Hi i need 2 know wat the ip address is for hp deskjet F380 is
hi cooldude,
this printer comes with a USB port for connecting to your computer. Unless you have the printer connected to an airport express base station, the printer will not have an IP address.
Let me know what you want to do and I can help you further. Do you want to share the printer so you can print from other PCs over your network?
Hope this helps
Tom
Jul 22, 2011 | Office Equipment & Supplies
Wat is ip address
The IP Address is the number or ASCII character representing a Web, presence. Every connection to the internet needs a specific "Identifier" this is a unique number or characters used to describe the connection. A bit like a "Telephone Number". http://www.whatismyip.com/faq/what-is-an-ip-address.asp
All explained above.
May 21, 2010 | Microsoft Xbox 360 Console
Laptop won't connect to wireless internet
wat is the Ip address
default gateway
????? Fast reply needed for a quicker resolution
Mar 18, 2010 | Google Chrome
WAT IS THE IP ADDRESS
that would be the address that allows you to connect to the internet on your phone .. its mainly used through your wireless carrier to provision you account for the internet
Nov 18, 2009 | LG Shine KE970 Cellular Phone
Can't print
hi,
WPA keys is security key for ur network and when u run the wireless setuo wizard, use the key pad on the printer to punch in the WPA or WEP key.......
or
if u were using ur printer before wirelessly, then u should still have the ip address stored on   ur printer,
1) print network configuration by setup menu of the printer (setup>>network>>veiw network settings>>print network configuration page)
2)it will print out, in that u will have ip address.
3) go to priner and faxes, right click on the printer icon and go to properties and under ports tab, click on configure port and change the ip addres for the ip address wat u have if that doesnt work, click on add a port and select standard tcp ip port and new port at the bottom of the window and entry the ip address and proceed with that,,,,,,,,,,,it should resolve ur issue....
Regards,  raj_p5983
Jan 21, 2009 | HP Photosmart C6180 All-In-One InkJet...
Website for Dlink
D-link uses more than one default IP address for it's products.
The default IP address for D-link router is 192.168.1.1
BUT - the factory default IP address for the WAP54G i.e. is 192.168.1.245!
To be sure: check the CD that came with your router. Usually it contains a .pdf file with the necessary information.
Dec 24, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Website for login for admin and stuff
you need to type the routers IP address into the browser. to find the address, be sure you are connected to the router (preferrably with a cable) then go to start then RUN then type CMD then hit ENTER
at the black window that pops up...type IPCONFIG then ENTER
the GATEWAY ip address is the router location. type that in the Internet Explorer address and it should prompt you for the login.
Still no gud
you need to enter the static ip address of your ps3 to the router's page where you forwarded the port numbers. click here for the illustration
try to open these ports as well for gta4
UDP ports: 6672, 28900
TCP ports: 8000-8001, 27900, 28900
if you're still getting the same problem, set your router to dmz
hope this'll help you
ciao!
Aug 29, 2008 | Netopia 2247NWG-VGx Wireless Router...
Wireless 3crusb10075 problem
Sounds as if your router may need to be set to enable wireless connection and enable DHCP, this alocates your wireless adapter an I.P Address automatically. If this is alraedy the case, check the properties of your adapter to see if it's set to recieve I.P address automatically. If still no joy find your routers I.P. address and DNS address (this is what you type in your web browser to set it up). If your router is 192.168.2.1 or similair, set your adapter at 192.168.2.2 and the same DNS address normally 255.255.255.0. Restart both pc and router and try again. Also make sure network sharing has been set up via the XP wizard.
Dec 14, 2006 | 3Com (3CRUSB10075) 802.11g/b Wireless...
Open Questions:
Just purchased a TTX Tech wireless PS3 controller that comes with a USB key fob that connects to one of the front USB ports of my PS3 console. I have successfully synced it to my PS3 only issue I'm having is how drastically different the configuration is from the usual sixaxis controllers. I noticed between the 2 controllers there are 2 clear differences amongst them. 1 being the trigger buttons are not the same and that the circular circumference for the analog sticks are alittle bit different in size. Basically comparing the size of a 25cent coin to a 5cent coin. I'm assuming because of the analog having less of a left to right and or a up and down travelling distance due to the difference of having a smaller analog circle that it could very well change the sensitivity aspects in the game of choice (COD Black ops 2) but I mean the difference between the two controllers is beyond noticeable I've experimented with lowering the sensitivity level from what was set when using the sixaxis controller compared to when using the TTX Tech controller. For example using the sixaxis I'm set to 13 for my sensitivity but when switching to the TTX Tech to become even close to having the same feel and view while using it in comparison to the sixaxis i have had to lower my sensitivity level to an 11 or a 10 instead of the 13 and yet it still is quite noticeably different from my sixaxis controller. Also I've found that the right analog for the TTX Tech is extremely sensitive gently applying upward downward and also side to side pressure on the analog causes a significantly noticeable jump or jolt that seems to never differ in speed regardless as to what has been set for the sensitivity level in game settings. In a nut shell basically I'm asking if anyone else has noticed these things I'm experiencing and if there may be a configuration manual or program that could some how configure the TTX Tech controller to act more as if it were a sixaxis controller in the aspects of the analog sensitivities and responding timing. Yes of course a new controller with a different shape and or feel will make for a "getting used to it" experience which does generally occur after a time period of using said controller more and more often. I am more or less meaning whether or not the smoothness and or the rythem you would have with one controller be more similar with one another. If anyone is a gamer and has gone from using a normal typical original PS3 controller and unfortunately having it be no longer able to be used to play games and switching to the TTX Tech controller immediately afterwards I'm sure will know exactly what I am trying to explain. Appreciate any insight and or knowledge towards my inquiry. Thank you kindly for the assistance and of course take it easy or take it any way you can get it :)
Oct 19, 2019 | The Video Game Consoles & Games
Video Game Consoles & Games Logo
57 people viewed this question
Top Video Game Consoles & Games Experts
Ekse
Marvin
Marvin
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
