Question about Cobra 29 LTD CB Radio
Cb radio why does my antenna light com on everytime i key up my mic
    Scholar:
  • 66 Answers
Most of the time this indicates a bad swr. You may have a poor ground or a bad cable. See more about swr here:
http://en.wikipedia.org/wiki/Standing_wave_ratio
You may need to lengthen or shorten the antenna but you should have a swr meter to do this in the frequency you are testing. At radio shack they should have one for cb.
Hope this helped
You should refrain from transmitting until you get the swr down to about 1.2:1 or close.
Kevin
Posted on Apr 12, 2008
RED SWR ALERT LIGHT COMES ON WHEN I KEY UP
In most cases if the mic works the common cause is the transmitter in the mother board is shorting out or not soldered to the board properly. another cause could be that your antenna is too close to the CB and will disrupt the signal.
Oct 14, 2012 | Galaxy Radios DX-959 40-Channels Base CB...
It has a great dead key but when I key up you can barely hear me talk. even with he mic gain turned all the way up
  • Hi, I can help.
  • If you have confirmed your dead key being "great" the the two things that can be causing your problem is a faulty mic, mic wiring, mic connector (either on the CB i=or the mic connector itself.
  • Have you tried a different mic?
  • The other thing would be a bad antenna, antenna connection, SWR.
  • Have you tried a different antenna? Checked your SWR (with an inline meter)? Make sure the antenna connector (PL259) and the connector for the antenna on your CB (SO239) are in good condition and that there are no cold soldier joints.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thanks for using FixYa.
Regards, Tony
Sep 14, 2011 | Cobra 29 LTD CB Radio
29 LTD CB Radio: Calibrate cb radio...
The CAL is to calibrate meter for reading SWR (standing wave ratio) which is reflected power when transmitting back to receiver(radio) from antenna system.
This CAL switch position when selected and mic keyed uses the CAL knob to align the meter needle with inverted red triangle next to cal on meter. Then when you select SWR switch position meter will display accurately when mic is keyed for that channel. Now notice the difference when you go between channels 1 and 40. The ant led light will act as idiot light if it is not lit then you are most likely safe to transmit.
I say system because your vehicle, antenna and coaxial cable are all part of this system. When you have a high reading and have to trim you antenna this is really calibrating the antenna to the vehicles body which acts as a ground plane.
May 16, 2010 | Cobra 29 LTD CB Radio
With key on in acessary radio works [no antenna light when mic keyed up] with truck running antenna light on when key up mic
Wire the radio directly to the battery with extra heavy duty wire. Watch the polarity and try to run the leads away from the fuse box and route the antenna in a different spot on the truck....
Mar 06, 2010 | Cobra 29 LTD CB Radio
Tunning the antenna on radio shack cb trc-447
After installing the antenna, follow these steps to adjust the
standing wave ratio(SWR).
1. Turn on the CB.
2. Set S/RF/SWR/CAL to CAL.
3. Key the Mic and rotate SWR CAL so the meter points
to CAL.
4. Unkey Mic.
5. Set S/RF/SWR/CAL to SWR.
6. Key Mic again and note the actual measurement on
the SWR scale. Refer to the following table to interpret
the reading.
1:1 - 1.5 Great
1.5 - 2:1 OK
2:1 - 3:1 Not So Good
Higher than 3.1:1 Terrible
The ideal standing wave ratio (SWR) is 1:1, or a meter
reading of 1 on the SWR meter's top scale. A SWR ratio
of 1.5:1 to 2:1 is excellent for most mobile CB antenna
applications.
Check the SWR on Channel 1 and Channel 40
If the SWR is higher on 1, make the antenna longer
If the SWR is higher on 40, make the antenna shorter
Most antenna's are adjustable. Make small adjustments at a time.
Oct 10, 2009 | Radio Shack TRC-447 CB Radio
When i key up the mike the tx/rx light and the ant
your swr setting are off wack fix your swr
Oct 02, 2009 | Cobra 29 LTD CB Radio
The marine cb radio turns on but you can't here noboby talking nor can u talk out from the cb
Sound like either an antenna problem, or a mic problem.
The mic on most cb's also serve as transmit/receive switching. A broken wire or bad switch in the mic or cord can cause either or both to fail.
If you have a bad antenna (or cable), you should still hear squelch noise on receive (maybe lower in volume) and be able key the mic and get a transmit light on the unit. Visually inspect the connector, cable and antenna. If need be use an swr meter to prove the antenna system is bad.
Hope that helped...
Geno
Aug 01, 2008 | Audio Players & Recorders
Cobra NW LTD CB radio
start out by getting a good antenna like a wilson or k-40 if your using it on a big rig make sure its a metal mirror and door a lot of big rigs use fiberglass and thats a nono you must get a no ground plane antenna...its all in the antenna...good luck doc's cb shop ny
Apr 09, 2008 | Cobra 29 NW CB Radio
Matching Antenna, or ??????
If the antenna is tunable, you definitely need to start out by having the swr set properly on the antenna. Also, make sure the plastic ferrel, (the small round white piece) is between the top of the antenna bracked and the antenna itself. It is there to make sure the antenna does not ground out to the vehicle. If the antenna is grounding out, it will be like no antenna at all. I have also had a few customers that have had broken coaxes straight out of the factory package on cheaper antenna setups.
Dean
Rollin CBs
Feb 08, 2007 | Uniden Bearcat Pro PC78LTW 40-Channels...
Cobra 29 LTD CB Radio Logo
420 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
