Question about Whirlpool LGR7646E Dryer
Whirlpool lgr7646eq2 Dryer
The dryer is workiing and spinging but no heat what should I check for it is a gas dryer
Alex
  • 1 more comment
  • Gagan2 Oct 18, 2008
    it is not heating up at all
  • scwisher May 11, 2010
    Does the pilot light?
  • Gagan2 May 11, 2010
    i have LGR7646EQ2 whirlpool dryer, it is not heating up at all. what should I check.
docjohn174
  • 943 Answers
SOURCE: Whirlpool Lgr7646eq2 Dryer
Hi thanks for the question. most times the problem is with the thermal fuse . failure is caused by clogged venting. clean all vents . the thermal fuse is located on the air duct, inside the dryer on the left , a small piece of plastic, with 2 blue wires to it . replace thermal fuse. thanks the appliance doc
Posted on Oct 06, 2008
My Gas whirlpool dryer model # LGR7646EQ2 wil not heat up.
Sounds like a thermal fuse. Follow link to part # and more details. Best of luck!
Whirlpool Thermal Fuse
Apr 07, 2012 | Whirlpool Dryers
Ignighter workis and burner has flame but will not keep burnner lit. speed queen dryer. made by RAYTHEON
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;
Aug 06, 2011 | Dryers
Whirlpool lgr7646eq2 dryer is not heating up. I checked the valve its open. any suggestions?
dependind on how old of model your hsi might need to be replaced (as valve im assuming its a gas dryer)
Sep 13, 2010 | Whirlpool LGR7646E Dryer
My whirlpool dryer LGR7646EQ2 dryer heats but will not shut off
will it shut off on timed dry?
if it does the sensor dry board or sensor are bad
if not the timer is
Jun 08, 2010 | Whirlpool LGR7646E Dryer
Whirlpool Craetions Dryer AWZ129: No Heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
May 15, 2010 | Whirlpool LER5636P Electric Dryer
No heat
Should be a cover about the size of a quarter on the front lleft bottom...pop off with a small screwdriver and start dryer....look inside and see if the glow bar lights up...if glow bright orange, probably good, may need gas solenoids or ignitor
Jun 10, 2009 | Whirlpool LGB6300 Gas Dryer
Whirlpool LP dryer will not light. model LGR7646EQ2.
the ceramic ignitor probably is broke. turnoff power and gas, then remove burner assembly ther are two screws holding it in. also loosen gas connecter .pull burner out an visibly check igniter you most likely will see the ceramic coil broken remove it and bring it and model # to a part house then reassemble burner
Jan 26, 2009 | Dryers
Dryer not heating up
replace the two selniods on the safty valves
May 15, 2008 | Kenmore 74602 Gas Dryer
Apr 06, 2008 | Whirlpool LGR7646E Dryer
Dryers Logo
347 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
