SOURCE: how do you fit a
tilt machine backwards at a good angle.look underneath and you will see that the drain hose is connected direct to the pump and held with a spring clip. just undo with pliers and bobs your uncle
SOURCE: Zanussi WJD1667W not drying at all
I've got this machine, and all washer dryers tend to have two heating elements and it sounds to me that the heating element for the drying side of the machine's functions needs replacing. You could probably find a cheap element for the machine somewhere and get it fitted for a small sum.
Let me know if this rectifies your problem
WD Pro
SOURCE: smelly washing machine drum
http://images.google.ca/imgres?imgurl=http://www.thriftyfun.com/images/feedback_image.lasso%3Fid%3D76759429&imgrefurl=http://www.thriftyfun.com/tf452244.tip.html&usg=__M4vU2JnpaL3tyDue4QVvJkaUpG8=&h=300&w=400&sz=20&hl=en&start=4&um=1&tbnid=kd-KVPILdqaeJM:&tbnh=93&tbnw=124&prev=/images%3Fq%3Dwhirlpool%2Bfront%2Bload,%2Bsmell%26hl%3Den%26um%3D1
Try reading these helpful hints on this thread... there are deeper issues to be looked at.. it's an easy fix.. Hope this helps!
SOURCE: Error E20 showing ........stops during wash cycle
not familar with the code but usually wash has a built in thermo stop to wait for water to heat to correct temp,if it works normally in a rince cycle and spins out and finishes properly i would look at heat element or stat,hope this helps
