Question about Kenmore Elite HE4 Electric Dryer
Dryer screen My screen only has one little corner that ever has lint in it.We had to clean out the whole bottom of our dryer from lint.We replaced our heater coil. Cleaned everything out,But my lint screen always only has a small amount of lint in one small corner.Does that mean my whole under-half of my dryer will fill up with lint again? There are no holes in my screen?
  • s9421 Jan 24, 2009
    I have the same problem with a maytag. However, what is strange is that I used to always have a ton of lint on the lint screen and now barely any. I removed the vent hose from the dryer and the wall and cleaned everything, but the problem persists. Where is all the lint going if not in to the lint trap. How can I determine if it is accumulating in somewhere in the dryer?
  • 5,911 Answers
No. The accumulation of lint in the dryer screen generally doesn't have anything to do the amount that ends up INSIDE your dryer. Too little lint is not a bad sign. It's dependent upon the type of clothing you are drying as well. If the clothes are not "lint givers" (like cottons and wools), you generally won't see a lot of lint in the dryer screen. Dryer screens are not perfect, either and some lint always gets through. As long as there are no holes in the screen and you have it seated correctly, and you clean it after each use, you shouldn't have any problems.
What affects dryer performance the most, is your vent hose and routine cleaning. The simple rule of thumb is: The SHORTER and STRAIGHTER the vent hose the BETTER. The vent hose should also be cleaned thoroughly periodically. I recommend once per season. That's about 4 times per year. What causes the lint to back up into a dryer is when the vent hose becomes kinked or clogged. The lint is mixed with moist air when it leaves the dryer. If it has no where to go, it starts to accumulate and stick in areas of the vent hose that are sagging, or at tight bends. Eventually, the vent becomes so restricted that the lint ends up inside your dryer. This causes the heating circuits to overheat to eventual failure. Not to mention, accumulations of lint inside a dryer can cause a fire. I have personally inspected dryers that were so full of lint that the dryer hose contained about a gallon of water from condensation and the inside showed evidence of multiple fires. If you need further info, I have an article I wrote up explaining all of this under "Tips and Tricks" under my profile. I hope this helps you.
Posted on Apr 06, 2008
SOURCE:
How do I get into my whirlpool duet front loader dryer to clean the lint out
Hello. First, turn the power off to the dryer or remove the power cord from the AC outlet. Next, locate the 2 screws in-between the upper and lower front panels and at the bottom front of the dryer--there will be 2-3 screws, usually 1/4 inch hex head, and remove them--use a magnetic nut driver, it makes it a whole lot easier! (note:sometimes, to replace the panel, you have to push up on the bottom of the panel hard to get the screw holes to line up again.) Set the panel aside. Open the dryer door and remove the lint screen from the holder. Close the door. Next, notice the blower housing cover, pic 3, #45, lower left corner. There should be 3-4 screws holding the cover to the blower housing. Remove the screws and cover--use caution--most metal edges inside a dryer are unfinished and razor sharp--akin to putting your hand inside a box of razor blades(ask me how I know this, lol). Remove any lint build-up inside the cover with a vacuum. Again, using a vacuum, suck out any lint from inside the blower housing and fan as best you can. Take care to not damage the fan blades! Now, try to remove as much lint build-up as you can with the vacuum. Be especially careful when vacuuming around the mouth of the heater element. Do the best you can. At this point, re-assemble the dryer using the reverse of assembly. If there is still a lot of lint inside the cabinet and you can't reach it--STOP! In order to remove the remaining lint requires removal of the front bulkhead(large metal plate that supports the front of the drum), drum belt, and drum from the cabinet. This is INVOLVED and can be very difficult to re-assemble if you have never done it before. Call for service. I hope I helped you!
Oct 02, 2015 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Clothes not getting dry
sounds like perhaps you are losing your heating element...could be electronic, but it's most likely the actual element needs to be replaced...
Apr 25, 2008 | Whirlpool GGQ8831L Gas Dryer
Where is the air intake on an electric cloth dryer
This link is to a video about cleaning a blower box lint trap housing of a Whirlpool , Frigidaire or Kenmore dryer..
There is a good view of the back of this dryer. Other than the controls and trim all of these models and makes are nearly identical.
As viewed from the back the air intake is at the lower right. The air enters the bottom of the heater flows through the heater coils into the dryer drum out of the dryer drum into the lint filter blower box into the blower and is expelled out into the dryer vent pipe.
There are other makes that may be different. On some LG dryers the blower is located at the front bottom left of the machine.
There are lots of help videos on youtube.
Whirlpool Kenmore Dryer Repair Remove and Install the Blower Box Lint...
Aug 01, 2014 | Frigidaire Clothes Dryer Thermostat...
Dryer not drying cloths even though it does the full cycle? hotpoint wd63
There are several reasons for this to happen.
  1. Heater element faulty.
  2. Thermostat faulty.
  3. Heater relay faulty.
  4. Blocked condenser.
  5. No cold water going in on drying cycle.
You really need a meter to test the components with, to get the bottom of the problem.
Please rate my solution.
Thanks.
Nov 16, 2009 | Hotpoint Aquarius WD63 Front Load...
Lint screen holder is full of lint
Yes, clean it out immediately. The lint screen should pull right out with no screws holding it. It should be cleaned every other load!
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Sep 25, 2009 | Magic Chef CYE4000AWW Electric Dryer
Cleaning lint
Your Roper dryer is made by Whirlpool, there is no reason to clean lint from around the heater, very little lint collects in that area. Every once in a while you can take the front off by removing 2 screws from under the lint screen, then pry up the top and there are 2 screws that hold the front on inside facing out. After removing the front you can vacuum inside below the drum.
Jan 18, 2009 | Roper REX4634KQ Electric Dryer
Heat wont stay on
remove front to get to burner remove screws under lint screen on top press clips each corner of top remove tne screws each corner inside top front panel.if lint screen in door frame press clips each corner bottom panel ..replace the 2 black coils on burner
Dec 01, 2008 | Whirlpool Dryers
Dryer will not start.. Here clicking sound when i push start button but nothing happens
Did you clean the lint screen and replace? Also - all lint should be cleaned from back of dryer and the duct...many dryer manufacturer have safety sensors that will not light dryer due to there being too much lint, not enough air flow...(safety feature) ...
Oct 09, 2008 | Kenmore 62602 Electric Dryer
Blown thermal fuses
I would think not. The MAIN cause of that fuse blowing is lint build up. Turn the dryer on and put your hand on the outside of the vent duct. Is the air blowing hard? If so, you will probaly be ok, if not maybe your blower wheel needs to be replaced...
Dec 15, 2007 | Whirlpool LER5636P Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
412 people viewed this question
Top Kenmore Dryers Experts
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
