Question about Optoma H30 Multimedia Projector
Optoma projector image yellowing
Hi, I thought we may need to change the lamp, but when we asked a theater shop they said we need to get the projector serviced.
The image on the screen is yellowing, can you tell me which issue it is, lamp to be changed or a service of the projector?
Thanks,
Rachel
    Champion:
  • 205 Answers
Very odd problem. Depending on the hours of the projector it could have some glass in it that over heated. Contact Optoma directly, my guess is they will work with you.. good luck
Posted on Jul 09, 2009
SOURCE:
What is the dmd?
Hello Anonymous,
A DMD is a chip with thousands of tiny mirrors that change angles in order to block or let light through, creating the image you are viewing. Texas Instruments has a great video and explanation here: DLP MEMS
The spots could definitely be caused by a malfunctioning DMD. As much as we would like your business, you will be better off purchasing a new projector. You can try searching ebay for a used working version of the projector so you can utilize the hours on that new lamp (there is currently one for sale for $125 on ebay). If you want to get a new projector, I recommend a website called Projector Central (Projectors Projector Reviews LCD Projectors Home Theater DLP Projectors...) for research on finding the right match for your needs.
In the future, if you have any repair or lamp needs, Mentronix repairs and stocks lamps for over 30 brands of projectors.
Mendtronix Inc AV Services LCD DLP Projector Repair Multimedia...
Jun 05, 2014 | InFocus IN2102EP Projector
Powering up
the projector is quite good and may not have any internal defect
may the bulb has really burnrd out......
try a new bulb if it works or not
Oct 15, 2008 | Sony VPL-HS20 Multimedia Projector
Runco picture upside down
Yes possibly because you have done a complete system reset and not a lamp hour reset so you will need to go into image or screen settings and select front view ceiling mount configuration
Apr 14, 2013 | Office Equipment & Supplies
Hi. I have a InFocus dp2000x. It has no lamp. I try with a flashlight in the lamp chamber (the flashlight is battery operated) When I turn on the projector with a vga or video input, the power led start...
Projectors are designed to be used with a lamp and will turn off when there isn't one present. You would have to purchase a new lamp to use the projector.
Feb 19, 2011 | ASK Proxima Proxima DP2000X Multimedia...
Good morning, I have an interesting issue with my Epson 6100 Powerlite home theater system. I wish to remove the original lamp in the projector and then replace it with a Photographers Flash/modeling...
All projectors have a safety switch for the lamp door. Locate it and just by-pass it. It sounds like you have the knowledge so let's go for it..
Aug 19, 2009 | Televison & Video
PT-L735 U projectors. Green screen and stretched
The green is the result of the blue device failing. Happens about 4000 hours or so. LCDs can't handle the heat. Check the scaling of the image of the second projector. 16x9 vs 4x3.
good luck
Jun 25, 2009 | Panasonic PT L735U Multimedia Projector
Projector won't switch on
You may have a failed power supply or a blown lamp. If you have access to a spare lamp, try changing it. (as described in the user guide). If you know the lamp is good for sure, then it is better to call service folks.
Aug 23, 2008 | Audio Players & Recorders
Colour misalignment and focus
If you feel dull image and any yellow color problem you can change the lamp other wise no need to change the lamp.
There will be patten settings are there. so please inform service center service engineer will do this job.
Regards,
Prakasam
Feb 17, 2008 | Office Equipment & Supplies
Infocus lite pro 580
ballast or lamp. if there are excessive hours on the lamp, that's the one.
Oct 22, 2007 | InFocus SP-LAMP-LP5 Projector Lamp for...
Problems changing lamp
Try removing the new bulb and reinsert it and make sure it make a good connection. Be sure to follow your projector's instruction manual on how to change your bulb exactly.
May 19, 2007 | Eiki LC XNB3 Multimedia Projector
Optoma H30 Multimedia Projector Logo
146 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
