Question about Video Game Consoles & Games
Just set up a 100' track and it seems as though parts of certain track pieces are intermittent as far as receiving power. All cars do the same thing at the same spot on these track pieces so it is not the cars. Any ideas?
  • Giamin Oct 01, 2008
    How can I play DVD mocies on my PS2
  • johntiller24 Dec 04, 2008
    How do you put guitar hero II cheat codes in on ps2 using the dualshock controller
How do you enter cheat codes on wii guitar hero iii legends of rock
Posted on Apr 06, 2008
Tip
Upload and Download to an Explorist 100
Summary:
Even though the Explorist 100 does not come with a data cable, or software to download or upload data to a computer, it is possible using an after-market cable and a nifty piece of software.
What I use: Note: be sure to download the software for the USB adaptor from here
  • GPSBabel software (free) from http://www.gpsbabel.org
  • A macintosh iMac and a Macintosh Macbook (but it should work fine on a PC)
What I do:
  • attach the cable to the back of the 100 as shown here
  • READ the pages at pc-mobile carefully!
  • Either use the GUI version or command line version of GPSbabel
See examples below for some usage tips....
Examples:
  • [command line] - output to Google earth format!
  1. ~/applications/gps/current/gpsbabel -t -i 'magellan' -f /dev/cu.usbserial -o kml -F 2-feb-08-track.kml
  2. ~/applications/gps/current/gpsbabel -w -i 'magellan' -f /dev/cu.usbserial -o kml -F 2-feb-08-waypoint.kml
  3. ~/applications/gps/current/gpsbabel -r -i 'magellan' -f /dev/cu.usbserial -o kml -F 2-feb-08-route.kml
where...
-t = tracks
-w = waypoints
-r = routes
-i = input format
-f = input file
-o = output format
-F = output file
Troubleshooting:
  1. If you get a speed or connectivity error from GPSbabel:
  • [on a Mac] check to see if /dev/cu.usbserial exists usng a terminal
  • retry the command ... sometimes the 100 doesn't seem to initialise properly
  • Check the FAQ's at http://www.gpsbabel.org
[Note: there may be other types of cable / software available, other than the items mentions here]
on Feb 03, 2008 | Magellan eXplorist 100 GPS Receiver
Short somewhere in basic fastrck oval
Strange indeed? Is there more that power to track connector going to the track. If so one may have been incorrectly orientated? The only other thing I think of that would cause a short between the two rails on the track is perhaps a set of dodgy points. sorry couldn't be more helpful.
Dec 22, 2013 | Lionel The Polar Express Train Set
Passenger power window is off track how to fix
Hi Heidi
This is a very easy and fast fix the Window is only aligned/attached to the track with a plastic lift/pin this has been known to come off and therefore pushing your window of the track.
You really don't need many special tools for this. You only need to remove the door panel (requires a certain size hex screwdriver for the door handle bolts) and then lift the window back on its track. Now the plastic on the track itself could have gotten brittle with age so once your able to see if it infact broke apart you can look at replacing the part usually that one runs between 60-100 dollars if you buy it online through places like ebay or parts.com for example. A remanufacturered guide/track will be quite fine. To take that whole thing apart well there are only 5 bolts you take out then you can pull the lifter assembly out (usually 5-10 minutes to do that) then to put the new one in it takes usually around 10-15 minutes but after that your window is tip top.
I hope this helped Philipp Tomorrowsdriver.com
Sep 25, 2010 | 1998 Oldsmobile Intrigue
1/3" SONY ir camera car-b3110hq. dc12v pal. Black horizontal lines scrolling up the screen. About an inch wide. Camera still working though. Intermittant fault seems to come back when the auto focus...
It seems that the power adapter in for for you country. It may be a import. Normally adapters can handle 50/60Hz but not good adapters or false adapters or adapters made for certain region are unable to handle both frequencies. This is normally the cause of the stripes you are seeing.
Cheers
TeaCii
If you own website, add live support almost free
Let real security guard watch your cam for $1/day
Jan 15, 2010 | Sony 1/3 inch CCD infra red CCTV Security...
Help with AKG shock mount H-100 parts
I kept messing with it till I got the right combination. It works fine now.
Thank you,
Mar 19, 2008 | Audio Players & Recorders
DEH 2700
i have had the same problem with a couple of my cd players, pull out your speakers and make sure the inputs on the speakers are not touching any part of the door frames or grounding out on any metal in your rear. also check if any wires are might be split and grounding out. i hope this helps
Oct 03, 2006 | Pioneer DEH-2700 CD Player
Video Game Consoles & Games Logo
57 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
