Question about Refrigerators
Intermittent Warming on GE side by side
I need help trying to solve this problem.
I have a GE side by side refrigerator/freezer. Every two weeks, the
refrigerator side becomes warm (60 degrees) . I defrost the machine,
and both sides work for two weeks. I have done this three different times
and it's the same thing......works to two weeks, gets warm, I defrost it,
works again---for two weeks.
  • jajoffr May 11, 2009
    i have the same problem with my ge freezer we have changed the heating element, but now it seems the defrost timer is not working or woking too much. how can you check the defrost timer and where is it located exactly? we don't see it underneath or by the compressor.
  • 290 Answers
The most common cause of this with a GE fridge is the defrost heating element is burned out.
Empty the freezer, take out the shelves and remove the back wall. You will see the heater at the bottom of the evaporator coil. It is a glass tube with a heating element inside it. Some models have two heaters, some have one. If either one looks black inside the glass it is probably burned out. You can check them with an ohm meter. If you don't have a meter, take the heater to an appliance parts dealer and they will check it for you. If yours has two heaters, they must be replaced as a set.
If the heater is not your problem, post the complete model number from the fridge and I will try to walk you through the defrost system checks.
Mike
Posted on Apr 06, 2008
  • Michael  Lindley
    Michael Lindley Apr 19, 2008
    Just wanted to follow up on your fridge problem and see if you got it fixed.
    Thanks, Mike
Ge refrigerator model gss22kgmc
check defrost element, if good check defrost thermostat, if good change defrot timer/control board depending on your specific model you can look at this link provided its a diff model but none the less quite similar
am searching for Main PBA for fridge freezer model no SRL 629EV The number...
Sep 02, 2014 | GE GSS22KGMBB / GSS22KGMWW / GSS22KGMCC...
Ice in freezer and warm refrigerator Zisb48dyb
If I remember correctly, GE had a issue with the drain pan as it would clog or restrict and back up in the freezer and in the air return (hence, water under crispers if refer section). GE has a repair kit for this and they have also changed the drain hose to prevent self restricting as it leaves the freezer. This part is an Icing kit part# WR49x10021, this comes with complete instruction as to what your changing and why. This should solve your drain and water problem, if this is what your issue is. I hope this was helpful.
Mar 31, 2014 | GE Monogram ZISS420NRSS 42" Built-In...
My GE refrigerator GE GSL25JFPABS stopped cooling on both the frig and freezer sides. I pulled it out, took off the panel and cleaned around the fan. I plugged it in and it worked perfectly for just less...
you may have a defrost problem, check for frost in freezer, back wall, or pull off rear panel and check evaporator, it should have some frost on coils, if frozen all around evaporator, check glass element at bottom of evaporator, should have blue and pink wire going to element
Aug 22, 2010 | Refrigerators
Both the freezer and refrigerator will not stay cold enough, unit is about 5 yrs old. Both sides are warming up, it just won't stay cold enough on either side. I took everything out and let it defrost for...
you must have a defrost problem,open the freezer door,do you hear the fan blowing,if not change evap fan motor,remove second from bottom bin and touch the back wall if you feel ice or snow there you have a defrost problem check the t-stat and heater,not sure but if you read the tech sheet i think you can click the light switches to put into defrost,also if plugs are on t-stat,unplug them and bypass the t-stat by pluging the wire to the heater,if heater comes on then you have bad t-stat if not read out heater with meter,also ge has been having alot of problems with the mother board ,if you defrosted it and it happened again in a 2 week period i dout it's the board
Nov 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer frosts up and stops cooling after approximately 2 weeks
either low in freon or defrost timer stuck or unit needs cleaning, remove front louver panel on bottom (either 2 screws or snap fit) look for timer then use small straight screwdriver to turn slowly till clicks then wait to see if working properly, if not could be problem. if you see a lot of dust bunnies while doing then clean with vacuum and do same to back area also
Jun 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge side by side not cooling
it could be two things your compressor is shot .check what date you bought it if less than one year you call the store you got it from or G.E but the store you got from sholud replace with a new one dont let them send a service tech out
May 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator keeps freezing up. Replaced defraust heater still froze up in about 4 weeks. Tried to replace main board WR55X10037 WITH WR55X10656 BUT THE NEW BOARD DOES NOT KICK MY COMPRESSOR ON. GE SIDE BY...
please contact the service authority because this is beyond your limit. to solve your problem, the back panel has to remove and only the service engineer knows the skill.......................sorry friend!
May 14, 2009 | GE Profile PSW26P Stainless Steel Side by...
GSS20DBMB GE side by side refrigerator
If the fan is running you more than likely have a defrost problem.
look at the back wall of the freezer section if it is frosted up. it's not defrosting.
There three components in this system. The defrost heater, the defrost termination stat., and the defrost timer. Newer refrigerators do not have a timer per say it is build into a electronic board usually mounted on the back of the refrigerator under a metal plate. The termination stat is the cheapest part @ $ 25.00. The heater should run @ 50.00 to 70.00. The board could be as much as 200.00 or more. If the refrigerator is over 10 years old you may wish to look into getting a replacement. Appliances are designed to start failing after 10 years old.
My opinion.
If you unplug the refrigerator let it defrost then plug it back in. it will work properly about 3 days before it frosts back up.
hope this helped. Good luck
May 20, 2008 | GE GSS25SGMBS Side by Side Refrigerator
Refrigerators Logo
108 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
