Hard disk showing nothing on it when I tranfered to another computer and it dose have information on it.
  • poweryo Dec 13, 2008
    I have a 500 gb iomega hard drive and I only see 2 gb, how can I solve this problem
  • Jeffrey Pemberton
    Jeffrey Pemberton May 11, 2010
    Was it a master on one and a slave on the other? Did you cange the jumpers if so?
Don't worry found the problem I had the wrong jumper setting.
Posted on Apr 06, 2008
Boot time dose not showing hard disk
Some laptops will show the hard drive icon light up when the pc start up and then nothing. (not often but I have seen a few) If your system is not booting after a few seconds and no hard disk light flickerring on and off, you ether have a bad hard drive or the hard drive may not be properly seated to the disk connection.
As your pc boot up, go into the BIOS and make sure your system is "seeing" the disk. if it not, you may need to replace the disk. If it does see the disk, reseat the disk making sure it is fully connected the disk connector. Reboot your pc. If it does not boot, replace the disk.
Good Luck
Jan 09, 2012 | Compaq Presario C700T Notebook
Solid red light. Does not show up on my computer.
Dose it show up as drive letter E:/ underdevice manager in disk drives?(Check out:right clicking my computer icon onyour desktop,select disk manager)
If so,try right clicking on my computer and selecting map network drive.(You'llget the same results by right clicking on network neighborhood icon on yourdesktop and selecting map network drive.)This is the method many people use toassign a drive name (i.e.,letter) to a drive.
How about asking you to format it before you can use it?Then you can recover data from hard drive with datarecovery software like Tenorshare Data Recovery.It can recover data afterdeeply scanning your hard drive to look for lost data.
Sep 14, 2011 | Cavalry Storage CAUI37250 250 GB Hard...
My hard drive dosen't show up on my desk top when i plug it in. What should i do? thx
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this format recovery program called asoftech data recovery to recover your files.
Aug 31, 2011 | LaCie Big Disk 500 GB Hard Drive
How can I tranfer files from an windows xp hard disc to windows 7 64 bit I know I can use windows easy transfer but my old computer isn't working that well so is there an easy way to do this thanks...
If I understood you right, just get an HDD case for your Windows XP hard disk so you can plug it through USB to your new computer then copy your files normally.
If the XP hard disk is a laptop hard disk (2.5" inches), get one of these, else, its a 3.5" inches hard disk, these cases are also widely available.
I hope this helps
Jul 11, 2011 | Microsoft Windows 7 Home Premium 64BIT...
I have acer aspire 5739g laptop my dvs rom is slimtype BD E ray Which is not working properly d drives shows om computer but when i put cd or dvd it wont show the disk and whenever shows...
Considering your firmware and drivers are up-to-date and completely installed; the computer should show you the information relative to the drive. It may be, that the internal CD/DVD drive is defective and needs replacement. If you do not want to mess with replacing the existing drive, I suggest you go to BestBy or WalMart and purchase an EXTERNAL (Clamshell type) USB to plug into the computer port and bypass the internal drive completely. These drives are about $30 and do everything the original internal drive dose. Including Burning Disks.
Jan 12, 2018 | Acer Computers & Internet
My external hard disk is not working properly. i can see the icon in drivers and printers but there is no folderor icon to open
Please remove the usb cable and try to connect do you see the notification new hardware found if yes just check my computer dose the hard drive shows over there if yes and double click on it dose it open if yes and the hard drive is empty .
then go back right click on the hard drive check properties dose it show the empty and the full graphs if it shows full and dosnt show the drive letter.
then right click on the my computer icon on the desktop go to manage and diskmanage ment check the hard drive over ther dose it show its unformated or un initialized if no dose it have drive letter on it if no then right click on the drive and say change drive letter and assigned one letter like h or g and check in my computer now dose it appair.if still so try changing the usb cable may its defective.
if dosent detect at all could be your hard drive case so you can remove the hard drive from inside the case and connect it the computer if works backup your data abd return backthe hard drive in the case and if its still in gurentee return it to the service center.
Dec 14, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
did you change operating systems? windows doesnt recognize EXT2 formats there may be an issue there.
was the other drive part of a raid array before the retooling? if it was part of a raid array you may need to rebuild the array before accessing the files.
next insure there are no special drivers required to access the drives nothing wierd like scsi interface or PCI card controller?
if there is no wierd issues try useing the setup disk as a boot disk drop to DOS and access the drive that way.
Jun 10, 2010 | Fantom Drives FDU12072S 120 GB Hard Drive
Unit is on but, will not show on my computer
what could be the solution of acfaulty hard disk?
Mar 16, 2009 | Maxtor Hard Drive
Maxtor Portable 320 GB External Hard drive doesn't show on my Mac
If you can get a 3rd party disk utility like DiskWarrior because if the disc information has corrupted the computer cannot see it, the utility will re write this and if the drive is OK it will re appear
Dec 07, 2008 | Maxtor Hard Drive
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
