My thermostat says its time to replace the battery, but I don't know how or where the battery is located.
  • 236 Answers
It maybe found in front of the remote control, just slide the front cover and and detach.
Posted on Apr 06, 2008
Location of thermostat for 2007g6
The thermostat is located in the thermostat housing which is in the radiator return line...
Zooming link: Image 1
Zooming link: Image 2
You will loose all the coolant when you remove the thermostat. We use a vacuum coolant fill device to remove the air from the cooling system and **** new coolant back in. I don't expect you have this so you will have to improvise. Fill coolant into block through upper radiator hose at radiator.
Hope this helps and just keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa.
Jose (ZJLimited)
Nov 03, 2011 | 2007 Pontiac G6 GT Convertible
Tip
How to Replace a Thermostat in a Fridge?
If there cooling and defrosting problem in your fridge. Also over cooling or not getting cooling properly problem. Then the problem relates to thermostat.
The procedure to replace the thermostat is as follows: ---
1) First of all unplug the fridge/refrigerator unit from electrical outlet for complete safety.
2) In top freezer and bottom refrigerator model units. The thermostat is located at the rear of freezer side. But in some units its located in the bottom of the refrigerator floor panel.
3) In side-by-side refrigerator the thermostat is located at the back of the freezer side.
4) To remove the thermostat you will have to remove the screws from the icemaker section located in the freezer section.
5) After the screws from the freezer’s inner section are removed. The inside panel will get loose and come out.
6) Many a time the screws are hidden under rubber type butches. So its bit hard to locate the screws. So check out properly that all the screws in the inner section are properly removed.
7) After the inside panel of the freezer section is removed. You will see the thermostat. It has wires connected to its terminals. Be care full that you don’t pull out any wires. They are very thin and delicate wires.
8) The wires are connected to the thermostat by a connector. So slowly remove the connector from the thermostat using a needle nose pier. Take care you don’t put any force while doing this. It’s very delicate but not very hard to do.
9) After the wires are removed. Remove the screws holding the thermostat .In some models the thermostat is screwed to evaporator coil tubes. In that cases take care you don’t damage the tube while removing the screws holding the thermostat.
10) Before removing the thermostat take care you note down the position of old thermostat. so after the old thermostat is removed out by removing the screws. Place the new thermostat in the same exact position.
11) Refit all the parts which you removed while removing the old thermostat in reverse method. Take care you don’t miss any part fitting.
This will help. Thanks.
on Mar 20, 2010 | Refrigerators
I need the locations of thermostats
Not quite sure when you say thermostat"s". or what size engine you have but what I went on and did was give you the location of the cooling system thermostat for the most common engine for a Trailblazer for your year (4.2 liter). If this is the one, just letting you know that that thermostat comes as a complete unit water outlet and thermostat together. they don't sell it separate. Hope this is what you were looking for and I hope this helps.
Sep 13, 2011 | 2004 Chevrolet TrailBlazer
How much should it cost to replace a thermostat in a 2004 trailblazer? Part? Labor?
The part is only $20, everything else is labor. Probably a 2hr job at most shops. Could be anywhere from $300-$500. If you have tools and are okay working on cars, you can do the job yourself and save a bundle. Should take you around 3-4 hrs. You have to remove the alternator, and its helpful to also remove the battery and battery box to get good access to the thermostat. Good idea to also replace the ECT (engine coolant temperature sensor) at the same time since it is right above the thermo. Also a good time to replace your lower and upper radiator hoses. If you do the job yourself, don't forget to get some dextrol 50/50 to replace the coolant you lose when removing the thermo. 1-2 gallons should be enough, if you don't use what you get you can always return it unopened.
Sep 09, 2011 | 2004 Chevrolet TrailBlazer
I wan to replace the coolant thermast, bu I don't know where the coolant thermastat is located.
if you want to replace your thermostat for the coolent it is located off the upper hose from the radiator going into the top of the motor. you will have to remove the hose from the housing then remove the housing itself and the thermostat will be sitting right there on top. make sure you remember whitch way its faceing so when you replace it you dont sit it down backwards or upsidedown.. also its a good idea to disconnect the battery because you should have ground wires running to the housing. make sure you have the proper gaskett also.. if you need to see it done first go to youtube videos and just type in changing thermostat there are alot of good videos that should help you out... i hope this helps get you going in the right direction..
Jun 02, 2011 | Mitsubishi Eclipse Cars & Trucks
Where is the thermostat located for the 1997 bmw z3 roadster 2.8 engine
It is on the front of the head, facing the radiator.
Follow either big radiator hose, they are both attached to the thermostat housing.
Your thermostat housing is probably plastic. If so, don't re-use it because plastic housings of that vintage shrink and warp. Buy a new plastic or aluminum thermostat housing.
On a car this old, consider replacing every plastic or rubber part you touch, unless you know that the part has recently been replaced. I have a couple of '97 328s, and I never put a plastic or rubber part back on the car without replacing it. Saves a lot of time and repairs down the road.
May 15, 2011 | BMW Z3 Cars & Trucks
Thermostat says lowbat.....where is the battery and what kind of battery do i need to replace? will my furnace still come on?
If you replace the battery in time, the furnace should still work. You didn't mention what type thermostat you have, but the battery is located inside the thermostat housing. Most can be accessed my opening the flip down cover of the front of the thermostat (this where you generally program it). Inside you will either see instructions for replacing the battery or you will see another small compartment door with a battery icon on it or it says "Battery". If none of that appears as stated, the batter will be behind the thermostat housing. It's generally 1 AA Battery.
Hope this helps you solve the problem.
Mar 09, 2011 | Goodman Heating & Cooling
I need to know where the thermostat goes on 2002 jeep liberty 6cy?
just left of the crankshaft pulley
  1. Disconnect negative battery cable at battery.
  2. Drain cooling system.
  3. Raise vehicle on hoist.
  4. Remove splash shield.
  5. Remove lower radiator hose clamp and lower radiator hose at thermostat housing.
  6. Remove thermostat housing mounting bolts, thermostat housing and thermostat .
To install:
  1. Clean mating areas of timing chain cover and thermostat housing.
  2. Install thermostat (spring side down) into recessed machined groove on housing assembly. Make sure rubber seal locating tab is positioned in the corresponding notch in the housing.
  3. Position thermostat housing on timing chain cover.
  4. Install two housing-to-timing chain cover bolts. Tighten bolts to 105 inch lbs. (12 Nm) torque.
  5. Install lower radiator hose on thermostat housing.
  6. Install splash shield.
  7. Lower vehicle.
  8. Fill cooling system.
  9. Connect negative battery cable to battery.
  10. Start and warm the engine. Check for leaks.
Oct 04, 2010 | Jeep Liberty Cars & Trucks
Fig. The location of the thermostat and its housing on the 3.7L engine
To install:
  7. Lower vehicle.
Hope helps (remember rated and comment this).
Aug 06, 2010 | 2002 Jeep Liberty
CHANGE THERSTAT ON 2002 JEEP LIBERTY
3.7L Engine - Thermostat
    Fig. The location of the thermostat and its housing on the 3.7L engine (click for zoom)
To install:
  7. Lower vehicle.
Hope helps (remember rated this).
Aug 04, 2010 | Jeep Liberty Cars & Trucks
Heating & Cooling Logo
53 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
