Question about Microsoft Windows XP Home Edition
My Outlook Express Won't work
Everytime I try to send out a message on my Outlook Express, it won't work. Error 998 comes up and Error No. ox800cocF6 and it says that Outlook Express is not supported on free hotmail anymore.
  • gil123 Jul 23, 2008
    asays the POP3,IMAP could not be found and the server name is not coorect
    Problem Solver:
  • 15 Answers
Sounds like it's self explanatory. Perhaps Hotmail is no longer free for Outlook Express. If you would like to use Outlook Express as your defautl email client and use a POP3 based email account, may I refer you to www.hotpop.com? You can apply for a free POP3 email account which you can set up to run with your Outlook Express. You may also want to check into www.gmail.com. They support web based inboxes as well as POP3 configuration for your Outlook Express.
Posted on Apr 06, 2008
SOURCE:
MAPI error message when import or export messages in Outlook Express
·You import mail from Outlook into Outlook Express, but you removed Outlook from your computer before you tried to import the mail into Outlook Express.
·You configure Outlook Express to be the default Simple Messaging application programming interface (MAPI) client.
·You import or export mail from Outlook Express, and you do not have Outlook installed on your computer.
To resolve this issue, try one of the following methods, as appropriate for your situation.
Method 1: If you want to use a special program you can use Outlook Express Fix Toolbox
https://www.fixtoolbox.com/outlookexpressfix.html
Method 2: Change your MAPI Settings
Configure Outlook Express to not be the default Simple MAPI client before you import the mail items. To do this, follow these steps:
1.Restart your computer, and then start Outlook Express.
2.On theToolsmenu, clickOptions.
3.On theConnectiontab, clickChangeto open theInternet Propertiesdialog box.
4.On theProgramstab, click an e-mail application other than Outlook Express in theE-maillist. ClickApply, and then clickOK.
5.ClickOKagain to close theOptionsdialog box.
6.Exit Outlook Express, and then restart Outlook Express.
You can now import or export messages.
May 31, 2016 | ErrorExpert
Outlook Express 6 - Address book failed to load
The WAB file may have become damaged or corrupted causing one or both of the above error messages. You will need to rename the existing .wab file and restart Outlook Express(OE). Once started, OE will create a new .WAB file. Microsoft does not recommend that you import the data from the old, damaged .wab file. If you do, you may import the damage into the new .wab file.
1. Click Start, point to Find (Search on Windows 2000 or newer operating systems), and click For Files or Folders.
2. In Search for files or folders named, type. *.wab and click Search Now.
3. In the Search results window, Right-click the file(s) with an extension of ".wab" and then click Rename.
4. Rename the file extension (the three left-most characters in the name) to "old" and press ENTER.
If you are still experiencing the issue after applying this fix you can try Address Book Recovery http://www.oemailrecovery.com/address-book-recovery.html
Aug 07, 2015 | Microsoft Outlook Express
Can't send emails in Outlook Express
Save yourself alot of headaches and use a web-mail service like Gmail.
Oct 27, 2014 | Microsoft Outlook Express
Outlook express won't let me read my emails. An error report box appears, and if I press send or don't send, it closes down outlook express.
This tool is able to recover your DBX file without need of backup file. So choose one repair method according to your requirement.
For more information visit:- Outlook Express Recovery DBX Recovery Software
Dec 14, 2012 | Microsoft Outlook Express
Not receiving or sending at start in outlook express
To fix this issue you can follow the
below mentioned workaround :
- Check your Internet and Outlook
Express account settings and double check that you have entered the
correct password and user name.
- Check your Firewall and Anti-virus
settings as sometimes this blocks the sending and receiving of
messages.
- Check if there is a corrupt
message stuck in your Outbox.
- A corrupt Outlook express dbx file
may also cause this issue so it is required to go for solution.
regards
jane
Jan 25, 2012 | Microsoft Update for Outlook Express 6.0...
I can send email messages via outlook express, but I cannot receive them. I get an error message. This started to happened after installing McAfee Internet Security on my Dell pc with Windows XP SP3. I...
The registry from McAfee that blocks your incoming mail could still be working... Try running a registry cleaner. Try Ccleaner @ www.ccleaner.com
Mar 17, 2010 | Microsoft Outlook Express
Outlook express is trying to send a message with a lot of photos attached. It is unable to do this. How can I delete this message.
If your Email is trying to send as soon as you start Outlook Express, you might try this:
Open Outlook Express and go to the top menu, click TOOLS then under that menu, OPTIONS. Under the GENERAL tab, uncheck the box for "Send and receive messages at startup", then click OK.
Close Outlook Express and start it up again. Hopefully this will allow you to delete the Email. Good luck!
Sep 15, 2009 | Computers & Internet
How to slow this problam
i had the same problem, on both of my computers all of a sudden, i went to hotmail and logged in and it was fine, but outlook express wouldnt work. go to help central at the bottom of the page and then type in outlook express. you can actually load hotmail into a pop3 and smtp account rather than an imap. follow this link if you can
http://help.live.com/Help.aspx?market=en-US&project=MailClassic&querytype=topic&query=WL_Mail_PROC_HMOE.htm
follow the instructions. easy. you wont get your hotmail folders, and make sure that you check the box that says keep copy of messages on server.
Sep 03, 2009 | Dell Computers & Internet
Outlook express6
if you are trying to send an email from an old isp mail account, using a different isp email connection; you have to change the mail.smtp settings, for the settings you will need to refer to your isp. If you are trying to send an email using a hotmail account, this can no longer be done as hotmail no longer allow the use of outlook express with their accounts
Apr 07, 2007 | Toshiba Satellite M45-S169 Notebook
Microsoft Windows XP Home Edition Logo
661 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
