Question about Consew 199R-2A Sewing Machine
Thread is bunching up and I cant remember which knob will releave this problem.
  • 130 Answers
If the thread is looping on the top, then the problem is with the bobbin,, If the thread loops on the bottom, the problem lies in the threading.
Posted on Apr 21, 2009
SOURCE:
Why is sewing machine thread gathering under fabric?
adjust the tension to a appropriate setting,
See the video here.
Sewing Help Sewing Machine Problem Thread Bunching Under Fabric
The knob and its location can differ based on the model of your sewing machine.
Oct 29, 2016 | Sewing Machines
When i try to use it it doesnt thread with the bottom thread and bunches up and breaks the top thread. i cant find this model online!!: please someone help! dont know if i threaded properly
Possible problem is the bobbin inserted the wrong way round. I'm not familiar with this model, but if you've checked the upper threading, and it's still bunching, make sure the bobbin thread feeds off the bobbin correctly (e.g. either to the right, or to the left, as it's inserted). Hope this helps.
May 02, 2015 | Brother Sewing Machines
I have no tension at all on my singer 8734
try some unwaxed dental floss to clean the tension knob.
May 19, 2014 | Sewing Machines
The thread bunches under fabric when sewing on leather
WHEN YOU FIRST THREAD LEAVE THE FOOT UP AND PAY ATTENTION IF YOU ARE GETTING A SNAG WHILE YOU ARE THREADING. IF YOU ARE THEN FIND OUT WHERE THE SNAG IS AND CORRECT IT. NOW, LOWER THE UPPER FOOT PRESSURE. THIS MUST BE LOWER BECAUSE THE FABRIC IS SO MUCH MORE THICK. IF IT IS STILL A PROBLEM TAKE NOTICE IF THE BUNCH IS ON BOTTOM OR ON TOP. MORE ON TOP THEN LOWER TENSION. IF THE BUNCH IS ON BOTTOM THEN TIGHTEN THE TOP. START YOUR TENSION ON TOP WITH THREE. THE BOTTOM NEEDS TO BE CHECKED FOR PROPER TENSION. THE BOBBIN SHOULD JUST HANG FROM YOUR FINGER. IF YOU BOB YOUR FINGER IT SHOULD BEGIN TO EXTEND JUST A SMALL AMOUNT. JUST REMEMBER THE THREAD IS THICKER AND MUST BE ADJUSTED BECAUSE OF THIS.
Jan 10, 2014 | Husqvarna Husky 145
Singer 6038 tension dial not working
there should be small washers ( discs with a tapered flange to direct the thread between the plates ) if they are not under the spring behind the tension adjuster knob then that will be your problem
if they are there then check that the tread is between the plates and not behind them
missing plates are available from a sewing machine mechanic sgop
May 07, 2017 | Singer 6038 Mechanical Sewing Machine
Thread bunching up on the bottom
try changing the needle
rethread the machine top & bobbin
make sure the top thread has not come off the thread take up lever
clean under the needle plate & in the bobbin area for lint or loose
thread
Aug 23, 2012 | Sewing Machines
The thread on the bottom bunches up all down at the bottom than bunches up
Usually problems like this are caused by improper bobbin winding and installation, incorrect tension, the wrong needle for project, or simply not grasping the threads and gently pulling them backwards when you start a seam.
1. Make sure you are threading the machine correctly.
2. Check your tension.
3. Check the bobbin, make sure it's wound properly and that you don't have the bobbin in upside down.
4. Check for bits of fluff and thread in the bobbin race area.
5. Change your needle, they wear out, get bent, dull... etc. You should have several different types on hand at all times.
6. Grasp both the threads gently and pull slightly backwards when you begin a seam. this will assure that your bobbin thread doesn't get all bunched up under the fabric.
7. Always test tension, needles etc., on a scrap piece of fabric before you begin sewing your project.
:o) Smile... sewing is fun... remember?
Mar 04, 2011 | Singer 3116 Simple
Hi...i have been having trouble with my bobbin thread bunching up really bad underneath and causing the machine to seize up when i try to sew...it starts to do this just after a few stitches...i make sure...
Always remember that it is the opposite of what you think, it is your upper thread that is not threaded right, not your bobbin. Once you thread it right, you should be okay. You can buy a manual at sew4less.com for about $14.95
Jul 22, 2010 | Euro-Pro Sewing Machines
THREAD GET BUNCHED UP UNDERNEATH THE FABRIC, THE STICHES SEEM TO BE INCOMPLETE THE TOP LOOKS GOOD THAN I TURN IT OVER AND THE THEAD IS BUNCHED AND LONG LOOPS OF THREAD ARE LEFT. THANKS LOU
Hi Lou! This sounds like a tension problem--the tension on the top thread is too loose. Try using different color threads on the top and bobbin, then carefully rethread everything. Stitch a couple of inches and check the underside. If the top stitches look fine and the bottom ones are loose and loopy, and with the pressure foot down, tighten the tension. Move the knob or dial (whichever you have) just a little bit. Sew a couple of inches more, and recheck. Continue to sew and recheck, gradually tightening the tension, until you see little if any bobbin thread on the top or top thread on the underside of the fabric.
Let me know if this helps, ok?
Robbie
Jan 27, 2010 | Singer Sewing Machines
Wont sew thread bunches up
Hi!
I think you are threading the top of the machine incorrectly. Make sure that what I'm saying is correct, use two color threads to sew with- and you will see that it is in fact the top thread that is bunching.
This might be a tension problem. Could be the bobbin is not threaded in the case right. First, check the threading of the bobbin and then check the stitch.
Next, adjust the tension on the bobbin case. There is usually a small screw on the case that can be tightened or loosened. I think you may need to adjust it a bit or adjust the top tension knob, just a small bit at a time. It the top does not change the stitch, then go to the bobbin case and adjust the screw to tighten the stitch a little bit more.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jun 19, 2009 | Kenmore Sewing Machines
Consew 199R-2A Sewing Machine Logo
124 people viewed this question
Top Consew Sewing Machines Experts
Kelley Buchanan
Kelley Buchanan
TCHNICAL SUPPORT FOR...
Irene Tulloch
Are you a Consew Sewing Machine Expert? Answer questions, earn points and help others
