Question about Whirlpool LGR7646E Dryer
Whirlpool Lgr7646eq2 Dryer
Hi All,
I have a dryer (gas) it spins and blows but no heat is coming out what should I look for...
alex
  • Mayshilon Apr 11, 2008
    Same problem was this question answered?
  • Anonymous Sep 09, 2008
    spins but no heat
  • 943 Answers
Hi thanks for the question. most times the problem is with the thermal fuse . failure is caused by clogged venting. clean all vents . the thermal fuse is located on the air duct, inside the dryer on the left , a small piece of plastic, with 2 blue wires to it . replace thermal fuse. thanks the appliance doc
Posted on Oct 06, 2008
My Gas whirlpool dryer model # LGR7646EQ2 wil not heat up.
Sounds like a thermal fuse. Follow link to part # and more details. Best of luck!
Whirlpool Thermal Fuse
Apr 07, 2012 | Whirlpool Dryers
Whirlpool lgr7646eq2 dryer is not heating up. I checked the valve its open. any suggestions?
dependind on how old of model your hsi might need to be replaced (as valve im assuming its a gas dryer)
Sep 13, 2010 | Whirlpool LGR7646E Dryer
My whirlpool dryer LGR7646EQ2 dryer heats but will not shut off
will it shut off on timed dry?
if it does the sensor dry board or sensor are bad
if not the timer is
Jun 08, 2010 | Whirlpool LGR7646E Dryer
My dryer works (spins, blows air) but it won't hea...
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 19, 2010 | Dryers
Whirlpool Craetions Dryer AWZ129: No Heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
May 15, 2010 | Whirlpool LER5636P Electric Dryer
Heat will not stay on
Hi, very common problem.
The problem is with the gas coils.
When they get weak, they only come on for about 10 minutes and then the machine will blow cold air. There are 2 of them with one being the booster coil. They come in a pair and run less than $20.
Best of luck. Please e-mail me if you have any other questions.
Sep 15, 2009 | Whirlpool LGN2000LWH Gas Dryer
My gas whirlpool dryer won't heat. Cool air does
Hi
Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats, motor heat switch, timer, selector switch, sensor.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 06, 2009 | Whirlpool Dryers
No heat
Should be a cover about the size of a quarter on the front lleft bottom...pop off with a small screwdriver and start dryer....look inside and see if the glow bar lights up...if glow bright orange, probably good, may need gas solenoids or ignitor
Jun 10, 2009 | Whirlpool LGB6300 Gas Dryer
Dryer not heating up
replace the two selniods on the safty valves
May 15, 2008 | Kenmore 74602 Gas Dryer
Dryers Logo
495 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
