Question about Cobra microTALK LI6000-2 (14 Channels) 2-Way Radio
I cant get the range mine has specified it says i think 12 miles but i cant get it to go over 1 mile
  • Anonymous Nov 02, 2008
    Have gone about 1 mile; they are all the same, even Radio S.
    Sergeant:
  • 250 Answers
Hello stumpy24586,
The range that you can expect to see when using two-way radios is very dependent on local conditions. These radios use UHF frequencies, which are very line-of-sight dependent. Obstructions like mountains, hills, tall buildings, thick vegetation (like forests), and using the radio in a shielded environment such as inside of an automobile can block your line of sight and limit your effective communications range.
The Cobra radios in question specify a maximum communications distance of approximately 17 miles. That kind of range is probably only practical in a situation where the user of one of the radios has some significant elevation (such as being on top of a tall hill) and therefore has increased line of sight. When communicating over relatively level ground that is clear of obstructions, you can probably expect a reliable communications range of 1-2 miles.
Best Regards,
Agent Ken
Go Ahead. Use Us.
Posted on Apr 07, 2008
SOURCE:
Mrs. Escalante was riding a bike path . After riding 2/3 of a mile, she discovered that she still needed to travel 3/4 of a mile to reach the end of the path. How long is the bike path
Addition of fractions requires the use of the lowest common denominator.
2/3 + 3/4 = 8/12 + 9/12 = 17/12 = 1 5/12 of a mile.
Feb 01, 2018 | Motorcycles
Convert 5400 inches to mile
0.08522727 of a mile.
5280 feet per mile x 12 (inches per foot) = 63,360 Inches per mile
5400 inches divided by 63,360 inches per mile = .08522727272 of a mile. Rounded up to .09 of a mile which is 9/100 of a mile or a little less than 1/10th of a mile.
Aug 30, 2017 | Office Equipment & Supplies
What is the top range of the two batteries, in miles?
the range in miles of a mobility scooter depends on make model and battery size and is usually found in owners manual.
the quoted range as example quoted at 12 miles usually means aprox 12 miles on a flat road with a weight of around 11 stone
hill climbing and any weight over 11 stone will reduce this max range considerably.owners manuals are avail online and from mobility centers and scooter manufactures,
Nov 30, 2014 | Health & Beauty
Motorola mj270r no range
Handheld radios talking line-of-sight with no obstacles will communicate approx. 2 miles. When talking from inside a building to outside, you can expect 1/4 to 1/2 miles range. Holding the antenna perpendicular to the ground gives you the best range. Height and placement of the antenna determines range. If you were on a mountain you could talk many miles into the valley below. However, in real world applications, range is limited. It can even be limited by the body fluid of the person wearing the radio on their hip, or blocked somewhat by the metal of the automobile one is riding in.
Channels 18-22 are listed as GMRS channels and may have more power than 1-17. The FRS channels are limited to 1/2 watt. But don't be fooled wattage doesn't equal distance. Higher wattage may give you a little more distance, but mostly it will give you clarity in the fringe areas.
Here is a link to the user guide: http://www.motorola.com/web/Business/Products/ConsumerTwo-WayRadios/Talkabout-MJ270R-Two-Way-Radio/_Documents/MJ270.pdf
A link to Motorola's page about the radio: http://www.motorola.com/Business/US-EN/Business+Product+and+Services/Two-Way+Radios+-+Consumers/MJ270R_Talkabout_Two-Way-Radio_B2B_US-EN
And I see where they are quoting 27 miles*, and go on to say:
*How far can I expect my radios to communicate? The communication range quoted is calculated under optimum conditions, with an unobstructed line of sight. Actual range will vary depending on terrain and conditions, and is often less than the maximum possible. Your actual range will be limited by several factors including, but not limited to, terrain, weather conditions, electromagnetic interference and obstructions.
Unfortunately, we are seldom in idea conditions. Radio-to-radio is going to get you 1/4 mile to 2 miles in real conditions.
Best regards.
Feb 24, 2013 | Motorola MJ270R Talkabout 2-Way Radios...
