Question about Roper RT21AKXKQ Top Freezer Refrigerator
Roper Refrigerator Well thanks for the help in getting the drain defrosted but why does it freeze up? Should I be worried, is there anything that needs to be replaced?
  • Anonymous Jun 09, 2008
    the freezer coils are constantly freezing up, how can I stop this from happening.
  • Roper Master
  • 2,651 Answers
No real concern, it just happens on particular models , might never happen again (espessially if you wrapped copper wire around the heater and dropped into the drain tube) sit back and enjoy that youve repaired your refrig no need to worry about it happening again,
Posted on Apr 07, 2008
Why is water leaking out evey day???
Is the water leaking from the refrigerator compartment or the freezer compartment? Can we assume the "leaking" water is more than some accumulated humidity/moisture (check your door gaskets)? Have you checked all water lines/fittings for the water dispenser/ ice cube maker (if you have one)?
If it is is the freezer section, the problem may be a clogged drain line (is there ice blocking the trough drain hole?) at the bottom of the freezer (evaporator) coils? You may need to defrost the freezer, check for any faulty parts (e.g., defrost time/ADC, defrost thermo, defrost heater), and clean the drain trough/tube. See Refrigerator Defrost Parts for illustrations.
May 22, 2014 | Roper Refrigerators
Roper refrigerator is freezing everything even when the dial is turned off. Help, a root beer just exploded!!
First check for ice build up in the freezer, which would indicate a defrost circuit failure. Look for ice build up on the evaporator coil.
You might be best served by manually defrosting your refrigerator and seeing if the indications change.
Feb 01, 2012 | Refrigerators
My Roper refrigerator collects water in both vegetable bins. Help!
Remove the food and the ice maker from the freezer ( if equiped ) . Remove the rear freezer panel . Using a hair dryer , start in the middle , below the coils , defrosting , until you see the drain hole . Use hot water to help defrost the hole . Once water starts going thru the hole , use a small hose inserted into the hole , and blow thru , to remove any unseen debris in the drain line . Use an ALUMINUM solid wire , 14-16 guage , with the insulation completely off , and insert one end into the drain hole as far as possible without any force . Wrap the other end about 1 1/2 to 2 turns , around the black rod (defrost heater) , above the hole . When refrig goes into defrost , the heat will transfer from the heater , to the wire , keeping the hole from freezing up again .
Jan 21, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
Leaking water inside fridge/freezes the food
Most likely your defrost condensate drain in the rear of your freeze is frozen over. I have put together a long page on the link below. Little too much about leaks in refrigerators and how to solve the problem to fit this page. Choose the part that applies most to your situation and let me know how I may help you resolve yours. I'll be here if you need so click on the link below, Thanks, Sea Breeze
Aug 13, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
Jul 01, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
My roper refrigerator(2door)constatly freezes up--WHIRLPOOL PROD.
Check the defrost timer, mark it and see if the dial rotates. It takes a while to see if it moves. Make sure food in the freezer is not blocking the openings for air to move around.
May 04, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Roper whirlpool model 2314273-A
This sounds like a defrost drain problem. Behind the panel in the back of freezer is a heater that defrosts the evaporator and below that is a drain hole. They will occasionally get clogged or just freeze over Pour hot water down it until it thaws then check to see if the water drains normally. If it drains after thawing then get a small length regular electrical wire and twist one end around the heater. You should get enough to extend the other end 2 or 3in into the drain hole. Now when the heater turns on it will heat the wire and thaw any ice in the top of the drain.
If you can't get water to drain then there is something clogging the drain tube and you'll have to find a way to clear it. I use a steamer that has a small tip to build pressure and force the clog out. Hope this helps.
Nov 02, 2008 | Roper RS22AQXKQ Side by Side Refrigerator
Roper Refrigerator
open the freezer compartment loo for ice build up on floor of frezer especally towards rear behind back panel. sounds like you have a clogged/frozen defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials)
Mar 05, 2008 | Roper RT21AKXKQ Top Freezer Refrigerator
Roper RT21AKXKQ Top Freezer Refrigerator Logo
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
