Question about ViewSonic VA720 17" LCD Flat Panel Monitor
Va720 view sonic monitor
The viewsonic monitor I have, has 2 screws on each side at the bottom 1 in the middle where the power supply and the other one is down at the bottom in the stand. I'm having ahard time trying to get this open so I can change the cable that goes to the computer. got any more ideas?
  • 180 Answers
To plug out the dont need to remove any screws only by applying a little force you are able to pull the cable out.
Posted on Apr 20, 2008
SOURCE:
PROBLEM IS VIEW SONIC MONITOR WERE OSD LOCK
osd lock is on screen configuration menu (on screen display) to clear an osd lock in your view sonic you can try this step
1.disconnect power cord
2.press and hold button 1
3.plug again your power cord
4. press your power button while still holding button 1
hope it help you
May 12, 2011 | ViewSonic E70f 17" CRT Monitor
Need a power supply for View Sonic VX922. Where
Here is a link for your View Sonic power supply:
http://www.shopzilla.com/laptop-power-adapters/viewsonic-power-supply/9177/products
It should have a replacement for you.
Jan 30, 2010 | ViewSonic VX922 19" Monitor Flat Panel
View Sonic VA720 monitor goes out after power goes
replace the logic board, not the power supply board. you can find logic board on ebay as low as $29...
Nov 15, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
ViewSonic Monitor screen gone black
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Oct 14, 2009 | ViewSonic VX2035WM LCD Monitor
Display on mac mini only shows no signal and turns black
his step-by-step guide describers how to obtain and install ViewSonic VA720 drivers for Mac.
1. Define your ViewSonic Monitor device model.
2. Define your operating system to install your ViewSonic Monitor device. Note: Update Drivers in Mac
3. Browse Monitor Drivers.
4. Find ViewSonic Monitor Drivers.
5. Select ViewSonic VA720.
6. Download ViewSonic VA720. Note: you can update all Drivers automatically with RadarSync (Freeware) or Driver Detective (Shareware).
7. Install ViewSonic VA720.
8. Restart or reboot your computer to finish your driver installation. Note: you can backup your computer drivers before updating.
May 03, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
My viewsonic ve170m display for 2 seconds and go back to black
Your power supply has gone bad you need to take the back off. Check the power supply look for blown caps the tops will be raised replace them that will fix the monitor.
Mar 16, 2009 | ViewSonic VE170m (Beige) 17" LCD Monitor
View sonic g220f
If both ends of the cable are plug in type, any monitor cable with a 15 pin D connectors will work.
Search internet for VGA cable.
Jul 30, 2008 | ViewSonic VA720 17" LCD Flat Panel Monitor
ViewSonic VA720
The VA720 I have has 4 screws from the back: 1 at each bottom corner and 2 in the middle lower at the base. Remove screws and carefully pry the front and back halves apart. They snap together. Usually working the bottom apart first is easiest.
Oct 08, 2006 | ViewSonic VA720 17" LCD Flat Panel Monitor
ViewSonic VA720 17" LCD Flat Panel Monitor Logo
118 people viewed this question
Top ViewSonic Computers & Internet Experts
Steve Allison
Steve Allison
Ekse
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
