Question about HP DeskJet 5550 InkJet Printer
Printer not getting installed
Whenever I try to add a printer the comp shows the following msg.'The print service spooler is not running.'
  • 236 Answers
Goto start menu and click on Run
in the box type: services.msc
in the new windows that pops up, scroll down and find "Print Spooler" right click on it, and make sure startup type is set to "automatic", then click on the start button in that same window. Click apply then click ok.. close the services window.. should work now
Posted on Apr 06, 2008
  • Dave MacPhee
    Dave MacPhee Apr 06, 2008
    * sorry, after right clicking on Print Spooler, choose properties, then make sure that the startup type is set to "automatic"
SOURCE:
PRINT SPOOLER SERVICE IS NOT RUNNING MSG DISPLAY WHILE ADD PRINTER AND COULD NOT COMPLETE THE OPERATON
You need to go into services and turn on Print Spooler.
Start Run Type services.msc Click ok Scroll down to print spooler. Right click the entry Click restart.
Check that its startup type is set to automatic as well Right click the entry for print spooler Click Properties Select Automatic in the Startup type dropdown box. Click apply Click ok.
Aug 09, 2011 | Canon LASER SHOT LBP-2900 Printer
I can not get the printer to stop printing ...what do i do?
Hi please turn off the printer and restart it after five minutes if you still have the problem please uninstall and reinstall the drivers for your printer.
Jun 13, 2010 | HP Office Equipment & Supplies
I am running vista ultimate 32-bit but i often received this error message:".....the local print spooler is not running...." when attempting to install a remote oki B4400 printer. Why is that?
Print spooler is printer service if this service is not running, it might not allow you to add or see any printer drivers
Try enabling print spooler service. Follow the instructions
Click on Start->Search->type "services.msc" hit enter. Service windows will open up, on the right side pane search for "Print Spooler"
-> double click to open service and select start type as "Automatic"
click on apply and click on "Start" botton to start the service.
Now try to install the drivers
Snapshot for more information.
Hope this helps
May 21, 2010 | Computers & Internet
I'm getting the error message whenever I try to select a printer that ''Windows can't open add printer. The local print spooler service is not running. Please restart the spooler or restart the...
If u r using the XP operating system, follow the steps to restart the spooler :
1. Click Start and then click Run and in the run window type services.msc and then press Enter.
2. Locate Print spooler from the Services window which is opened now.
3. Right click on it and select Start.
May 08, 2010 | Office Equipment & Supplies
Hello, my laser jet printer is not connecting, msg when attempting to print says "Windows cannot open add printer. The local print spooler is not running, please start the spooler or restart machine." I...
Start by removing the printer driver(s). Check several times, as some printers hide in lots of places. Once the printer/driver(s) are all gone, try a new installation.
Nov 07, 2009 | HP LaserJet 1020 Printer
Printer Spooler service!
This will provide you with the most common default settings.
  1. Restart (reboot) your system [to assure a clean reinitialized starting point].
  2. Log on as any Windows user that has 'administrator' privileges.
  3. Open your 'Services' console [Start button > Run... > type "services.msc" (without quotes), then hit 'Enter'].
  4. Locate, then open "Print Spooler" [double-click it OR right-click it, then choose "Properties" from the context menu].
  5. Modify the settings on the "General", "Log On", and "Recovery" tabs according to the following images.
"Today's the best day of my life...and NOW you're part of it!"
Dec 11, 2008 | Lexmark E120 Laser Printer
Print spooler service not running
This means your printer is not correctly installed. Please remove the installed driver and printer from the PC and then follow the steps given in this TIPs N Trick by me:
http://www.fixya.com/support/r1133275-drivers_installation_problem
Nov 04, 2008 | HP LaserJet 1020 Printer
1) Click the Star>Run, type in "Services.msc" in the Run dialog box.
2) A services window popup, find the service name "Print Spooler", double it and change the Service Status to "Start".
Now u can use your printer now.
YBC (/\)
Aug 04, 2008 | HP LaserJet 1018 Printer
Spooler not running after Lexmark x83 installation on windows XP laptop
From what you're saying the windows print spooler service is not starting following the installation of your printer (and thereby you cannot print i'm assuming)
try the following to start the print spooler service if it is not already running.
Click Start
Right Click My Computer
Click Manage
Click "Services and Applications"
Click Services
Scroll down to "Print Spooler" and double click on it to open up the properties page
where it says "startup type" select automatic from the combo box list
Apply
If the service is NOT running, start it by clicking "start"
click OK
The print spooler service is started now, and **should** work properly. If the spooler is still not starting properly, then you may have a driver issue and i reccommend uninstalling and reinstalling the drivers for your printer.
Jul 01, 2008 | Lexmark X4270 All-In-One InkJet Printer
Print Spooler Problem
Try this:
Start the computer in safe mode then delete all the files and the folders in the following two folders: • C:\Windows\System32\Spool\Printers
• C:\Windows\System32\Spool\Drivers\w32x86
Start Registry Editor. To do this, click Start, click Run, type regedit in the Open box, and then click OK
Locate and expand the following registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Environments\Windows NT x86
View the list of subkeys. There should only be the following subkeys: • Drivers
• Print Processors
delete any other in this list
Locate and then expand the following registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Monitors
View the list of subkeys. There should only be the following subkeys for the default print monitors: • BJ Language Monitor
• Local Port
• PJL Language Monitor
• Standard TCP/IP Port
• USB Monitor
delete any other in this list then restart your computer.
Good Luck
May 24, 2008 | HP PhotoSmart C4180 All-in-One Color...
HP DeskJet 5550 InkJet Printer Logo
97 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