I can't find the manual, and I was wondering how far away you can talk on the BellSouth Walkie Talkies Model 2252?
The range of the BellSouth 2252 will depend on the frequency and the surrounding environment. If you get the FCC license and operate in the GMRS range, then the radios will have a maximum of a 2 mile range. The surroundings will matter: hills, buildings, etc. will shorten the range.
If you are using the FRS frequencies, your range will be significantly shorter (again depending on the surroundings). I'd guess no more than 1/2 mile line of sight.
I hope this helps.
(who uses another brands of two-way radios and the ones with a 5 mile GMRS range work over 1/2-3/4 of a mile depending on hills. The ones with a shorter range can't communicate with someone at the far end of the property. It's about 3/4 mile from the road to the back fence.)
Jul 14, 2011 | BellSouth 2252BK (22 Channels) 2-Way Radio
I just bought the gmrs 1262 ch and it says up to 12 miles... im not even to miles away from the other one and we cant hear each other... we are on the same channel and everything... HELP PLEASE!!!!
Assuming you have purchased a "bubblepack" type radio, you have a have joined many being mislead about the claims of distance on these type radios. Typically FRS/GMRS Radios claim the have 10, 12, or even 15 mile range. In the fine print however, you will see that it is dependant on conditions such as terrain, buildings, weather conditions and so forth. Most of these high distance ranges can be obtainable with no objects or terrain interfering with a direct path from one radio to another. The transmit power on these radios are also limited to 1/2 watt to 1 watt. Not a lot of power to get very far with less than ideal conditions.
A radio with at least 5 watts output may be more ideal depending on the intended use.
Dec 10, 2010 | Radio Communications
I have a 2001 Grand Jeep Cherokee w/over 100K miles. Am I better off trying to get some form of extended warranty, or just have whatever they recommend for 100K miles (per owners manual). The warranties...
I think extende warranty is just a precaution and it might not be so much useful if you are mainting it properly with specified service at specified miles...So keep driving and do the specified services when it reaches specified miles as per owners manual..
Dec 20, 2009 | 2001 Jeep Grand Cherokee
HOW FAR IS THE DISTANCE THAT YOU CAN HEAR ON THE MOTOROLA TR50? I LOST MY OLD MANUAL
Typically handheld radios will talk line-of-sight up to 2 miles. Obstacles you put between the two radios can absorb part of the range. Talking from inside to outside of a building you may only get 1/4 to 1/2 mile. Height and placement of the antenna determines range, so the higher you are the further you will talk. If you were on a mountain top and talking to the valley below, you could talk as far as you could see, which might be significantly more than the 2 miles you would get in normal terrain. (I think the box advertises up to 5 miles, but this would be under ideal conditions, and is not realistic.)
Aug 08, 2009 | Motorola Radio Communications
1/2 mile range max
Advertising on these models is much like reading about a car's MPG, it must be in perfect conditions. Handheld radios generally will talk "radio-to-radio", "line-of-sight" up to 2 miles. Once you start putting obstacles in between the radios you will shorten your range. Even the body fluid of the person wearing the radio on their hip will absorb some of the range. Talking from inside of a building to outside you might expect 1/4 to 1/2 mile. Good rule of thumb: Height and placement of your antenna determines range. The higher the antenna, the further you can talk. If you are talking from on a mountain top to a valley below you can talk as far as you can see. Increasing Range: Hold your radio perpendicular to the ground, not slanted like you would hold a phone. This problem alone could decrease your range 2/3s. Face the direction you are wanting to communicate. Don't shout CB-style, shouting reduces talk-range. Lastly, use good batteries. This will ensure your transmit capability.
Jun 08, 2009 | Radio Communications
50 to 100 mile range
Any sports store like Cabella's, Gander Mountain,
Read what it says on the package?
Nov 03, 2008 | Motorola Walkie Talkie 2-Way Radio
Cobra microTALK LI6000-2 (14 Channels) 2-Way Radio Logo
193 people viewed this question
Top Cobra Radio Communications Experts
Steve Allison
Steve Allison
Chris
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
